HD-DVD....the END...
Τι εγινε τελικα ρε παιδια οντως Τελος?
(απλα θελω να το ακουω :happy_8:)
ΝΑΙ, ΤΕΛΟΣ...αλλά μη χαίρεσαι, διότι η κεντρική ιδέα από όλη αυτή την κουβέντα είναι οτι η Sony είναι ο Σατανάς που θα φέρει το μονοπώλειο στον πλανήτη. Με λίγα λόγια η προφητεία συνεχίζεται και αυτή τη φορά το θηρίο είναι κακό και με πολλά μπλέ κεφάλια.
Top ten things to do with your now defunct HD-DVD player
Finally, HD DVD users now have the empirical evidence they've been looking for to prove that the universe really is conspiring against them. We figured we'd make ourselves useful over here and give you a list of things you can do with your poor, obsolete HD DVD player -- starting with taking it out to dinner, excusing yourself to the bathroom before the check comes... then getting the hell out of there.
  • Gimmes
  • eBay
  • Doorstop
  • Entertainment center cup-holder
  • Destroy it. Office Space style. :cool_11:
Oh, the humanity
  1. Mail it to the office of Howard Stringer in protest of Blu-ray's victory.
  2. Plug it into your clothes dryer's 240-volt outlet. Woops, honey! My bad, guess we have to buy a Blu-ray player now. :cool_11:
  3. Finally, replace your Betamax player. :respect:
  4. Buy the Blu-ray player of your choice, put it in the box, attempt to return it as "defective."
  5. Channel it through Whoopi Goldberg and make some pottery with it.
  6. Put a Blu-ray disc in the tray and then call up Toshiba when it doesn't work. Repeatedly. :cool_1:
  7. Put it in a time capsule, just to confuse future generations. :happy_9:
  8. Buy a few dozen of 'em and build a little hut for your Blu-ray player.
  9. Lock it alone in a room with a few lethal weapons... let it die honorably.
  10. Use it to upscale DVDs, which is all you ever used it for anyways.
HV
Το πεθαμενο HD-DVD ... Νεες releases....Απο WARNER :p
In The Valley If Elah ( Warner )
Michael Clayton ( Warner )
No Reservations ( Warner )
Γενικα δεν νομιζω ποτε να σταματησουν οι HD-DVD releases τουλαχιστον οχι απο Paramount και Universal αν και μαλλον τα κομματια θα ειναι λιγα..
Απάντηση: HD-DVD....the END...
Κριμα ,το μονοπωλιο ποτε δεν ειναι υπερ του καταναλωτη.Ειδικα απο μια εταιρια οπως η sony !Ειναι πολλα τα ατοπηματα που εχει κανει στο παρελθον για να την εμπιστευομαστε.Ειναι τουλαχιστον αφελες!
απλα τελειωσε το πρωτο μισο
για να δουμε τι θα κανει στο καθεστως που λεγεται
DVD
Re: Απάντηση: HD-DVD....the END...
Aυτο ειναι που φοβομαστε... οχι το μονοπωλιο της κατασκευης... γιατι υπαρχουν πολλοι κατασκευαστες player...
το μονοπωλιο του φορματ και αν θα θελησει να το εξελιξει και να λυσει τα ηδη προβληματα που εχετε πει εσεις οι ιδιοι οτι εχει
φοβομαστε και μαλιστα απο τη SONY... που δεν εχει δειξει και τις καλυτερες αντιδρασεις σε αρκετα στο παρελθον
και σαν πολιτικη τιμων... και σε επιλυση προβληματων σε profile κλπ... ειδωμεν λοιπον ... σε τι θα καταληξει το BR...
Νεες εξελιξεις...
ΚΑΙ ΝΑΙ Η ΣΟΝΥ ΑΝΑΚΟΙΝΩΣΕ ΤΑ 2 ΝΕΑ BD PLAYER ΜΕ PROFILE 1.1!!!!
ΠΙΟ ΝΕΑ, ΠΙΟ ΑΚΡΙΒΑ... ΚΑΙ... ΠΙΟ ΙΔΙΑ ΑΠΟ ΟΤΙ ΚΥΚΛΟΦΩΡΕΙ ΣΤΗΝ ΑΓΟΡΑ ΕΔΩ ΚΑΙ 5 ΜΗΝΕΣ!!!
Αυτη ειναι η σονυ... περαστικα μας...
George195
