Tosiba HDDVD firmware update
Firmware Update Information for Owners of Toshiba HD DVD Players: Models HD-E1, HD-XE1 and HD-EP10.
[FONT=Verdana, Arial, Helvetica, sans-serif]Firmware Update Version:[/FONT]
2.5
[FONT=Verdana, Arial, Helvetica, sans-serif]Applicable Models: [/FONT]HD-E1, HD-XE1 and HD-EP10
[FONT=Verdana, Arial, Helvetica, sans-serif]Overview:[/FONT]
As part of our commitment to provide world-class service to our customers, Toshiba is supplying this firmware update for use by purchasers of Toshiba HD DVD Player models HD-E1, HD-XE1 and HD-EP10. This firmware update includes support for 1080p/24Hz OUTPUT (for HD-XE1 and HD-EP10), additional OSD languages, improved network connectivity supporting the download of web-enabled network content associated with certain HD DVD discs, and also addresses certain disc playback and HDMI/DVI related issues identified by Toshiba.
Update Sheet download:
HD-E1, HD-XE1, HD-EP10 (click your model)
[FONT=Verdana, Arial, Helvetica, sans-serif]Important Note:[/FONT]
Certain HD DVD discs may contain or have the capability of downloading studio-provided, web-enabled network content. To minimize any potential compatibility and/or connectivity issues, before viewing such content, it is recommended that you perform the firmware update process to ensure that your HD DVD player is using the latest firmware version.
[FONT=Verdana, Arial, Helvetica, sans-serif]How to obtain and install the update:
1. If you have a broadband internet service</STRONG>
[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]You may obtain the firmware update over the internet using the Ethernet port on the back of your HD DVD Player. Instructions for configuring the Ethernet port and downloading the firmware update can be found in the owner's manual and Update Procedure sheet for your HD DVD Player. Set out below is an overview of the process:
- BEFORE BEGINNING THE FIRMWARE UPDATE PROCESS, BE SURE TO REMOVE ANY DISCS FROM YOUR HD DVD PLAYER.
- Please configure the Ethernet port. You may need to turn on DHCP and DNS.
- After you have configured the Ethernet port, follow the directions in the owner's manual to check for a firmware update.
- If a firmware update is available for your player, it will take about 20 minutes to download and install.
When the later version of FW is available for your player:
1. A message will appear, and the firmware update will automatically start.
2. When the firmware update is completed, the player will automatically turn itself off.
For the HD-XE1 player only:
Please also follow steps 3 through 6
3. Power up the player again.
4. The player will display a message that another update will start.
5. Read the message and press OK. The message will disappear, and the second firmware update will automatically start. Please be patient during this process. (During the update, "VERUP" will flash on the display of the player.)
6. When the firmware update is completed, the player will automatically turn itself off.
- DO NOT UNPLUG, TURN OFF, OR USE ANY OTHER FEATURE OF YOUR PLAYER DURING THE FIRMWARE UPDATE PROCESS. Doing so will cause the writing of the firmware update to the player to be halted and the player may no longer operate properly. If the player stops working, please contact Toshiba Customer Service for your country.
- If no firmware update is available, the player will quickly exit the firmware update process.
- Please refer to the owner's manual and Update Procedure sheet for additional details.
[FONT=Verdana, Arial, Helvetica, sans-serif]2. If you have a PC with a CD-RW drive that is connected to the internet [/FONT]
You may be able to download an ISO image file of the firmware update to your PC and copy it to a blank CD-R or CD-RW disc. For more information, and to download an ISO image file of the firmware update
"click here" (English Language Site).
3. If you are unable, or prefer not to obtain the firmware update by one of the methods described above
You may contact Toshiba Customer Service for your country and request that a firmware update disc be sent to you by mail.
- You can update the firmware using this update disc by following the instructions provided with the disc.
Please note, Toshiba's terms and conditions that applied to your acquisition, ownership, possession and use of the HD DVD player will apply (with the appropriate changes) to the firmware updates. By uploading the firmware updates to your HD DVD player, you expressly agree to the same.
[FONT=Verdana, Arial, Helvetica, sans-serif]Frequently Asked Questions:[/FONT]
Q1. What does this update do?
A1. This firmware update adds support for 1080p/24Hz output to the HD-XE1 and HD-EP10 player. also it adds more on-screen language display options for HD-E1, HD-XE1 and HD-EP10. In addition, this firmware update improves network connectivity for supporting the download of web- enabled network content associated with certain HD DVD discs, and also addresses certain disc playback and HDMI/DVI related issues identified by Toshiba.
Q2. Why do I need to turn on DHCP and DNS?
A2. Turning on DHCP causes the player to automatically detect its IP address and other network information from your internet service provider's DHCP server. Turning on DNS causes the player to automatically detect the DNS server address associated with your internet service provider.
Q3. I purchased an HD DVD disc that contains/has the capability of downloading web- enabled network content. What do I need to do to view this content?
A3. First, be sure that you have properly configured the player's Ethernet port. If your Ethernet port is properly configured, perform the firmware update process to update the player's firmware to the latest firmware version. Once you have updated the player with the latest firmware, follow the directions that came with the HD DVD disc or that appear in the menu of the HD DVD disc. Should you experience problems viewing such content, please contact Toshiba Customer Service for your country.
