PS3 New Firmware 2.20 - Επιτέλους Υπότιτλοι σε DivX
H SONY φαίνεται έχει "φιλελληνικά αισθήματα" και έτσι ανήμερα της Εθνικής μας Γιορτής (25-3-2008) κυκλοφόρησε το πολυαναμενόμενο firmware 2.20 με αυτά που ζητούσαμε (μετά το ανούσιο firmware 2.17), μεταξύ των οποίων και υπότιτλους σε DivX και πολλά άλλα όπως φαίνεται πιο κάτω:
Find out what features are included in PS3 system software update 2.20.
An update to the PS3 system software was released on March 25, 2008. If you update your PS3 system, the system software version will be 2.20 and the following features will be updated. In order to download PS3 system software version 2.20, you will need a minimum 130Mb of free space on either the PS3 Hard Disk Drive (System Update) or on removable storage media (PC Update).
Main features in system software update version 2.20
  • BD-LIVE support
Blu-ray Disc Profile 2.0 (BD-LIVE) is now supported. Visit the BD-Live guide in Help & Support under PS3 > Video at eu.playstation.com for more details.
  • Copying playlists
You can now copy playlists that you create in Music and Photo to a PSP system. Visit the Copying playlists guide in Help & Support under PS3 > Getting started > Managing Files on PS3 at eu.playstation.com for more details.
Other new or revised features in version 2.20
Settings
  • The way you register Bluetooth devices has changed. Also, you can now manage your registered devices.
  • A [BD Internet Connection] setting has been added under [BD/DVD Settings].
  • An [Audio Output Device] setting has been added under [Remote Play Settings].
  • You can now display an image while editing a playlist.
Music
  • You can now play a music track while editing a playlist.
Video
  • You can now play DivX and WMV format files that are 2GB or larger.
    You can now display subtitles in DivX-format video files
  • You can now begin playing a DVD from the point where you previously stopped it (Resume Play).
  • A [Mosquito Noise Reduction] option has been added under [AV Settings] in the control panel for standard DVDs.
  • You can now play BD-R version 1.2 (LTH* BD-R) discs.
* LTH, or low to high, is a recording method that supports organic dye write-once BD-R media.
Network
  • You can now change some PS3 system settings during remote play.
  • [Save Target] has been added as an option under [File] in the browse mode menu of the Internet browser. This option lets you save a file that is linked from a Web page, such as an image or video file, or other type of file, to your PS3 system's hard drive or storage media.
  • The Internet browser now displays some Web pages more quickly.
  • Using the Internet browser, you can now play a linked video file* as it is being downloaded.
* Some types of video files cannot be viewed in this manner and must be downloaded completely before playback.
Note:
  • This system software update includes all features contained in previous versions.
  • The new system software will preserve any settings previously made to the PLAYSTATION 3. Depending on the software title, you may not be able to play without first updating the PS3 system software.
  • Do not perform updates using any data other than the official update data provided by Sony Computer Entertainment over a network or on disc media, and do not perform updates by methods other than those described in the product documentation or in this site. If an update is performed using data from another source, by another method, or with a PS3 system that has been altered or modified in any way, the PS3 system may not operate properly and may not be able to install the official update data. Any of these actions may void the PS3 system warranty and affect your ability to obtain warranty services and repair services from Sony Computer Entertainment.
ENJOY!:137:
Εκεινο το " subtitles for divx will be supported", δεν εχω καταλαβει ακομα ποια ειναι η εννοια που του δινουν εκει στη Sony...
Για μενα υποστηριξη θα λεγοταν αν διαβαζε τους υποτιτλους απο μονο του απο srt αρχειο. Ή αν εβγαζαν ενα δικο τους επισημο προγραμμα απο το οποιο επρεπε να τα περασεις...
Ενταξει δεν ειναι και καμια φοβερη δουλεια με εκεινο το προγραμματακι αλλα και το τελευταιο μαρκα με `καψες dvd player πλεον διαβαζει εξωτερικο srt file. Tι hardware εχουν αυτα και τι το PS3 !!!
H SONY, όπως ξέρεις, είναι μία από τις μεγαλύτερες κινηματογραφικές εταιρείες στο Hollywood, και το γεγονός ότι υποστηρίζει DivX/XviD με επίσημο firmware(από το 2.10 και μετά) για το PS3 είναι νομίζω μεγάλη υποχώρηση από μέρος της, αλλά κατάλαβε ότι για να μπει για καλά στην αγορά, δεν θα έπρεπε να δώσει ένα "κολοβό" all player.
Τώρα όσον αφορά τους υπότιτλους, εγκατέστησα χθές το νέο firmware 2.20, αλλά δεν είδα εξωτερικούς(.srt) υπότιτλους, ούτε από USB stick, ούτε από USB external HD, παρά μόνο ενσωματωμένους με το πρόγραμμα AVIAddXSubs από εδώ:
HTML:
http://www.calcitapp.com/AVIAddXSubs.php
και κάτι είναι και αυτό.
Για τους υποψήφιους αγοραστές του PS3 να αγοράσετε και το τηλεχειριστήριο του (~25-30€) που είναι και bluetooth, οπότε έχει και μεγαλύτερη κάλυψη από τα κοινά IR τηλεχειριστήρια και μπορεί να χρησιμοποιηθεί και σαν δεύτερο game controller.
bmavroeidis
