2.35 και ξερο ψωμι:126:
Αυτο που μας λεει το παραπανω quote ειναι οτι ο σκηνοθετης το γυρισε σε 1,85 με κεντραρισμα ομως των δρωμενων σε 1,33.Inexplicably, in the Director Notes on the DVD[2] for The Interpreter, Sidney Pollack states that he filmed Out of Africa and subsequent films of that decade in "4 to 3" "pan and scan"; and that it "...probably was one I should have had in widescreen". This aspect ratio of 4:3 conflicts with movie-audience common sense, and IMDB states that the aspect is 1.85:1, which equals 16:9.[3] Perhaps he meant he panned and scanned through a director's aperture of 4:3 using 16:9 camera and film, as he is discussing the influence of television's square screen on cinema of the 1980s and 1990s. In these director's notes, Mr. Pollack states that prior to Out of Africa (1985), he shot exclusively in "widescreen" and did not resume the wide format until The Interpreter in 2005.
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 10"><meta name="Originator" content="Microsoft Word 10"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5C0EEF%7E1%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:595.3pt 841.9pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Κανονικός πίνακας"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> Μην μας ρίχνεις ….Την τελευταια και μονη φορα που εμεις προσπαθησαμε να ασκησουμε πιεση μαζευτηκαν 20000 υπογραφες στο petition για ελληνικους υποτιτλους στο HD-DVD και φυσικα κανενα αποτελεσμα..
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 10"><meta name="Originator" content="Microsoft Word 10"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5C0EEF%7E1%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:595.3pt 841.9pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Κανονικός πίνακας"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> Αυτο που το διάβασες ;Το 235/1 λοιπον σαν καδρο.....σου προσφερει την ποιο κοντινη αποσταση θεασεις χωρις να χανεις εικονα και να ειναι ταυτοχρονα ξεκουραστο.....αρα εχεις την μεγαλυτερη εικονα που μπορεις να εχεις στο σπιτι σου.....
Φανταστητε οτι περιπου οι 92" σε 16/9 να γινοντουσαν + 30% παραπανω σε ιντσες απο την ιδια αποσταση θεασεις και χωρις να ενοχλουν .....!!!!!!!!
καλο απογευμα........
Σιγα να μην καθομαι να διαβαζω....!!!!!<META content=Word.Document name=ProgId><META content="Microsoft Word 10" name=Generator><META content="Microsoft Word 10" name=Originator><LINK href="file:///C:%5CDOCUME%7E1%5C0EEF%7E1%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml" rel=File-List><STYLE> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:595.3pt 841.9pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </STYLE>
Αρχικό μήνυμα απο kostas kefalas
Το 235/1 λοιπον σαν καδρο.....σου προσφερει την ποιο κοντινη αποσταση θεασεις χωρις να χανεις εικονα και να ειναι ταυτοχρονα ξεκουραστο.....αρα εχεις την μεγαλυτερη εικονα που μπορεις να εχεις στο σπιτι σου.....Αυτο που το διάβασες ;
Υπάρχει καποιο λινκ;<?xml:namespace prefix = o /><o></o
Εδω δεν εχουμε χρονο για........
Απο το μυαλο μου το εβγαλα βρε...!!!!
Το 235/1 χρειαζεται αλλη αποσταση θεασης.....
π.χ. Για 2 μ πλατος οθονης αναλογα το καδρο 4/3-16/9-235/1 χρειαζεται αλλη αποσταση θεασης για σωστη παρακολουθηση.....Και οταν μιλαμε για σωστη παρακολουθηση εννοουμε ξεκουραστη και να μπορουμε να αντιλαμβανομαστε ολη την εικονα ανετα......
Το ξερω οτι περι ορεξεως κολοκυθοπητα.....αλλα πρεπει να λεμε και το ιδανικο....
Συμφωνα με αυτη τη θεωρια, που το πλατος μας ενοχλει κι οχι το υψος, μακαρι ολες οι ταινιες να ητανε 4:3 δηλαδη, για να ειχαμε και μεγαλυτερη εικονα.:135:Επειδή ξερω πως εισαι λάτρεις της μακρινής απόστασης θεασης ετσι ώστε να μην χρειάζεται να γυρίζεις αριστερά και δεξιά το κεφάλι σου σαν να βλέπεις αγώνα τένις θα σου παραθέσω το παρακάτω σχεδιο και θα μου πεις αν ισχύει η όχι..
Πες λοιπόν πως χουμε μια οθόνη 16:9 με δυο μετρα πλάτος και είμαστε πολύ ικανοποιημένη με το μέγεθος της οθόνης από απόσταση θέασης 3,5 μετρα…
Σχ.1<o></o
Το οπτικό μας πεδιο σε αυτή την οθόνη και χωρίς να ταλαιπωρούμαι το σβέρκο μας καλύπτει τις πλαϊνές πλευρές του κάδρου και συνεπώς εχουμε μπροστα μας μια ολοκληρωμένη εικόνα…
Ας φανταστούμε τωρα πως από την ιδια απόσταση θελουμε να βάλουμε μια οθονη 2:35 χωρίς όμως να χρειαστεί να μειώσουμε το υψος της οθόνης αφου από την απόσταση μου είμαστε τα 3,5 μετρα μας καλύπτουν πλήρως και δεν μας κουράζουν..
Μοιραία λοιπον όταν βάλουμε αυτή την οθονη παρατηρούμε το εξής προβλημα…<o></o
Σχ.2<o></o
<o></o
Επειδή πλέον το οτπικο πεδίο μας δεν μπορει να κλειδώσει τα πλαϊνά της οθονης θα πρέπει όχι μονο να μην πλησιάσουμε πιο κοντα , αλλα να απομακρυνθούμε ώστε να μπουν και οι πλαϊνές πλευρες του κάδρου στο οπτικο μας πεδίο…
Αυτό όμως εχει ως συνέπεια να απομακρυνθούμε αρκετά από το κέντρο της οθονης που σημειωτέον μεχρι εκεινη την στιγμή σε καδρο 16:9 μας φαινόταν υπεροχη και χορταστική . Σχ.3
Δεν γινετε και η πιτα ολόκληρη και ο σκύλος χορτάτος…
