JVC D-ILA 8K4K (35Mpixel)
gkontoletas
trouble in my brain
World’s highest*
1 35 megapixel pixel count:
More than 17 times Full High-Definition
[FONT=Arial,Bold][FONT=Arial,Bold]JVC Develops 1.75-inch 8K4K D-ILA Device[/FONT][/FONT]
~ World's first*
1 single display device achieving Super Hi-Vision*2 (33 megapixels)~
Victor Company of Japan, Ltd. (JVC) announces a new addition to its lineup of proprietary
D-ILA (Direct-Drive Image Light Amplifier) high-definition reflective liquid crystal devices for
projectors. The newly developed 1.75-inch 8K4K D-ILA device has the world's largest number of
pixels*
1 and is able to display images of approximately 35 megapixels (8192 x 4320 pixels), the
equivalent of more than 17 times the level of Full High-Definition. This means that a single
display device can now produce Super Hi-Vision images and can display images with the highest
number of pixels currently defined under international standards.
*1 As a projection-type display device, as of May 2, 2008.
*2 Super Hi-Vision is a TV broadcasting service currently under development at NHK; a single image has
approximately 33 megapixels (7680 x 4320 pixels), with 60 frame/second sequential scanning and 22.2
multichannel sound. Image format is international standard ITU-R BT.1769, SMPTE 2036. Diagonal size is
1.67 inches at Super Hi-Vision standard pixel dimensions of 7680 x 4320.
After JVC developed the initial 7.86-megapixel (3840 x 2048 pixels) 4K2K D-ILA device in the
summer of 2003, it subsequently further evolved the technology for highly realistic, high-definition
images through a range of test viewings and verification testing, resulting in the development of
JVC’s first commercial 4K2K D-ILA device (1.7-inch device size, 5,000:1 device contrast ratio)
and the 4K2K D-ILA projector incorporating that device in September 2004.
In June 2007 JVC developed a 1.27-inch 4K2K D-ILA device that was the world's smallest
device of its kind, having a 6.8µm pixel pitch and 4096 x 2400 pixels, and in February 2008 it
began marketing a newly commercialized professional D-ILA projector, DLA-SH4K, incorporating
that device.
Through the development of a new production process and new pixel structure for even finer
pixels, JVC has now succeeded in developing the 1.75-inch 8K4K D-ILA device, the world's first
device to achieve real Super Hi-Vision definition level. The new device has approximately 50%
higher density in its ratio of area per pixel as compared to the 1.27-inch 4K2K D-ILA device,
which was originally the world's smallest 4K device. Furthermore, the new device has achieved a
video display of approximately 35 megapixels, the world's highest pixel counts*
1, while continuing
to provide the D-ILA series' characteristics such as “high-quality images without a distracting
pixel structure”, “high light availability”, and “high contrast ratio”.
Device size ...................................................1.75-inch diagonal​
No. of pixels (H x V) .......................................8192 x 4320 pixels
Pixel pitch .....................................................4.8µm
Gap between pixels ........................................0.24µm
Aperture ratio .................................................90% or higher
Device contrast ratio .......................................20,000:1
Response time (tr + tf) ....................................4.5ms
LC mode .......................................................Vertical Aligned LC
LC alignment film ...........................................Light stabilized inorganic alignment film
Ουάου, ένα τέτοιος προβολέας με ανάλυση 8000x4000 και περισσότερα από 32 εκατομμύρια πίξελς, όταν θα προβάλλει υλικό που είναι εξαρχής γραμμένο στην ίδια ανάλυση, θα έχει τέτοια αναλυτικότητα που θα είναι αντίστοιχη σχεδόν της ανθρώπινης όρασης!!! :111:
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
Σκεφτείτε μόνο ότι σε ένα τυπικό κάδρο 100 ιντσών, τα πίξελς θα έχουν πλάτος, ούτε λίγο ούτε πολύ, 0,25 χιλιοστά περίπου!!!!!!!!! :111: :111:
<o:p></o:p>
Τι σημαίνει αυτό;! Για να το συνειδητοποιήσετε, πάρτε μια μεζούρα και παρατηρήστε τις μαύρες κάθετες γραμμές που οριοθετούν τα χιλιοστά. Ε λοιπόν, τα πίξελς ενός τέτοιου προβολέα σε ένα κάδρο 100 ιντσών, θα έχουν το ίδιο ή ελάχιστα μεγαλύτερο πλάτος με αυτές τις γραμμές!!! :111: :111: :111:
<o:p></o:p>
Ή για να κουφαθείτε ακόμα περισσότερο, σε έναν τέτοιο προβολέα ανάλυσης 8000x4000, τα πίξελς θα έχουν το ίδιο περίπου πλάτος με τις οριζόντιες και κάθετες γραμμές, το κενό δηλαδή ανάμεσα στα καθρεφτάκια σε έναν μονότσιπο DLP 720p προβολέα!!! :111: :111: :111: :111:
<o:p></o:p>
Για τα κενά ανάμεσα στα πίξελς σε έναν τέτοιο προβολέα φυσικά δεν γίνεται καν λόγος!!! Δεν θα μπορείτε να τα διακρίνετε ακόμα κι αν κολλήσετε τη μούρη σας στην οθόνη, αμφιβάλλω αν θα μπορείτε να τα δείτε και με τη χρήση μεγεθυντικού φακού!!! :111: :111: :111: :111: :111:
<o:p></o:p>
Ουάου, προσπαθώ να φανταστώ τις εκφράσεις του Κεφάλα καθώς θα προσπαθεί να διακρίνει τη δομή του πάνελ σε έναν τέτοιο προβολέα και κατουριέμαι από τα γέλια!!! :142: :142: :142:
Απάντηση: Re: JVC D-ILA 8K4K (35Mpixel)
<o:p></o:p>
Ωραιες αναλυσεις αυτες ....!!!!!
