foobar2000ultimate
vlasis
Φωτογράφος!
Απάντηση: foobar2000ultimate
/// INSTALLATION ///
1) extract the .7z archive in the default foobar2000 folder (should be C:\Program Files\foobar2000\)
2) run foobar with ColumnsUI as interface (in Preferences -> Display -> Select interface)
3) in Preferences -> Display -> ColumnsUI -> Main -> use Import Button to import the [link] file extracted in 1) in foobar2000 folder (C:\Program Files\foobar2000\) , apply the imported layout !
4) you may have to configure stand alone components like Quick Search Toolbar, Cover Flow, Lyric Show panel, Playlist Switcher, Album list Panel ... cause the configuration file do not contains my settings (not stored in the .fcl)
5) you may have to change the PATH for covers and artist photos for each components using them ("Graphical Browser" panels, "Panel Stack Splitter" panels and "Cover flow" panel) simply rigth-click on the component to update --> enter settings of the component --> modify the path for the variables cover.path and/or artist.path, generally coded in the first lines of the code of the component!
IMPORTANT : for ELPlaylist, the cover path is set in a variable handled by ELPlaylist __ART_PATH__ (by default, it's setted to folder.jpg in songs directory) --> go to ELPlaylist Settings (rigth click on it -> settings), tab behaviour and just double-click on the var name to update the path used!
/// POSSIBLE TROUBLES ///
- lauching foobar by clicking a file from explorer work bad due to Panel Stack Splitter bugg, and do not display some buttons and panels, the better way is to open mp3 files from foobar or having foobar lauched before opening a music file from explorer
o yeaaaaaaaaaaaaaaaa Timbrius panmegistous!!!!!!!!!
....:609: πωπω ...χάθηκα. :140:
Κάτσε να βγάλω άκρη....
vlasis
Φωτογράφος!
Mηπως θες και αλλα ............μεσιε Τιμπροβιτς!!!!!!!!!!!!!
Αληθεια στην διευθυνση που δινεις ειναι στα ρωσικα ,που στα διαλα τον κατεβαζω τον ultimate??????
vlasis
Φωτογράφος!
1000 αααααααααααααααα----εφτασα τα 1000ααααααααααα μυνηματα!!!!!!Μπραβο
Τimbrius!!!!!!!!!!
Βλάση χρησιμοποιείς το AMR και σαν "usb d to a converter" με
πηγή pc ; Ή το χρησιμοποιείς αποκλειστικά σαν ολοκληρωμένο
cd player;
vlasis
Φωτογράφος!
cd player;
Βασιλη φιλε μου!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Φυσικα εχω σεταρει foobar 2000 με το usb Dac του AMR και......κλαινε μανες πουλακι μου!!!!!
Εχω σεταρει και τον foobar μπερκετι και πανε τα φλακια και τα original regordings συννεφο
μαστορα μου!!!!!!!Ε ρε γλεντια ............!!!!!!!!!!!!!!!!
Βλάση κάνε μου σε παρακαλώ μια χάρη
Εάν σου είναι εύκολο βαλε στο foobar στο preferences-advanced-playback-full file buffering την τιμή 50000 εάν παίζεις flac και πες μου αν ακούς καμιά διαφορά
Thanks
vlasis
Φωτογράφος!
Αντωνακι θα το δω το βραδυ!!!!!!!!Και συ βρε πουλακι μου απο την μακρινη αραπια εχεις τον νου σου πως παιζει ο Φουμπαριδης?????????Ε ρε ανωμαλαρεςςςςςςςς καλα μας λεω εγω!!!!!
Γουσταρωωωωωωωω!!!!!!!!!!!!!!!!!
vlasis
Φωτογράφος!
Απάντηση: Re: foobar2000ultimate
Check again
Σουηδική Αραβία ! από Κατερίνη είμαι
Ρομπες γιναμε παλλικαρακι μου!!!!!!!!ΟΚ απο την Σουηδικη Κατερινη λοιπον.............ευγε νεε μου!!!!!
Spiromag
