NAT Audio Magna - Τhe most powerful single-ended tube amplifier?
Κώστας Φ.
Design Features
- Single Ended pure class A mono block power amplifier
- Eimac power industrial type direct heated triode - 450TH (N.O.S.)
- DC coupled all tube circuit (only output transformer without capacitors)
- CE comfortable
- 160 W of pure class A @4ohms or @8ohms
- low global feedback configuration with damping factor of 20
- high capacity in power supply resulting to over 500joules of energy storage
- custom designed power transformer of 1000W encapsulated-low density
- custom designed output transformer of 1000W encapsulated- last generation
- full double stabilisation of high voltage for driver tubes
- 6N1P-EV & 6N30P-DR long life military grade tubes for driver purposes
- full automatic bias with automatic-adjust (no any adjustment).
- variable bias (two mode with 40W & 160W of output power)
- balanced DC power to supply filament of output tube
- balanced regulated DC power to supply filament for driver tubes
- both input and output WBT connectors
- input wired with pure 6N silver (99,9999% of silver purity)
- all aluminum modulated chassis with double 25mm thick front panel
Billed as the most powerful single-ended tube amplifier on the market, NAT Audio's Magna produces 160 watts into 4 and 8 ohms with a frequency reponse of 10Hz to 100kHz -3dB. Input sensitivity is 2.7V for full output, gain 22.5dB at 8 ohms and noise 105dB below rated output. The tube complement is 1x 6N1P-EV, 1 x 6N30P-DR and 1 x Eimac 450TH. The unusual power triode is a direct-heated NOS design and runs in a DC-coupled all-tube circuit (output transformer-coupled without capacitors) with low global feedback applied to achieve a damping factor of 20. The power and output transformers are rated for 1000 watts and the power supply capacitance is over 500 joules. The Magna is an auto-bias design with variable bias mode for 40 or 160 watts of output power. The Magna is a special-order item with a 45-day lead time.
Πηγή: 6moons.com
Σελίδα κατασκευαστή.
Design Features
- Eimac power industrial type direct heated triode - 450TH (N.O.S.) Σε λιγο καιρο θα πρεπει να κλεψεις μουσειο για να λαλησει του ειργαλιου
- CE comfortable Διερωτωμαι πως παιρνουν εγκριση CE με 3000 V dc εκτεθειμενα σε κοινη προσβαση στο καπελακι της ανοδου.
Κώστας Φ.
Απάντηση: NAT Audio Magna - Τhe most powerful single-ended tube amplifier?
Αυτό είναι μεγάλο πρόβλημα με τις NOS. Για μένα θα λειτουργούσε αποτρεπτικά.
Η Atma-Sphere πχ λέει:
We have an internal design rule we call the 20-year rule that prevents us from using NOS tube types, in other words the tube type has to be in current manufacture.
Αυτά τα τέρατα που χρησιμοποιεί ο NAT για τι χρήση είχαν σχεδιαστεί?
Ημίθεος
Η πιστοποίηση CE είναι κατά δήλωσιν του κατασκευαστή, και είναι μάλλον άνευ σημασίας. Για να περάσουν από TÜV ή VDE...
Υπαρχουν δυο δρομοι για το CE comformity.
Aναφερεις τον ενα, που πραγματι ακολουθουν οι περισσοτεροι. Ο αλλος ειναι πραγματικος ελεγχος αλλα η διαδικασια κοστιζει πανακριβα.
Εαν ομως προκληθει βλαβη σε ανθρωπο, κατοικιδιο κλπ απο την συσκευη μπορει να μπεις μεσα εφ ορου ζωης.
Η Λυχνια που χρησιμοποιειται ειναι για Εκπομπη - διαμορφωση πλατους και αλλες χρησεις σε πομπους. Κανεις δεν σου απαγορευει να την δουλεψεις σε Audio με τραγικα χαμηλωτερη αποδοση, καθως δεν ειναι φτιαγμενη να εχει υψηλο κυκλο εργασιας (Duty cycle). Kαι για να μην νομισεις οτι εχω προσωπικα με τους μαγκες, θα πω οτι οι Γιαπωνεζοι κατι τετοια τα κανουν κατα κορον, με το δικο τους στοκ απο λαμπες εκπομπης που ξεμειναν απο τις καραβισιες εφαρμογες με την εφαρμογη του GMDSS.
