Ποιός φοβάται τους "ψηφιακούς"; (2007's Award Winners από το 6moons)
Κώστας Φ.
Το 2007 οι 9 συντάκες του 6moons έγραψαν 175 reviews και μοίρασαν 34 βραβεία.
Τη συγκεντρωτική λίστα με τις συσκευές που απέσπασαν κάποιο βραβείο μπορείτε να τη δείτε εδώ.
Για διαβάστε τώρα και το "editorial" που σχολιάζει τα της χρονιάς που (σχεδόν) πέρασε....
State of the (Non) Union addresses. They're useful. Hindsight commentary creates context going forward. Being the middle of December, I had just finalized the awards graphics for this year's winners in our pages. This de facto overview of 2007 reminded me of component highlights. Where we'd been. Then something struck. There was a highly unusual peak (well beyond linear) of class D amp winners this year. All of 'em -- with only one exception -- were based on lower-power Tripath chips. Had all this occurred by way of the same writer, one would cry personal biases, system context and write it off. Which is why it would never have happened in the first place. What's more, each of the actual five writers awarding class D amps adores and owns valve amps. Let's illustrate this spike with hard figures:
Out of 34 awards (for in certain cases more than one component at a time), the spread over categories turned out as follows:
1 cables
4 CDP
3 DAC
1 mobile hifi
1 vinyl
6 speakers
3 tube integrateds
1 tube preamp
2 solid-state preamps
1 tube amp
2 solid-state amps
1 hybrid amp
1 Hypex amp
8 Tripath amps
That's 9 class D amps out of 13 amps total, 8 of 'em Ts. Doesn't that give you pause? It sure does me. Adya Tripathi's corporation goes bankrupt, Cirrus Logic acquires its assets and Tripath amps go from strength to strength. Granted, this occurs well outside the mainstream. On one side we have the Kingrex, Sonic Impact, Trends and Winsome Labs offerings for a few hundred bucks each. Their appeal is mainly to the cheapskate brigade, with the well-off bothered by perception, lack of bragging rights and suitable speakers. On the other side we have Firenze Audio and Red Wine Audio which offer more power and battery drive. There's less mess-with-perception hurdles but still few bragging rights.
There's more on this topic. In our 5+ years of operation, we've bestowed our Lunar Eclipse award only four times. We apply it sparingly to truly mean something. To be eligible, numerous factors have to align just so. Simply being very good but ultra expensive won't cut it for example. Out of these four awards, two have been for speakers, two for amps. And both amps are class D, one ICEpower, one Tripath. Last year, John Potis voted for the Bel Canto Design e.One Reference 1000s. He also owns 300B push/pull and 845 SET amps and -- among a lot else -- the 96dB sensitive Hørning Perikles speakers to go with 'em. This year I voted for Red Wine Audio's Signature 30.2. I also own Yamamoto's A-08S, Fi's 2A3 monos, Melody's I2A3 and SP3 and Eastern Electrics's M520. For context, John is my senior reviewer with the (here plus elsewhere) most reviews under his belt of any of my staffers. That's why bestowal of Lunar Eclipse awards thus far has been limited to him and me. It requires experience and context. Back to D-class amps.
David Kan this year awarded the Kingrex, Trends and Winsome Labs offerings. He owns a bevy of tube amps by Dared but also chip amps by AudioZone, conventional solid-state by Symphonic Line and high-power class D by NuForce. Marja & Henk awarded Kharma's small D-class monos. They own an Audio Note 300B integrated, a bevy of 300B tubes for seasoning and a Moscode hybrid. Do we see a trend in the making?
On the personal front, FirstWatt's F1 and F3 gave way to a pair of F4s as my current transistor amps of choice. They combine the highest resolution in relaxed and natural form of any amps in my house plus -- by virtue of unusual transparency to what precedes them -- whatever valve-sourced effects a first-rate preamp like ModWright's LS-36.5 or Supratek's Cabernet Dual adds. Things have developed to a point where, most days of the week, I prefer to listen to my Rethmic Lowtharios, the Saadhanas, over the F4 rather than tubes.
In a related vein -- tube man discussing transistors -- my reviews of AMR's AM-77 180wpc hybrid and Coda's 450-watt CX monos reconfirmed the old adage that high-power amps sound better on speakers which need power. Accept the exceptions though. John's encounter with the 1000-watt Bryston 28B-SSTs proved something unexpected. Bryston's claim for true load invariance, sonics as good at 1 watt as at 500, finally came home. One tends to think of load invariance in beastly terms. An amplifier's behavior won't change into unfriendly loads. If you're paying tons of money for a company's crowning achievement and statement amplifier however (with transistor amps, this invariably means the most powerful), shouldn't it sound terrific no matter what - at low volumes and even over 100dB speakers? It really should. It hardly ever does though.
