ΝΟΚΙΑ 7600 - χαρίζεται
ΝΟΚΙΑ 7600 αριστο σχεδόν αχρησιμοποίητο, σε τιμη απλά να φύγει απο το σπίτι καθώς εβαλα μπρός να διώξω οτι δεν χρησιμοποιώ πλέον...
30 ευρώ μόνο...!!!!
Dual Mode Operation
  • WCDMA and GSM 900/1800 networks
  • Automatic switching between bands and modes
Size
  • Weight: 123 g (with Lithium Battery)
  • Dimensions: 87 mm x 78 mm x 18.6 mm, 103 cc
Display and User Interface
  • Bright active matrix TFT color display
  • 65,536 colors · 128x160 pixels
  • Graphical user interface
  • Built-in HF for speech, music, and polyphonic ringing tones
  • Three soft keys plus scroll key
Integrated Digital VGA Camera
  • Image/video resolution: 640x480/128x96
  • Self-time function (10 sec)
  • Video capture up to 15 frames per second
  • Phone display used as a viewfinder
  • 29 MB dynamic memory for contacts, video clips, images, tones, messages, music files, add -on applications, calendar, and to-do notes.
  • Dedicated camera key for instant capturing of still images or videos
Digital Music Player
  • Digital Music Player for MP3 and AAC files
  • Music file download over-the-air or from a combatible PC via Nokia Audio Manager which is included in Nokia PC Suite
  • Listen with stereo headset or through internal loudspeaker
  • MP3 and AAC files as ringing tones
High-Speed Data
  • Up to 57.6 kilobits per second in circuit-switched data networks
  • Up to 384 kilobits per second (downlink) and 64 kilobits per second (uplink) in WCDMA packet transmission networks
  • Multitasking: Take and send pictures while you talk
Connectivity
  • Infrared
  • Bluetooth wireless technology
  • USB with Pop-Port™
  • Wireless phone connection to a compatible PC
  • Send/receive pictures, video clips, graphics
Messaging
  • Combine video/picture, text, and voice into multimedia messages
  • Embedded e-mail client
  • Concatenated text messages, picture messaging
Voice Features
  • Voice dialing
  • Voice recorder
  • Integrated handsfree speaker
Browsing
  • Advanced XHTML browser
  • WAP 2.0 over GPRS data in both GSM and WCDMA modes
Video Services
  • Video clip download up to 1.4MB
  • 3GPP Streaming
  • Note: The streaming functionality in the Nokia 7600 phone is an operator dependent feature and requires network support.
Applications
  • Pre-installed Java™ based games and applications
  • Downloadable Java™ applications, maximum download size 348kB per application
Software
  • PC Suite for Nokia 7600 phone in sales package
  • Nokia Audio Manager for music file transfer from a compatible PC is included in PC suite for Nokia 7600 phone
Battery
  • BL-5C
Capacity
  • 850 mAh Li-Ion
Talk Time
  • Up to 1.8 - 2.9 hrs (WCDMA)
  • Up to 3.0 - 4.0 hrs (GSM)
Standby
  • Up to 7 - 12.5 days (GSM and WCDMA)
Απάντηση: ΝΟΚΙΑ 7600 - χαρίζεται
Γιάννη κράτα το, να μου το δώσεις το Σάββατο που θα είμαι στην Αθήνα.
PM
Γιάννη στείλε μου ένα μήνυμα με το κινητό σου δικό μου, αν το έχεις, γιατί το δικό σου κάπου το έχασα.
Ευχαριστώ.!
Τα είδα Μιχάλη αλλά δυστυχώς τζίφος... να βρεθούμε αυριο να σου επιστρέψω τα χρήματα και το κρατάς το κινητό και αν μπορεσεις εσύ να το ξεκλειδώσεις εχει καλώς.
Δεν βρήκα με τίποτε την απόδειξη αγοράς, απο την ΤΕΛΕΣΤΕΤ ήταν αγορασμένο απευθείας αλλά δεν μπορώ να βρώ κανένα παραστατικό (πάει καιρός)
Πάρε με τηλέφωνο αυριο να κατεβω να σου επιστρέψω τα χρήματα.
Νομίζω ότι αυτό είναι για να ξεκλειδώνεις την κάρτα και όχι για τον κωδικό του πληκτρολογίου.
Re: Απάντηση: ΝΟΚΙΑ 7600 - χαρίζεται
νομίζω είναι αυτό που θές Μιχάλη.
μπορείς να το δοκιμάσεις???
ΣΕ πήρα τηλέφωνο πριν 5 λεπτα
Γιάννη το έχω ξεχάσει στο αυτοκίνητο. Θα κάνω όμως δοκιμές.
Ευχαριστώ HV.
To ΙΜΕΙ είναι 351547000074901, για οποιον έχει όρεξη να κάνει δοκιμές. :)
HV
Ξερετε ποσο μαρεσει να βοηθαω τον κοσμο....Περα απο το να αρπαζομαι με μερικους :)
DCT4 Codes for IMEI: 351547000074901
Provider: 20210000
Greece, Telestet / TIM Greece
Type: 5
#pw+ 09 70 33 41 15 12 43 6 +1#
#pw+ 34 61 76 16 54 13 67 5 +2#
#pw+ 08 55 73 20 73 47 07 4 +3#
#pw+ 04 45 23 16 62 17 12 1 +4#
#pw+ 91 78 62 23 35 50 76 1 +5#
#pw+ 90 89 52 42 16 21 45 0 +6#
Provider: 20210000
Type: 7
#pw+ 33 85 76 35 46 47 57 7 +1#
#pw+ 85 60 71 27 24 62 07 1 +2#
#pw+ 81 40 11 53 72 12 71 3 +3#
#pw+ 03 52 33 45 23 74 53 6 +4#
#pw+ 19 62 14 51 04 24 41 4 +5#
αυτόν να βάλεις Μιχάλη λεει απο ολους τους κωδικες να βαλεις τον τελευταίο.
#pw+ 85 25 21 37 60 47 22 6 +6#
Now you have to enter the whole code on your phone
The code has the following format: , where the X's are numbers.
1 - Enter "#"
2 - Enter "*" three times to write "p"
3 - Enter "*" four times to write "w"
4 - Enter "*" twice to write "+"
5 - Enter the 15 numbers
6 - Enter "*" twice to write "+"
7 - Enter "7"
8 - Enter "#"
Your Nokia phone is now unlocked.
μμμμ η μόνη λύση είναι να μου το φέρεις Μιχάλη να το δούμε αν μπορεί φίλος να το ανοίξει. Αν και μου φαίνεται παράξενο να εχει κλειδώσει. Ισως να ηταν κλειδωμένο για TELESTET τοτε ΤΙΜ/WIND τωρα και να μην δέχεται cosmote π.χ.
Σορρυ για την ταλαιπωρία
HV
Μπορει να παρει τηλεφωνο την WIND η να παει απο εκει και να δει μηπως εχουν τον κωδικο.
Εγω μια φορα εχω ξεκλειδωσει κινητο με το εν λογο προγραμματακι.
Γιάννη την άλλη φορά που θα είμαι Αθήνα,θα στο φέρω για να το δεις.
Δεν πειράζει, συμβαίνουν αυτά. Πάντως, δεν νομίζω ότι είναι κλείδωμα δικτύου, αλλά κωδικός πληκτρολογίου.
οκ μιχάλη θα το φτιάξουμε , μίλησα με τον κουμπάρο μου που είναι στην WIND και θα το δεί και αυτός, μπορεί να βρεί το τιμολόγιο. Πότε θα ανέβεις πάλι??
Spiromag