Η Eitel-McCullough εχει κλησει εδω και δεκαετιες
NAT Magma Single Ended Power Amplifier Mono Block 160 Watts @ 4 & 8 ohms Class "A"
[FONT=Arial, Helvetica, sans-serif]Technical Specification[/FONT]​
[FONT=Arial, Helvetica, sans-serif]Type[/FONT] Single Ended Class "A"
[FONT=Arial, Helvetica, sans-serif]Power Output[/FONT] [FONT=Arial, Helvetica, sans-serif]160 Watts @ 4 & 8 ohms; 1 kHz[/FONT]
[FONT=Arial, Helvetica, sans-serif]Frequency Response[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]10 Hz to 100 kHz; -3dB[/FONT]
[FONT=Arial, Helvetica, sans-serif]Input impedance[/FONT] [FONT=Arial, Helvetica, sans-serif]100 kohms[/FONT]
[FONT=Arial, Helvetica, sans-serif]Input Sensitivity[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]2.7 V RMS for full power output[/FONT]
Gain [FONT=Verdana, Arial, Helvetica, sans-serif]22.50 dB at 8 ohm[/FONT]
[FONT=Arial, Helvetica, sans-serif]Rise Time[/FONT] [FONT=Arial, Helvetica, sans-serif]5 microseconds[/FONT]
[FONT=Arial, Helvetica, sans-serif]Noise[/FONT] [FONT=Arial, Helvetica, sans-serif]105 dB below rated output[/FONT]
Phase status [FONT=Verdana, Arial, Helvetica, sans-serif]Non inverting ( 0o )[/FONT]
[FONT=Arial, Helvetica, sans-serif]Tube Complement [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]1x 6N1P-EV, 1 x 6N30P-DR , 1 x 450 TH[/FONT]
[FONT=Arial, Helvetica, sans-serif]Power Requirement[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]110 VAC or 220 VAC @ 50 to 60 Hz, 450 VA [/FONT][FONT=Arial, Helvetica, sans-serif]Dimensions [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]11.8" (300 mm) wide [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]´[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] 25.2" (640 mm) deep [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]acute;[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] 14.2" (360 mm) high[/FONT]
[FONT=Arial, Helvetica, sans-serif]NET Weight [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]approx. 88 lbs (40 kg) unpacked / per piece[/FONT]
[FONT=Arial, Helvetica, sans-serif]TOTAL Weight [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]approx. 110 lbs (50 kg) packed / per piece[/FONT]
[FONT=Arial, Helvetica, sans-serif]Design Features[/FONT]
[FONT=Arial, Helvetica, sans-serif]- [/FONT]Single Ended pure class A mono block power amplifier
- CE comfortable
[FONT=Arial, Helvetica, sans-serif]- [/FONT]160 W of pure class A @4ohms or @8ohms
[FONT=Arial, Helvetica, sans-serif]- [/FONT]high capacity in power supply resulting to over 500joules of energy storage
[FONT=Arial, Helvetica, sans-serif]- [/FONT]custom designed power transformer of 1000W encapsulated-low density
[FONT=Arial, Helvetica, sans-serif]- [/FONT]full automatic bias with automatic-adjust (no any adjustment).
[FONT=Arial, Helvetica, sans-serif]- [/FONT]balanced regulated DC power to supply filament for driver tubes - both input and output WBT connectors
Site http://www.nataudio.com/products/Magma/Magma.htm
Κώστας Φ.
Απάντηση: NAT Magma Single Ended Power Amplifier Mono Block 160 Watts @ 4 & 8 ohms Cl
Έχει ξαναμπεί εδώ.
Ας γίνει ένα merge. :cool_4:
Re: NAT Magma Single Ended Power Amplifier Mono Block 160 Watts @ 4 & 8 ohms Class "A
Kοιτα που μας διαβασαν και βγαλανε το καλωδιο της Υψηλης, αλλα και την μπροστελα, χαριν φωτογραφισης.
Τωρα πως θα δουλεψει διχως την υψηλη Ταση ?
Nikos67
