OPPO BDP S83 Blu-ray Player (Profile 2.0)
The folks over at AVSForum have spotted the Oppo BDP S83 Blu-ray Disc player, the first such player from the now famous DVD Player manufacturer.
Well known for their line of upscaling DVD players, the company spent much of the format war pushing their players as a "alternative" to a high definition player.
Now fully convinced that Blu-ray is the future, Oppo is offering this BD-Live player with 7.1 analog outs and promise support for all audio codecs when it launches. No other information is known at this time.
http://www.blu-ray.com/news/?id=1751
Ομολογω οτι με πιασατε στον υπνο του σαββατου....:137:.
Παντως το ειχαν τοσο μυστικο, που ακομα και σε μας δεν ειχαν πει κουβεντα......
Οταν εχω νεοτερα θα τα πουμε....
Νεοτερα απο το ιντερνετ...
  • Product Name: BDP-83
  • Manufacturer: Oppo Digital
  • Review Date: September 06, 2008
  • MSRP: $TBD
  • DVDO processing chipset (VRS by Anchor Bay)
  • 7.1 analogue outputs
  • HDMI 1.3 (with support for native decoding for DTS HD and Dolby Digital Plus/TrueHD)
  • Upconversion of DVDs to 1080p
  • 1080/24p output
  • BD Live 2.0 support (via 10/100 Mbps Ethernet)
  • USB connectivity
  • Dedicated analogue stereo outputs
  • IR control in/out connections ("for Oppo approved connections only")
  • SACD & HDCD support
  • Coaxial & S/PDIF outputs
Last year Oppo discretely showed off a prototype of its DV-983H flagship universal DVD player at the DVDO booth. This year they didn't disappoint. Unannounced, we got wind of a non-functioning prototype Blu-ray player that was sitting at DVDO's CEDIA booth. What's this? An Oppo Blu-ray player? Could this be the holy grail so many were hoping and waiting for? Apparently yes - though Oppo was not releasing information about availability or pricing as of yet.
Here's what we do know :
The unit will have the same DVDO processing chipset as found in the new DVDO Edge (VRS by Anchor Bay). It will have 7.1 analogue outputs, HDMI 1.3 (with support for native decoding for DTS HD and Dolby Digital Plus/TrueHD), and will upscale DVDs to 1080p. It even supports 24p output.Based on the chassis markings, BD Live 2.0 support (via 10/100 Mbps Ethernet) is included out of the box and USB connectivity is provided for photos and music playback. Dedicated analogue stereo outputs are also present and the unit has IR control in/out connections ("for Oppo approved connections only"). No RS-232C control is present. Perhaps most surprising (in a pleasant way) is SACD support as well as compatibility with HDCD's. Coaxial & S/PDIF outputs are present for legacy audio, including Dolby Digital and DTS.
While Oppo isn't releasing any pricing information we can't imagine this unit being competitive unless it is priced at $499 or less given the competition on the market from such companies as Sony, LG, Panasonic and others.
Και γω γυρω στα 500 ευρω τη βλεπω τη τιμη αφου το 983 εχει 400, σιγουρα το bluray θα εχει παραπανω.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Ρε συ Μητσο, τι το θελαμε και το ξεκινησαμε το θεμα?
Βρηκε βημα τωρα ο...αραψ(πως λεμε πριγκηψ?):142:
Αντρεα μου και Μητσο μου.....
Οτι και να αρχισουμε να λεμε, το 2008 θα βγει με ησυχια και κατα το πασχα του 2009 θα γινει η κουβεντα θερμοτερη.
Δυστυχως ολοι οι μαγκες με τις νεες τεχνολογιες κατεβηκαν στην εκθεση με '' non working models ".
Μ αλλα λογια, να σας αναψουμε φιτιλιες και να δουμε πως παει το πραμα.
Εκτος απο τις μεγαλες consumer-αδικες εταιριες ολοι οι αλλοι θα κυκλοφορησουν τα νεα προιοντα τους απο την ανοιξη του 2009.
