Linn Sneaky DS
Διατίθεται εδώ και λίγο καιρό (και μέσω ebay-995£) το Linn Sneaky DS.
-Supported file types: WAV, FLAC, MP3 (native?)
-Audio sample rates: 7.35 k, 8 k, 11.025 k, 12 k, 14.7 k, 16 k, 22.05 k,
24 k, 29.4 k, 32 k, 44.1 k, 48 k, 88.2 k, 96 k, 176.4 k, 192 k
-Word depths: 16 – 24 bits
-Ethernet interface: 100Base-T RJ45
-Control protocol:Compatible with UPnP™ media servers, UPnP™ AV 1.0 control points
-Connector types : optical digital output, coaxial digital output, line outputs
-Inverted safety 4 mm BFA Sockets
-Output impedance: line outputs 300 Ω / speaker outputs 0.06 Ω
-Output voltage: line outputs 2.8 V peak, 2 V rms (0 dBFS) / speaker outputs 15 V peak, 10 V rms (0 dBFS, 16.6 dB gain,vol. 79)
-Output offset: line outputs < 2 mV / speaker outputs < 3 mV
-Signal-to-noise ratio: line outputs Better than -120 dB
-Channel balance: Better than +/- 0.2 dB
-Channel separation: line outputs Better than -120 dB / speaker outputs Better than -100 dB
-Gain range: -80 dB to +20 dB
-Gain resolution 1 dB
-Unity gain volume 0 dB = volume 80
-Dynamic range: 120 dB
-Damping factor: 67
-Signal level for clipping: 415 mV rms (0 dBFS, +16.6 dB gain, vol. 79)
-Harmonic distortion: < 0.03% at 1 kHz at 10 W
-Load tolerance: Unconditionally stable into all loudspeaker loads
-Frequency response: pre 2.5 Hz – 170 kHz (-3 dB) / power 2.5 Hz – 48 kHz (-3 dB)
-Speaker output voltage: 15 V peak
-Speaker output power: 20 W into 4 Ω
-Power consumption: Standby 10 W / Operational 14 W / maximum continuous 120 W
Mains supply voltage (auto-ranging) : 100 – 120 V ac (±10%) 50 – 60 Hz / 200 – 240 V ac (±10%) 50 – 60 Hz
-Fuse 250 V, T1.6 A (not user replaceable)
-Dimensions: 345 mm (w) x 44.5 mm (h) x 274 mm (d)
-Weight 2.7 kg
-Control Remote controllable (handset not supplied)
Τοποθείται και όρθιο (44,5 cm ύψος):
Δεν είναι κελεπούρι ακριβώς, αλλά ως linn θα μπορούσε να είναι και ακριβότερο.
Ευπρόσδεκτες άλλες πληροφορίες (ram,decoder,dac, ενισχυτής,...).
Κάποια παράπλευρα, για άλλη ίσως κατηγορία.
Η Linn (μάλλον γνωστό), συνεργάζεται εκτός από την Twonkymedia και με την ripfactory, εταιρία αυτοματισμού αντιγραφής cd.
Παρουσίασαν το ripserver, ένα mini-itx pc με σχετικά όμορφα χαρακτηριστικά (500 GB-1 TB, RAID 1, fanless, wireless, χαμηλή κατανάλωση,web GUI,linux, αρχικά όλα αυτά όμως, γιατί προέκυψαν διάφορα προβλήματα στην ανάπτυξή του):
Περισσότερα: http://forums.slimdevices.com/showthread.php?t=43979
Το κουτί, είναι το Nexus Psile
Βγάλανε και το δωρεάν ripping λογισμικό, ripstation micro με αυτόματοποιημένο tagging από freedb και την δικιά τους βάση-GD3, αντίστοιχη με το accuraterip διαδικασία ελέγχου λαθών (ripsure) και άλλα.
Για την linn ειδικά έχουν την έκδοση ripstation micro ds.
Με μια γρήγορη δοκιμή, αν εξαιρεθούν κάποια σκοτείνα σημεία (όπως το offset, τα gaps, το αν δουλεύει το ripsure (http://forums.slimdevices.com/showthread.php?t=44534&highlight=ripstation), η διαφορά μεταξύ των δύο εκδόσεων αφορά την δομή των φακέλων που δημιουργούνται και κάποιες διαφορές στα tags.
Το ερώτημα είναι, για ποιο λόγο είναι απαραίτητες αυτές οι αλλάγες;
Αν έχει κάποιος μια συλλογή, δημιουργείται κάποιο θέμα όσο αφορά τα tags και το λογισμικό διαχείρισης της Linn, ή το streaming των αρχείων;
Ευχαριστώ.
Ψάχνοντας λίγο περισσότερο, διάβασα πολύ θετικά σχόλια.
Ψηφιακή προενίσχυση (24 ή 32 bit ?), δυνατότητα σταθερής/μεταβλητής στάθμης αναλογικής εξόδου, ενεργοποίησης/απενεργοποίησης τελικού και upsampling.
Για να δούμε και το majik, τον άμεσο ανταγωνιστή του transporter, υποθέτω, χωρίς να γνωρίζω τίποτα περισσότερο.
Με την ευκαιρία, πολύ καλή η κίνηση, για ανοιχτού κώδικα control point.
Ταπεινή μου γνώμη, θα πρέπει να πιέσουν την twonky, αφού την προτείνουν, για μεγαλύτερη ευελιξία (το κυριότερο, δυνατότητα transconding στον server).
Νομίζω ότι τo squeezecenter δεν έχει ακόμα αντίπαλο στον τομέα της λειτουργικότητας, τουλάχιστον.
Και φυσικά όλοι τους, θα πρέπει να μην ξεχνάνε και την ασφάλεια.
Συνεχίζοντας τα σχετικά-άσχετα με το sneaky, από το tracking σύστημα της linn:
Here are the projects we are playing with now...
Silverlight UPnP control-point implementation
UPnP control-point integration into Songbird, WinAmp, Window Media Player or your favorite desktop media manager
Browser integration with Subsonic or your favorite web-based music application
Innovative desktop integration
LinnGUI for Mac
FLAC support for Windows Media Connect
Innovative interaction models for playlist management and multi-room support
LinnGUI for Windows Mobile
LinnGUI for Maemo and the N800
UPnP AV alarm clock, House Audio Sequencer, and Auto DJ
IP Intercom
Voice controlled music selection
Ας γίνουν τα μισά.
  • loggeo
yannissails
