Αρχεια εικονας .mod
Αυτα τα αρχεια πως τα βλεπουμε σ'ενα pc;
Ειναι απο βιντεοκαμερα JVC με σκληρο δισκο αλλα δεν εχει καποιο προγραμμα για αναπαραγωγη.
Την εχει ενας φιλος κι εγω δεν βρηκα ακρη.Για βαλτε τα δυνατα σας...
actually just found another program (that comes bundled with the JVC Everio) called Cyberlink PowerDirector. This program will allow you to export your video(s) as .AVI or .MPG1 or .MPG2 files. Here’s a brief overview of how to do it:
1 Open PowerDirector
2 Import all of your .MOD files.
3 Add all of your .MOD files to the timeline (or) If you want to create individual .AVI or .MPG files, add the files to the timeline individually.
Once your timeline is setup how you’d like it, Click “Produce”
4 Now select Save to File
5 Finally Select .AVI or .MPG and select the directory that you’d like your file stored to.
If you manually change the file type from .MOD to .MPG, you can play it in Windows Media Player. If you want to change the format to upload it to the web (maybe you need .WMV) use ImTOO MPEG Encoder. It’s a free download that lets you change the format of almost any file type (including .MPG) into almost any other format (given that the clip is less than 5 minutes long).
http://www.moviecodec.com/imtoo.html
gvts