Q4. When I connect my HD DVD Player to my HDTV or HD Monitor using a HDMI to DVI adaptor cable or a HDMI to DVI adaptor, the output resolution of the player remains fixed at 480i. Does the new firmware address this issue?
A4. This firmware update addresses the issue. Should you continue to experience problems, please contact Toshiba Customer Service for your country.
Q5. The HDMI output does not work or works intermittently with the HDMI or DVI input on my HDTV or monitor. Does the new firmware address that issue?
A5. The firmware update addresses and improves HDMI and DVI connectivity issues. If you still experience such issues, try disconnecting and reconnecting the HDMI cable. Make sure your display input is set to HDMI (or DVI). If your display has more than one HDMI/DVI input, make sure that all connected HDMI/DVI source devices are powered on (even if not in use). If none of these solve the issue, please turn off the TV and the HD DVD player. Check all connections. Disconnect and reconnect the HDMI cable. Turn on the TV first and then turn on the HD DVD player. Should you continue to experience issues, please contact Toshiba Customer Service for your country.
Q6. During HD DVD playback I sometimes experience pixelization, block noise or audio dropouts. Sometimes playback freezes or stops. Sometimes, playback is not smooth. Does the new firmware address these issues?
A6. This firmware update addresses various playability issues. You should also check to be sure that the disc is clean and, if the disc will not operate at all, that you are inserting the disc with the right side up. In the event that playback freezes or stops, press and hold the ON/STANDBY button on the front of the player for approximately ten seconds. This will cause the player to turn off. After the player turns off, turn the player back on by pressing the ON/STANDBY button, and then press the OPEN/CLOSE button to remove the disc. Should you continue to experience issues, please contact Toshiba Customer Service for your country.
Q7. Do I need to install prior firmware updates before installing the current firmware update?
A7. No. The current firmware update includes all of the prior firmware updates.
[/FONT]
Σκανε οι βόμβες, σκάνε! Το απόγευμα θα το κατεβάσω και θα σας πω τις διαφορες!
btw το ελληνικό μενού είναι από το προηγούμενο firmware update. Στο ΧΕ1 τουλάχιστον, που έχω εγώ, υπάρχει το ελληνικο μενού! :bravo:
Λοιπόν... μόλις είδα οτι τελικά έχω ήδη την έκδοση 2.5... αλλά δεν έχω 1080p/24.
δοκίμασα με το DVD (hddvd version) και συνεχίζω να βλέπω 1080p/60 στο σήμα του προβολέα.
αντίθετα το PS3 μου δίνει κανονικά 1080p/24.
Ουγκ;
Την αναβάθμισή την έχω κάνει εδώ και μια εβδομαδα περίπου στο EP-10 μου. Στα μάτια μου έχει βελτιωθεί η εικόνα στο SD και πλέον μπορώ να πώ πως ξεπέρνά άνετα το pioneer 696 . Στα HD-DVD δεν βλέπω διαφορές. Εκει έτσι κι'αλλιώς πετούσε...Για το 1080/24 δεν μπόρεσα να το τσεκάρω γιατί ο 700άρης μου δεν το υποστηρίζει. Επίσης βέλτιώθηκε κατα πολύ η ευκρίνεια στα 1080i. Τα Ελληνικά είναι μια καλή προσθήκη, αρκεί να αρχίσουν να υποστηρίζονται περισσότερο στις ταινίες. Στα μενού του μηχανήματος, οπού υποστηρίζονται πλέον, δεν τα χρησιμοποιώ γιατί δεν μου αρέσουν...Κάτι πάιζει και με τον ήχο (στο καλύτερο) αλλά ακόμα δεν έχω καταλάβει ακριβως τι. Για παράδειγμα: πριν την αναβαθμιση στο Band of brothers (σε DVD) ο receiver έδειχνε ότι δεχόταν σήμα stereo και μετά λέει οτι δέχεται σήμα dolby digital. Και κάνει διαφορά και στα αυτιά μου. Αυτό δεν μπόρεσα να το καταλάβω...Χαλάλι όμως. Θα το αντέξω...!
Ουγκ;
Ρόμπα!!!!!!:happy_9: :happy_4:
Απάντηση: Tosiba HDDVD firmware update
Εγώ έχω το HD-E1........οπότε δεν έχει 1080p/24Hz για 'μένα.......:-|
Σε πολύ μικρό χρονικό διάστημα από την κυκλοφορία της έκδοσης Firmware 2.5 το οποίο επιτρέπει την χρήση 1080p/24Hz η Toshiba ξαναχτυπά με το νέο Firmware Update 2.7 (αφορά τα μοντέλα HD-XE1 / HD-XA2, HD-A20, HD-A2, HD-A2W και HD-D2 προς το παρόν). Υπόσχεται να δώσει χαρά σε όλους τους κατόχους των νέων A/V ενισχυτών, μιας και θα παρατηρήσουν την ένδειξη Dolby TrueHD (όπως και όλες τις ενδείξεις των νέων φορμα) να ανάβει επιτέλους, μετά από αρκετό καιρό υπομονής, στον αγαπημένο τους ενισχυτή.
Μπράβο στην Toshiba και ελπίζουμε γρήγορα γρήγορα και στα υπόλοιπα μοντέλα.
Θάνος Γαλάνης
