Τι καινουργιο υπαρχει στο Γεωγραφικο Πλατος 500
Tymphany LAT
Tymphany Linear Array Transducer (LAT)
The Tymphany Linear Array Transducer (LAT) is the first audio transducer to bring great bass to the new generation of consumer lifestyle products. Extremely scalable, the patented Tymphany LAT delivers a richer sound experience to places never before thought possible. With its new slim shape, no mechanical vibration, and sleek styling, the Tymphany LAT represents the first significant breakthrough in transducer technology since the inception of conventional audio transducers. How it Works
In a dramatic departure from conventional cone transducers that displace air across a single diaphragm, the Tymphany LAT displaces air using a linear array of multiple smaller diaphragms. The result is a more efficient transducer geometry for a given SPL. The balanced drive design is comprised of a series of coupled diaphragms that are driven by opposing end motors. One motor drives half of the diaphragms, while the other motor drives the other half in opposition. Sound radiates through multiple flow ports along the side of the housing. The transducer can be mounted either horizontally or vertically into much shallower and narrower boxes than conventional drivers. Features
  • Efficient Form Factor - The revolutionary Tymphany LAT brings bass where it could never go before as a result of its breakthrough design and sleek profile. For example, the Tymphany LAT 500 packs the power of two 10 subwoofers into a thin tube-shaped transducer only 5 wide, and the Tymphany LAT 700 offers the equivalent of two 12 subwoofers in a streamlined 7 width.
  • Vibration Free - The Tymphany LAT is vibration free, offering a bass sound with minimal or no artefacts. Unlike conventional cone-shaped transducers, the Tymphany LAT has been designed with opposing end motors that cancel out structural vibration, so the transducer does not shake and will not transmit structure-born vibrations to critical circuitry in consumer products. Having done away with mechanical vibration, the Tymphany LAT contributes to system stability, and eliminates the potential for rattle or buzz that vibration can cause in audio systems.
  • Design Differentiation - Because of its unique form factor and sleek appearance, the Tymphany LAT can be can be used to significantly differentiate and aesthetically enhance consumer products.
http://www.tymphany.com/lat50006001-08
Για πες μας με δικα σου λογια την δικη σου γνωμη Μιχαλη
Καινουργιο πραμα με ΠΟΛΥ ενδιαφεροντα χαρακτηριστικα, που δεν εχει ομως ακομη δοκιμαστει. Κατα τον κατασκευαστη αντικαθιστα δυο 10ιντσα γουφερ στις μισες διαστασεις. Συνδεεεται και σαν Dual Voice coil, που σημαινει οτι με ενα τετοιο δουλευεις δυο καναλια σε ενα Ηχειο, κλπ κλπ.
Τεραστια διαφορα τιμης καταλογου της εδω αντιπροσωπειας σε σχεση με μαγαζια της κεντρικης Ευρωπης.
Βεβαια δικαιολογειται να υπαρχει μια διαφορα αλλα εδω μιλαμε για κοντα στα διπλα.
Για οσους τυχον δεν γνωριζουν την TYMPHANY ειναι η Δανεζικη εταιρεια κατασκευης μεγαφωνων (πρωην DST) κατω απο την οποια συστεγαζονται Peerless - Scanspeak - Vifa (απο ενα σημειο και μετα Peerless V-line). Οι εταιρεια αυτη ειναι απο τις εκεινες που εξακολουθουν να πουλανε πρωτης ποιοτητας μεγαφωνα προς τους DIY και τους OEM κατασκευαστες, μετα την αποσυρση των AUDAX (αλλαξε αντικειμενο), FOCAL (φτιαχνει μονο ετοιμα Ηχεια σαν JM LABS), DYNAUDIO και αλλες.
Οσον αφορα τους Transducers LAT 250 - LAT 500 - LAT 700 εχουν ηδη κυκλοφορησει και περιμενουμε να δουμε σε τι μυστηριες εφαρμογες μπορει να χρησιμοποιηθουν απο τους διαφορους κατασκευαστες. Σε πρωτη φαση δεν θα ηταν ασχημη ιδεα ο συνδιασμος LAT με καποιο Ribbon σε ενα μακρυ και στενο Ηχειο.
Χαρακτηριστικα εδω
http://www.tymphany.com/categories/tymphany-lat/subwoofers
gperdik
