Kαι η Bryston στο παιχνίδι των "ψηφιακών"...
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Kαι η Bryston στο παιχνίδι των "ψηφιακών"...
Είνια το πολύ γνωστό. Όταν δεν μπορείς να τους νικήσεις πας μαζί τους...
Τι τιμή να έχει άραγε αυτό;
Κώστας Φ.
Bryston D-class - Reveals James Tanner that "we have been researching "Class D" designs for about 10 years now and plan on introducing two 8-channel Class D Zone amplifiers at the Vegas 2008 CES Show next month." Asked whether any 2-channel amps were in the works: "No 2 channel amps planned. Generally speaking, the Class D amps will be a bit cheaper because the are very efficient so they do not require anywhere near the heatsink size. We are using Bryston Linear Power Supplies though so the cheaper, lighter switching supplies will not be used."
Πηγή: 6moons.com
Κώστας Φ.
Bryston's James Tanner surprised me by showing me a new direction for Canadian amplifier manufacturer Bryston: it has developed a series of class-D (switching) amplifiers. "You'll notice from the line's hybrid name that we combine the class-D output module with regular linear power supplies, not switching supplies," explained James. "The switching supplies are too noisy."
Prominently displayed on their exhibit was the firm's new D-250Z amplifier, rated at 250W into each of its 8 channels. Such an amplifier can supply a full 7.1 home-theater system, or four stereo zones. Furthermore, each individual stereo zone can be bridged to deliver 800 Watts into 8 ohms.
"We now have an amplifier that supplies 8 channels at the very good price of $5695, much less than our conventional multichannel amplifier reviewed in the pages of your magazine." Notable, however, is that the company's usual 20-year warranty does not apply to the D-250Z, which is only warranteed for 5 years.
blog.stereophile.com
Απάντηση: Re: Kαι η Bryston στο παιχνίδι των "ψηφιακών"...
$5695 :cool_11: :cool_11: :cool_11:
Κώστας Φ.
Νταξ' δεν είναι κακή τιμή.
Λογικά στην πιάτσα θα κυκλοφορεί με λιγότερα από $5000.
Αν είναι όντως Hypex τα modules και αν μιλάμε για την ακριβή σειρά, για να φτιάξεις κάτι αντίστοιχο μόνος σου αγοράζοντας direct από την Hypex θα σου βγει κανένα 2-2,5 χιλιάρικα το λιγότερο (1600 ευρώ κάνουν τα 8 modules και θες PSU, toroids, κουτιά, βύσματα κλπ) και μιλάμε για DIY λύση στην ουσία. Διπλάσια τιμή για ένα αντίστοιχο εμπορικό προϊόν (με βελτιώσεις που ίσως έχουν γίνει στα module, έστω και μόνο στα χαρτιά, εγγύηση, brand name κλπ) δεν είναι κάτι τόσο εξωφρενικό. Έχουμε δει πολύ χειρότερα.
Αν από την άλλη μιλάμε για το Standard module (το φθηνό που βγαίνει στα 500 περίπου ευρώ η 8άδα), χωρίς regulators κλπ, τότε όντως είναι λίγο τσιμπημένη η τιμή.
Προσωπικά βέβαια, με 5 χιλιάρικα θα έφτιαχνα τούμπανο πολυκάναλο με modules κατευθείαν από τη Hypex...
Κι όταν λέω τούμπανο το εννοώ:
4x700HG modules, με τα δύο (για τα μπροστά ηχεία) σε dual mono και τα άλλα δύο με κοινή τροφοδοσία (για κεντρικό και sub) και 4x400HG με ένα PSU ανά δύο modules. Softstart, φίλτρο, βύσματα Neutrik, μπόρνες WBT και για το τέλος, ένα ωραίο κουτάκι:
Χλωμό να χωρέσουν σε ένα κουτί (μάλλον σε ένα κουτί τα 700 και σε άλλο τα 400), αλλά who cares?
Did I hear you say "overkill"? Yes, but I like it! :mrgreen:
Ειναι ακριβο για τα σημερινα δεδομενα.
Κα ειναι κατι που φτιαχνεται, εγω ουτε ακριβο κουτι θα αγωραζα.
Για τα αλλα οπως βυσματα μπορνες ενταξει.
Κώστας Φ.
Re: Απάντηση: Kαι η Bryston στο παιχνίδι των "ψηφιακών"...
...εγω ουτε ακριβο κουτι θα αγωραζα.
Πως φαίνεται ότι δεν είσαι hi-endας! :happy_9:
Σοβαρά τώρα, αν δώσω 4.700 για DIY (ή έστω semi-DIY) λύση, δεν θα κολλήσω στα 300 που μπορεί να κάνει ένα ακριβό κουτί. :cool_4:
Φυσικά δεν το αγοράζεις γιατί είναι ακριβό αλλά γιατί είναι όμορφο.
Απάντηση: Re: Απάντηση: Kαι η Bryston στο παιχνίδι των "ψηφιακών"...
Ειμαι κρυφο-hi-endας!! "happy_1" "happy_1" "happy_1"
600$ το κανάλι με το όνομα της Bryston από πίσω είναι μια χαρά τιμούλα παιδιά! Σκεφτείτε το σε δικάναλο, 1200$, ε, τι άλλο θες?
Να δείτε που στην επόμενη έκθεση της, η Magnepan με αυτό θα δουλεύει τα ηχειάκια της, ιδίως τα μεγαλούτσικα! Οπότε 6 κανάλια θα χρησιμοποιεί για τα ηχεία της σε ενεργή τριενίσχυση (όπως κάνει πάντα) και τα ρέστα μας (τα άλλα 2) ή θα παίζουν κανά σαμπάκι, ή θα παίζουν κεντρικό και sub σε HT, καλό μου φαίνεται!
Αρα για ενα 3.6 Magnepan θελεις 6 καναλια επι 600 δολαρια κανει 3.600$.
Εδω ελλαδα ποσο θα εχει? αυτο θελω να το δω :smoking:
Ακριβώς! Και τα δυο κανάλια του Bryston που περισσεύουν, bonus να τα κάνεις ότι γουστάρεις!
Και μη μου πεις ότι τα βατ του ενισχυτή αυτού δεν αρκούν να οδηγήσουν σωστά το ribbon γιατί θα πέσω ξερός στα γέλια.... Ομοίως και για τη μεμβράνη των χαμηλών!
Πάω στοίχημα ότι πολλοί τελικοί μονομπλόκ στα ίδια χρήματα (να μη πω και σε πολύ περισσότερα) παίζουν πολύ πολύ χειρότερα, οπότε γιατί όχι?
Εξ'άλλου αν δώσεις 7.500 ευρώ γαι τα 3,6 ή κοντά 20.000 ευρώ για τα 20.1, γιατί να μη δώσεις και ~4.000ε για ενισχυτή? Εδώ πουλάνε τόσους και τόσους ενισχυτές σε πολύ ακριβότερα κοστολόγια, και δε ξέρω κατά πόσο δικαιολογημένα....
Τώρα μη με βγάλετε και διαφημιστή των Bryston.... οκ? Υπάρχουν κι αλλού πορτοκαλιές που κάνουν πορτοκάλια....
Κωστα καποια στιγμη θα σε χρειαστω για καποιες γνωσεις περι 3.6 Magnepan :happy_9:
σαν και αυτον στη φωτογραφια να γινεις ξεδιαντροπε
  • loggeo
mgm
