Dreambox DM800 PVR - Παρουσίαση
- 300 MHz MIPS Processor
- Linux Operating System
- OLED - Display
- MPEG-2 / H.264 Hardware decoding
- Tuner: DVB-S, optional: DVB-C, DVB-T
- Tuner Module, Plug&Play
- 1 x Smartcard-Reader
- V.24/RS232 Interface
- 10/100Mbit Ethernet Interface
- 1 x Scart (RGB, FBAS or S-Video)
- DVI
- 2 x USB 2.0
- analog modem
- S/PDIF Interface for digital bit stream out (AC-3)
- 64 MByte Flash, 256 MByte RAM
- SATA
- for use either as internal SATA HDD 2,5“
- or to use for extern eSATA
- unlimited channel lists for TV/Radio
- channel-change time < 1 second
- automatic service scan
- directly bouquet-lists
- EPG (electronic program guide)
- multiple LNB-Switching control (supports DiSEqC)
- OSD in many languages and skin-support
- Videotext Decoder
- extern 12V power supply
DreamBox DM800 technical data
DBS-Tuner mit DVB-S2:
Frequency Range 950 .... 2150 MHz
Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
DVB-S2: 10 – 31 Mbaud/s (8PSK) , 10 –30 Mbaud/s (QPSK)
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible, H.246
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical, Toslink
Ausgang Video:
Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video
Serielle Interface RS 232:
Typ RS232 bidirectional
Bitrate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
Analoge modem:
analoge modem for Internet connection
SATA Interface:
- for use either as internal HDD 2,5“ or eSATAor internal 2,5" HDD
USB
2 x USB 2.0 Host
LNB power and polarisation per tuner:
LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
Count of active satellite position:
DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power consumption:
< 15W at 12V
External PSU
Input:
110-240V AC / 50-60Hz / 0,6A
Output:
12V = / 3,0A
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 195 mm x 140 mm x 40 mm
Weight: 1,8 kg without HDD
http://www.dream-multimedia-tv.de/english/products_dm800_technical.php
Απάντηση: Dreambox DM800 PVR - Παρουσίαση
Πιο σωστός τίτλος θα ήταν "παρουσίαση των χαρακτηριστικών του κάθε δέκτη".
lakiss51
Η παραθεση των χαρακτηριστικων μονο δεν προσφερει τιποτα-ή ελαχιστα.Εντυπωσεις και γνωμη αξιολογησης θελουμε
Eγω τον εχω εδω κι ενα μηνα περιπου.
Του εχω βαλει κι ενα εσωτερικο σκληρο sata 250gb.
Ο δεκτης εχει 2 σημαντικα προβληματα.
Πρωτον υπερθερμαινεται αρκετα, με αποτελεσμα να κολλαει αρκετα (παρα πολυ ειδικα τωρα το καλοκαιρι) κι ετσι αναγκαστηκα να του βαλω 2 εξωτερικους ανεμιστηρες (απο ενα usb stand για φορητο).
Δυτερον κατι τρεχει με τον δεκτη και πολλες φορες αρνειται να κανει boot , αν δεν τον αφησεις αρκετη ωρα εκτος ρευματος.
Εκτος αυτων φυσικα, ειναι ενας γνωστος dreambox, εχει μερικα καλα images (gemini, pli , nabilo), κανει γρηγορο ζαπινγκ, ευχρηστος και κομψος.
Στα high defonition καναλια εχει πολυ καλη εικονα, αλλα στα sd θα μπορουσε να ειναι και καλυτερος.
Ενα ακομη μειον του ειναι οτι καταναλωνει πολυ ρευμα , ακομη και stand by , γι αυτο πρεπει να τον βγαζεις συνεχως απο την πριζα!!!
Klipschlascala_pro1988
