Διχως λαμπα
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Chilin Technology Introduces the World’s 1st Lamp Free 1080p Projector with Liquid Cooling Technology at CEDIA EXPO 2008.
For Release 2 p.m. MDT
Sept. 3, 2008
Taiwan OEM/ODM supplier sets to impress the custom home theater channel.
Taiwan -- September 3rd, 2008 -- Chilin Technology, a leading ODM/OEM manufacturer and supplier of high end home theater projectors is pleased to announce the first liquid cooling LED light source home theater projector. In partnership with Luminus Devices and Texas Instruments, this projector features Luminus PhlatLight LED in place of a conventional UHP lamp, as well as the latest Texas Instrument 1080p (1920x1080) DMD technology. In order to optimize the performance of this new light source, the projector requires a thermal management system that breaks with tradition. To this end, Chilin introduces the1st Lamp Free Full HD Home Theater Projector with liquid cooling into the market.
With 600 ANSI lumen and >100,000:1 Contrast Ratio, Chilin delivers an unbelievable 128% NTSC color gamut, which is 80% greater than that achieved through conventional UHP projectors. Integrated with Chilin’s tradition of superior optics and color management performance, the picture quality and color performance is simply unbelievable.
“ Building on our 44-year heritage of superior technical capabilities, we at Chilin are very enthusiastic about the harmony of artistry and technology that we have achieved with our new LED based projector, “said Alex Wang, senior product manager of Chilin Technology. “Though we may be a newcomer as a Taiwan OEM/ODM supplier in the custom home theater arena, we are focused on delivering ultra high end projectors that provide our customers superior color management, picture quality and thermal management systems.”
The secret to building high quality, superior performance and longer lifetime LED based projectors is an advance thermal management system. Chilin engineers designed its liquid cooling technology to assure the optimized performance of LEDs over time. Chilin’s unique cooling technology dissipates heat directly from the Phlat Light LEDs which is operated at a high electric current of 30A, hundreds of heat density higher than current common LED application.
Chilin has designed an efficient cooling technology to assure LED reliability. Chilin’s liquid cooling technology dissipates heat directly by water to keep the PhlatLight LEDs junction at a consistent, low temperature assuring unmatched reliability of Luminus’ LED. This technology truly enables the concept of “no lamp replacement”. Chilin expects to achieve up to 50,000 hours under its liquid cooling technology.
”Chilin Technology is very pleased to announce our successful joint development of using TI’s DLP Technology and Luminus’s Phlat Light LEDs to achieve superior product performance and image quality,” noted Wang.
Most notable, the no shattering, no lamp replacement, HD DLP home theater projector will be demonstrated at CEDIA EXPO 2008 in a private suite located on the 10th Floor, Room # 1014 of the Hilton Garden Inn, 1400 Welton Street, Denver, Colorado. The Chilin suite will be accessible from September 3rd-6th, where Chilin will be showcasing their entire series of DLP based 1080P projectors for existing and future OEM/ODM partners.
Please contact Gina Wu or Alex Wang to schedule a technology preview of Chilin’s product technology at CEDIA EXPO 2008. For more information - www.Chilintech.com.tw
About Chilin TeCHNOLOGY
Chilin Technology was founded in 1964, a subsidiary of the Chi-Mei Group. Chilin Technology has been playing an important role of managing color performance in plastic raw materials for over 40 years. In 2000, Chilin entered the display industry via Flat Panel Display material, LCD Flat Panel Display systems and Projection Display. Chilin is uniquely positioned because of its vertical integrated scope and strength in component supply chain management. Chilin offers “one stop shop” service to companies seeking superior value and performance in their OEM partner.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
50.000 ωρες?
Ο προβολεας αυτος της ταιβανεζικης Chi Lin ειναι(βεβαιως) DLP,
στα 1080ρ και o LED φωτισμος του κραταει...50.000 ωρες η 5,7 χρονια
συνεχους λειτουργειας.
Φωτεινοτητα 600 lumens και αντιθεση...100,000:1 :111:
αυτα τα εξωπραγματικα νουμερα κοντραστ παντως σημαινουν αριστο ον -οφ μαυρο.Δεν ειναι δυνατον να βγαλεις αλλιως τετοια νουμερα.Τα led μαλλον πρεπει να σβηνουν για να δειξουν μαυρο πατερνακι.
Απ'οτι φαινεται τα ledακια μαλλον θα αυξομοωνουν το φως τους,το οποιο δημιουργει μια σημαντικη παραμετρο που δεν υπηρχε στις λαμπες που ειχαμε ως τωρα.
Απάντηση: Re: Διχως λαμπα
Από το στόμα σου... και στων led το αυτί!... :116:
Απάντηση: Διχως λαμπα
ωραια πραγματα...Αλλα αυτος ο προβολεας ειναι σαν να μην πω..λες και ελεις να βαλεις στο ταβανι μια 40crt ..γομαρι..Θα πεσει το ταβανι..Να φανταστω επεισης πως θερμοκρασια ελαχιστη και τελος τα βουρ;;;;:107:
Με πηγή φωτισμού τα LED (που δεν έχουν τα προβλήματα καταπόνησης από ON - OFF και αυξομειώσεις όπως οι "συμβατικές" λάμπες των σημερινών προβολέων) και με οδήγηση PWM θα δούμε τρομερά contrast ratio αλλά και φοβερή ποιότητα εικόνας. Αφήστε που μπορεί εδώ να καταργηθεί ο τροχός!!!! διότι στο ημιαγωγό LED μπορούμε να επέμβουμε κατά την κατασκευή και να του δώσουμε το φάσμα του φωτός που θέλουμε να εκπέμψουμε οπότε μπορούμε να ορίσουμε 3 πηγές φωτός RGB με αποτέλεσμα και σε LCD αλλά και DLP ένα πάνελ και καθόλου τροχός αντίστοιχα ή αργότερα (στο μέλλον με την ακόμη περισσότερη βελτιστοποίηση της απόδοσης και ψήξεως των LED) να χρησιμοποιούνται τρίχρωμα LED! (πιο μικροί προβολείς).
Γενικά έχει πολύ ψωμί η υπόθεση και πολύ δρόμο ακόμη αλλά όταν το διαβούμε θα έχουμε πλέον σχεδόν όλοι προβολείς στο σπίτι πέραν από τις LCD - PLASMA οθόνες μας και θα δουλεύει για να βλέπουμε ακόμη και τις διαφημίσεις (όσπου να καούν τα LED θα τον έχουμε πετάξει).
Ακόμα και το παραπάνω μοσχαράκι το αγόραζα χαλαρά.......
Άντε να ξεκινήσει να δουλεύει, να βγουν πολλά μηχανάκια για να πάμε να αγοράσουμε!!
Μακάρι στα επόμενα 3 χρόνια να είναι εδώ, σε κανονικές τιμές!
DAMBO