Προς το παρον αμπελοφιλοσοφια και υπομονη.....
Αυτο που με καιει να μαθω ειναι τι chipset θα φοραει το oppo, εκτος απο το VRS της Anchor Bay. Η διαφορα εκει θα φανει.
Παρεπιπτωντως , η Oppo δεν ειχε δικο της περιπτερο, αλλα το player βρισκοταν στο περιπτερο της Anchor Bay.
Σε λιγο καιρο θα μαθουμε περισσοτερα απο τους beta-testers στο αμερικανικο φορουμ.
Οσο για τον Ελληνα beta-tester, μονο thanks ξερουν να γραφουν σε ολους οσους συμετειχαν στη βελτιωση των firmware.....
Απάντηση: OPPO BDP S83 Blu-ray Player (Profile 2.0)
Τόλη, υπάρχει ένδειξη τιμή για το εργαλείο?
Δέχομαι και πμ αν είναι...μυστικό!!
Re: Απάντηση: OPPO BDP S83 Blu-ray Player (Profile 2.0)
Ειδες τι παθαινεις οταν πλακωνεστε με τον cinemusic ?? :137:
Δεν βλεπεις μετα !!!!
Δεν ειδες που το λεει το αρθρο ?? Το εγραψε και ο τολης οτι εκτιμα οτι θα ειναι γυρω στα 500 Ε.
Απάντηση: Re: Απάντηση: OPPO BDP S83 Blu-ray Player (Profile 2.0)
χαχαχα.....
Και πως θα περάσει η ώρα βρε Μήτσο μ'??
Και πως θα μεγαλώνουν τα threads για να χαίρεται ο...Νώε?? :138:
Χωρίς πλάκα δεν το είχα δει καθόλου!!!!!:111:
Μάλλον φταίει ότι ακολουθούσε το αγγλικό κείμενο και δεν το πρόσεξα.....
Thanks φίλε!! :107:
MAD
Σιαρτάκιας
Πάντα αναρωτιόμουν ο Νώε έχει (ώχ! συγνώμη) είχε,άσπρα μαλλιά? :142:
Λοιπον........
Μας πιασανε ολους, μα ολους αδιαβαστους....
Ουτε οι Αμερικανοι beta-testers ηξεραν τιποτα.
Πολυ απλα γιατι αυτο που βλεπετε στις φωτο ειναι το προτοτυπο.
Το ανακαλειψαν καποια μελη του Αμερικανικου φορουμ στο περιπτερο της Anchor Bay και φυσικα διαδοθηκε σε λιγα λεπτα.
Αυτο που φαινεται εκ πρωτης οψεως ειναι το το νεο Oppo θα ειναι το πρωτο universal bluray player. Στην Αμερικη υπαρχουν παρα πολλοι φαν του SACD, DVD-A. Προφανως επισης θα ειναι και το πρωτο bluray που θα κανει καλο upscaling στα DVD, πραγμα που δεν πετυχαινει κανενα μεχρι στιγμης.
Στο πισω μερος του, διακρινονται και δυο RCA, που δεν ειχαν τα προηγουμενα μοντελα. Προφανως θα ακολουθησουν το συστημα Audio only, οπως στα 980/983, που κλεινει τα κυκλωματα εικονας και το κανει ενα καθαροαιμο audio player ( για αυτους που λενε οτι τα κυκλωματα εικονας βαζουν θορυβο στον ηχο ).
Φαινεται λοιπον οτι θα εχουμε και audiophile ηχο .
Δυο ειναι τα νεα που περιμενουμε.
Πρωτο ειναι το chipset οπως ειπα και παραπανω. Αν η Mediatek εκανε το θαυμα της, θα εχουμε εκπληξεις στη ποιοτητα εικονας.
Δευτερο και σπουδαιοτερο ειναι η τιμη.
Γιαννη μου δεν υπαρχει μυστικο γιατι δεν υπαρχει τιμη.
Καποιοι λενε για 499$, καποιοι για 699$.
