Το ακριβοτερο Blu Ray player
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Μαλιστα!
Το Goldmund Eidos 20 BD στοιχιζει ουτε λιγο, ουτε πολυ,
16.900$ !!!
Για να δουμε γιατι...
GOLDMUND INTRODUCES FIRST HIGH-END BLU-RAY PLAYER Priced at $16,900 The Eidos 20 BD Embodies Goldmund's Signature High-Tech Refinement Los Angeles, February 25, 2008: Goldmund, makers of the world's most extravagant and technologically advanced systems for audio-video purists, introduced today the company's first Blu-ray player, the Eidos 20 BD. With the announcement of the Eidos 20 BD, Goldmund becomes the first high-end audio/video manufacturer to issue a Blu-ray player. The Eidos 20 BD embodies the Goldmund high-tech refinement that has made the Swiss-based company a leader in the audiophile community for the last 30 years. Goldmund signature features found on the Eidos 20 BD include the "AC-Curator" power supply circuit which dramatically improves picture and sound stability and dynamics, and the "Mechanical Grounding" construction which removes from the player mechanism spurious vibrations blurring the video signal and increasing jitter. In addition, the new Eidos 20 BD uses the Goldmund "Magnetic Damper," a device lowering the reading errors, a feature that previously was exclusive to Goldmund's highest end devices. "As a result of last week's news in regards to the format wars, Goldmund decided to launch the Eidos 20 BD earlier than we had originally planned to capture the attention of the industry that believes in the superior technological merits of the Blu-ray format," said Michel Reverchon, president of Goldmund. "The Blu-ray player is the perfect addition to our Goldmund Media Room, which requires high-definition playback and is the pinnacle of technological excellence." Goldmund will begin taking orders for the Eidos 20 DB, which is priced at $16,900.
Καλες οικονομιες...
ειμαι περιεργος να δω αυτος που θα το αγορασει τι προτζεκτορ εχει! Παντως αν το σκεφτειτε μια hi-end εταιρεια δεν μπορει να βγαλει ενα player που να στοιχιζει 2000 πχ
με 1900 ευρω φτιαχνω ενα htpc
ονειρομηχανη και κανει καθε τετοιο κουτακι λιγο
για θεμα αναβαθμισεων δεν το συζηταμε
htpc
ολα τα αλλα απλα δεν.
Ακομα και το αρθρωτο ayre για να αναβαθμιστει θελει ενα σκασμο λεφτα
htpc
Πες τα Χρυσόστομε...
Απάντηση: Το ακριβοτερο Blu Ray player
Ε αφου έλυσαν το θεμα με τα φθηνα BDplayer για τους κοινούς θνητούς , ειπαν να βγαλουν κατι και για τους Hi-endαδες.
Λογικό μου φαίνεται…)(
Χαζομαρουλες. Βαζω στοιχημα πως ενα ps3 κοντράρει ανετα το παραπανω κονσερβοκουτι.
HV
Βασικα οποιος εχει 2-3 δικιες του εταιρεις , 2-3 κοτερα , Ιδιωτικο jet κτλ κτλ κτλ δεν νομιζω να κολησει να το παρει...Απο την αλλη με Blu-Ray θα ασχοληθει ? Αυτος θα εχει δικο του Village Park :)
Εγώ μιλούσα γι' αυτά με τις οθονίτσες των 500 - 600€!!:happy_9:
Πριν ένα μήνα πήρα το Origen με την 12" και έσκασα 1000€ αλλά άξιζε. Του έχω ένα πουσαρισμένο Core 2 Duo E6850 στα 3.6Ghz και κατάφερα και χώρεσα Ultra 120 Extreme cooler και πήρε και την 8800GTS (G92).
Άντε να δώ τι θα γίνει με τον HD ήχο στα PC....
  • rose.athens
makpag