99 out of a 100 times, the very things which create high power -- endlessly paralleled output devices, multiple gain stages in series, high feedback to combat nonlinearities -- also create compromises for applications where this power is excessive and redundant. A pretty logical conclusion a sane mensch might draw from that is that
a/ good-sounding muscle amps are much harder to make than low-power versions
b/ not to buy speakers which force you to use powerful amps
Before you insert into the 'low-power' placeholder valve amps by definition -- or SETs to be more specific -- hold a moment. Low output impedance and current delivery are audible across the board. But they're not something SETs deliver to the same extent as most transistors. Resolution, among other things, is a function of noise floor. It's another area where transistors, in general, hold the stronger hand. Transistor amps like Nelson Pass' FirstWatt F3 and F4, Vinnie Rossi's Red Wine Audio Signature 30.2 and Bryston's 28B SSTs show how sand amps can offer something as important to audio pleasure as direct-heated triodes though not exactly the same. That lit-from-within thing triodes do -- 'artificial intelligence' as some refer to it -- is still beyond the grasp of transistors. But so is their sense of seamless bottom-to-top linearity, transient definition and dynamic tracking out of reach of most triodes. Those tend to lack the raw current which translates into these very qualities; plus stygian bass foundation and upper-bass attacks to convey soundstage scale and music power respectively. By the time you increase tube power with push/pull and paralleled circuits, the speed and immediacy of simpler circuits tend to get sacrificed.
Mind you, none of this is gospel. It's merely me cottoning, slowly but inexorably, to specific transistor virtues as something to no longer be without. Until such day that a single system can do it all -- or better, when I tire of tiring of sameness -- polygamy rules. It means owning multiple components in each category. It means assembling them in various ways to celebrate a particular flavor for a day, a week or even longer until boredom demands a different aroma. One key facilitator are the right speakers. By not requiring much power, better-sounding amplifiers of lower wattage ratings become suitable. Those can be a lot cheaper to get you three or four for the price of one. Just think Trafomatic Experience One for example.
When not in use, spare components take up space of course. That's not workable for everyone. Still, a lot of AudiogoN buying 'n' selling grief would cease if the more seriously afflicted audiophiles practiced polygamy: amp and speaker swapping on a regular basis without selling off stuff. Part of audiophilism is the enjoyment of ownership, of cool toys. Why not be master over a strategic harem of many superior but affordable amps, integrateds and speakers to match 'em with? Clearly, this is not a universal solution for everybody. But if you're seriously bitten by the bug, it could be just perfect. It's something that works for me and I don't see giving up on it anytime soon. Which probably means, there's a class D amp in my future too.
This returns us full circle. D-class, in certain implementations, has achieved surprising maturity. Tube lovers exposed to them agree how these amps bridge the old polarization of transistors and tubes. That neither means all class D amps sound the same nor that some of them sound 'like' tubes. What it does mean is that they can offer many of the good qualities of tubes together with core aspects of transistors. For the experimenters among us, it's fortunate that the market now offers quite the choice of low-power amps and the necessary speakers to go with them. It makes audio polygamy financially feasible for more of us. Thus spaketh Harem Baba...
Πηγή: 6moons.com
Τελικά έχει τόσα κοινά ο ήχος των Tripath με τους λαμπάτους;
Γενικά, που θα πάει η ιστορία με τους Class D/T; (Ξέρω, αλλά κουβέντα να γίνεται... :mrgreen: )
Κώστας Φ.
Απάντηση: Re: Ποιός φοβάται τους "ψηφιακούς"; (2007's Award Winners από το 6moons)
Τωρα εσεις που ξερετε, αυτο το 6μουνς ποιοι το εχουνε ?
Ποιος κανει κουμαντο τελος παντων ?
Μιχάλη προσωπικά δεν έχω ιδέα.
Πάντως ως publisher αναφέρεται αυτός (γεννημένος στη Γερμανία, ζει στην Κύπρο). Οι reviewers είναι από...παντού (Ολλανδία, Hong Kong, Αυστραλία, Γαλλία, ΗΠΑ, you name it).
Εγώ. Τους φοβάμαι τους "ψηφιακούς".
Ακόμα περισσότερο όμως φοβάμαι τη βλακεία.
papaevagelouv