Αυτη τη στιγμη τα νεα player παιζουν απο 750$ και πανω.
Αν με το καινουργιο χρονο πεσουν οι τιμες οπως λεγεται, τοτε θα ξερουμε.
Τοτε λεγεται οτι θα εμφανιστουν και τα κινεζικα, τα οποια καλα τα ελεγα σε προηγουμενο τοπικ, τελικα ηταν μουφα η επιδειξη τους στην εκθεση στη Κινα. Κανενα δεν εμφανιστηκε ποτε, ουτε πωλειται πουθενα.
Σαν πληρως ευχαριστημενος απο το 981 ... ελπίζω η ΟΡΡΟ να κανει την υπερβαση και να ριξει στην αγορα
ενα άριστο BD-Player... που να κανει και αριστο upscaling στα DVD... Αναμενουμε λοιπόν τις αρχες του 2009
και ελπιζουμε σε μια καλη τιμη...
Αληθεια απο profile τι θα ειναι...? η δεν το ειδα...?
Απόστολε ριξε ενα μνμ στα καρντασια της USA να στειλουν σε καλη τιμη... γιατι ... πες τους ...εχεις κατα παλαβους εδω
που θα τους δειρουνε..:137::138:...:135:
Απάντηση: Re: OPPO BDP S83 Blu-ray Player (Profile 2.0)
Λοιπον........
Το πρωτότυπο μου αρέσει. Κομψό, φαίνεται σα γυαλισμένο αλουμίνιο η πρόσοψη. Και μαύρο.......
Μου έχει κάνει εντύπωση που τα περισσότερα BluRay players είναι μαύρα! Επιστροφή στα παλιά.....
Ωραία χαρακτηριστικά. Τα κάνει όλα και συμφέρει!
Το Πάσχα κάποιοι θα σουβλίζουν και κάποιοι θα σουβλίζουν σε HiDef :107:
Τι ακριβώς περιμένουμε από το chip Αποστόλη?
Πχ άριστο upscale στα DVD? Κανένα περίεργο progressive scan? Κάποιο διαφορετικό fps για βελτίωση της κίνησης?
Ξέρουμε κάτι, ή απλά υπολογίζουμε άριστη εικόνα?
Ευχαριστώ για την πληροφορία Τόλη!!
Ίσως να βγάλουν 2 εκδόσεις με διαφορετικό εξοπλισμό.
Θα ήταν έξυπνη κίνηση από την Oppo.
Πχ ένα player χωρίς SACD & DVD-A και το κύκλωμα Audio only σε χαμηλή τιμή (στα 400€ πχ) και ένα με όλα τα παραπάνω (στα 600€)
Ας ελπίσουμε να μην εκτοξευθεί το $ μέχρι τότε και οι τιμές ανέβουν ψηλότερα....
Δημήτρη, απ' ό,τι είδα θα είναι profile 2.0.
Αν θέλετε βοήθεια ρίξτε πμ!! :138:
Μερικα ακομα νεα και φωτο....
I almost missed the non-working prototype of Oppo's long-awaited BDP-83 Blu-ray player in one corner of the DVDO booth. Not much was revealed except that it will be BD-Live and have 7.1-channel analog outputs. Oh yeah, it will also have the DVDO VRS processing onboard thanks to a new chip, the ABT2010, which is also used in the new Edge processor.
Προσεχτε τωρα τι παιζεται....
Το ABT2010 , το βαζει η Oppo στη νεα παραγωγη του 983.
Αυτο που εχει κανει πολυ κασμο να απορει και να ρωταει ειναι , αφου το ABT2010 υποστηριζει 1080/24 γιατι δεν τα υποστηριζει το 983 ??????????
Γιαννη για μαυρο το βλεπω σαν το 980/983.
Συνεχεια...
Αυτος ειναι ο νεος video processor απο την Anchor Bay ο DVDO Edge.
Παιζει με το ABT2010 και κοστιζει 800$.
pablonou
