PROBLHMA-Samsung LE46M86B
tzo
Geia sas paidia
mia erotisi parakalw..gia th Samsung LE46M86B
tin exw parei prin 4 mines apo technixx thessaloniki
to provlima einai to eksis:
arketes fores mou kanei texnoyrgimata stin othoni ... san na einai magnitismos.molis tin anoigw SYMVAINEI AYTO KAI MONO!...(den exei on-off..kai menei st-bye 24 h)
arxika eipa pws einai apo to DEKTI-dreambox , alla telika itan apo tv
tiw prwtes fores evgaza to reyma kai epeze pali kanonika.
simera esvisa mono,APO REMOTE...kai anoiksa apla.. kai epanilthe.
An parameinei se ayto ..to problima de me enoxlei,apla mipws einai kapia zimia rwtaw..na mou dwsete ta fwta sas.
exw kai statheropioiti tasis gia tis 2 syskeyes pou einai ekei tv kai dreambox
ta texnoyrgimata einai kati...san polyxromes loyrides kathetes......den mporw alliws na to perigrapsw.pote de mou to exei paroysiasei enw pezei!
*apeythinthika sto servis kai moy eipan oti an den einai monimo to provlima de tha mporesoyn na to entopisoyn...
an kapiow filos mporei...as voithisei parakalw..mias kai einai akomi stin eggyisi!
eyxaristw prokatavolika
stelnw kai mia foto..pou evgala otan to ekane to mesimeri..
File mou tha se stenaxoriso ligo,os katoxos tis LE37M86 mou parousistike akribos to idio problima.to problima ofilotan sti motherboard tis tileorasis kai antikatastathike sta plesia tis eggiisis.Apo tote kai meta kanena problima
tzo
diladi apo oti katalava,to provlima einai sovaro,kai de prepei na to afisw!
profanws tha xeirotereyei oso paei...
pantws tha prospathisw na zitisw antikatastasi,oxi allagi antalaktikou,
stis prwtes eikosi meres,mou to eixe protokanaei...eleos!!!
eyxaristw gia tin apantisi
tzo
LE-46M86BDX/XEC
αυτο λεει πισω στη σφραγιδα της τv
http://www.samsung.com/gr/products/t...6m86bdxxec.asp
αλλα αυτη αγορασα ...και εγραφε πανω στο κουτι που παρελαβα.
Samsung LE46M86BD
http://www.technixx.gr/deeplink.jsp?...FTVfEgodcVMaCg
*Aλλο θεμα αυτο...αλλα τωρα ΤΟ ΕΙΔΑ.......
νομιζω αλλη tv μου εστειλαν.....
και δεν ξερω τελικα αν ειναι ,....FULL HD
Δωστε μου μια εξηγηση...παρακαλω
tzo
Το ταμπελακι πισω στη φωτογραφια..
δε μπορω να ξερω τι αγορασα ακριβως
διοτι τα περισσοτερα καταστηματα δε ξερουν να απαντησουν.
στη Samsung που ειχα ρωτησει πριν τη παρω..μου ειπαν υπευθυνα (οχι γραπτα) οτι ειναι foull HD.
Τωρα διαπιστωνω πως ειναι ready..
και εχει και το προβλημα με τις γραμμες...
Αν δε μου αλλαξουν συσκευη,δε θα δεχτω ανταλακτικα σερβις!
θα κινηθω δικαστικα!
Αγορα τιμολογιο 10/10/07
Αγαπητέ φίλε, δεν γνωρίζω για το πρόβλημά σου αλλά καλά έκανες και το δημοσίευσες, (πιθανόν να στέρησες ένα πελάτη από τη Samsung), μου φαίνεται πως οι εταιρίες λόγω ανταγωνισμού κάνουν ανεπαρκείς ελέγχους ποιότητας στα νέα μοντέλα, εκτός και αν ο τόπος προορισμού "Greece" εκτός από τις υψηλότερες τιμές που παρουσιάζει σε σχέση με τις μεγάλες ευρωπαϊκές χώρες είναι και αποδέκτης "βιαστικών" για να μη πω προβληματικών γραμμών παραγωγής. Ίσως πάλι να φταίει η αλματώδης αύξηση της ζήτησης των LCD (και στη χώρα μας) και τα εργοστάσια *κόβουν δρόμο* για να ανταπεξέλθουν και να μην τους πάρει την πίτα ο ανταγωνισμός.
Απάντηση: Re: PROBLHMA-Samsung LE46M86B
Κατ' αρχήν καλώς ήλθες στη παρέα μας! :happy_4:
Η BD είναι Full HD, η BDX όχι ... αλλά το πρόβλημα είναι άλλο.. γιατί σου έστειλαν άλλη TV???
To πρόβλημα είναι ΚΥΡΙΩΣ από το ηλεκτρ. κατάστημα που πήρε την TV... άλλο παρήγγειλε και πλήρωσε και άλλο του ήλθε...
έχεις δίκιο, όμως αυτή που του έστειλαν παρουσίασε πρόβλημα και δεν μου άρεσε καθόλου η απάντηση που πήρε από το service, ο πελάτης δεν είναι τρελός να θέλει να στερηθεί την καινούργια του τηλεόραση, έπρεπε να την πάρουν αμέσως για έλεγχο, επισκευή ή και άμεση αντικατάσταση. Είχα πρόσφατα προβλήματα με την τηλεόρασή μου και το service ήθελε σώνει ναι καλά να με πείσει ότι το πρόβλημα δεν ήταν πρόβλημα, τους παίρνεις τηλέφωνο και πρέπει να τους αποδείξεις ότι δεν είσαι ελέφαντας...
Τι να πω....:mad_2:
tzo
Re: Απάντηση: Re: PROBLHMA-Samsung LE46M86B
Ευχαριστω για το ενδιαφερων σας..
Τελικα ειναι οτι γραφει στο Model:......BD?
Η ειναι αυτο που γραφει πιο κατω Model Code:........BDX/ XEC ?
Απάντηση: Re: Απάντηση: Re: PROBLHMA-Samsung LE46M86B
Ό,τι γράφει η καρτέλα ΠΑΝΩ στην TV... μάλλον...:141:
kkoumas