Απο οτι βλεπω υπαρχει και μειωση στα κενα αν δεν κανω λαθος..
Θελει λιγο ακομα μειωση για καλο αποτελεσμα...
Η στοιχειοποιηση ειναι εμφανη ακομα στους 1080 απο θεση θεασεις σε 100"ιντσες οθονη....
Εαν μπορεσουν να εχουν την διπλασια αναλυση του 1080 με το ιδιο μεγεθος τσιπακι καλο ειναι.....νομιζω οτι θα ειναι πολυ καλο το αποτελεσμα ετσι για τις ιντσες που παιζουμε στα σπιτια μας...
Παναγιωτη ειναι λαθος να προσπαθεις να δεις κατι......το προβλημα πρεπει να βγαινει αβιαστα και να το βλεπεις.....μονο τοτε εχει νοημα....
Και πόσες δραχμές κάνει αυτό το μαραφέτι?????
Όσες τα pixels του?????:139::139:
εεεεεεεεεεε το έχουν ξεφτυλίσει!! Αλλά οκ μέχρι να έρθουν αυτά τα πράγματα σπίτι μας θα έχω γεράσει.
Αντε να δω πότε θα καταφέρω να πάρω προβόλι γιατί ακόμη είμαι στις γυψοσανίδες του δίπλα τοίχου από την οθόνη που ΘΑ!! αγοράσω. Ισως μέχρι τότε να έχει πέσει ο HD100 στις 3.500 τώρα που βγήκε και αυτό! (Μπαααααα).
ΛΕΥΤΕΡΗΣ ΚΟΥΚΟΥΡΑΚΗΣ
απο-Συντονιστής
Τα 1080 ειναι υπεραρκετα για οθονες μεχρι και 200" παιδια... Το μονο που χρειαζεται τωρα ειναι καλο υλικο και περισσοτερα fps. Οι προβολεις αυτοι θα εχουν εφαρμογη μονο σε μεγαλους κινηματογραφους και ΙΜΑΧ οθονες...
Απάντηση: JVC D-ILA 8K4K (35Mpixel)
Γενικά τους D-ILA τους γουστάρω τρελά!
Αλλά στην περίπτωσή μας μου κάνει εντύπωση ότι το κάδρο αλλάζει πάλι αναλογία (ξεφεύγει από το 1.777 και πάει στο 1.896).
Και βεβαίως η ανάλυση αυτή θεωρώ ότι στα σπίτια μας (αποστάσεις θέασης 3 ως 5 ή 6 μέτρα) ξεπερνά κατά πολύ την ικανότητα των ματιών μας.
Ακόμα και σε "ανοικτό παράθυρο" δεν θα μπορούσαμε να δούμε τόσο "τέλεια".......
Δε θέλω από την άλλη, να σκέφτομαι πως από τα 2Mp θα ανέβουμε στα 35Μp!!! Τρομάζω στην ιδέα της έλευσης του νέου σούπερ ντούπερ Ultra HD Super Blu-Ray disc με χωρητικότητα 3ΤB που θα είναι απαραίτητη ως χωρητικότητα για να χωρέσει την υπερπληροφόρηση των 35Mp!!!
Και δεν θα ξεχάσουμε βεβαίως και τις HDMI 2.8 γιατί οι 1.3-1.4-1.5-1.6-1.7-1.8 δεν μπορούν να περάσουν τέτοιο όγκο πληροφορίας.....
Ούτε τα νέα Super HD format ήχου με 25κάναλη πληροφορία και απαραίτητη προϋπόθεση νέους ενισχυτές και players (PS4???)
Αυτά είναι!!!! :101:
NIX
Το 1080 ειναι αψογο αλλα κατι εντος μου λεει οτι το διπλασιο θα ηταν ακομα καλυτερο.
Υποθεσεις κανω.
Δεν μπορω καν να φανταστω τα 35mp αλλα υποθετω οτι ειναι overkill για κινουμενη εικονα.
Σιγουρα ομως δεν τολμαω να βγαλω συμπερασματα για το διακενο,αυτο μονο ο Κεφαλας μπορει να το κανει.Βεβαια το λαγο απο το καπελο δεν τον εβγαλε,οποτε...
(Κωστα,ειναι φιλικη μπιχτη αλλα η αληθεια ειναι οτι μ`εσκασες και μ`εστειλες.Ουτε ο Καλχας να ησουν!)
DAMBO
