Uncharted 2
Αντε αντε με το καλο και να το κανουν και πιο δυσκολο και με πιο πολλους γριφους.
(Αλλα αυτο που θα δακρυσω μολις βγει και το εχω στα xερια μου θα ειναι το God of War 3!!!)
Μερικές φωτογραφίες σκαναρισμένες από περιοδικό εδώ.
Το κείμενο δε διαβάζεται πλήρως αλλά τα βασικά σημεία είναι τα εξής:
- The biggest thing in the article IMO is that there's a new girl named Chloe Frazer. GI asked about Elena and Sully's return but they had no comment.
- The story is about looking for the ships that Marco Polo "lost" while returning home to Italy.
- Melee combat is more dynamic now.
- They mentioned they were using only 30% of the PS3's power with Drake's Fortune and are planning to use nearly 100% with Among Thieves.
- A demo was shown to GI with Drake going through a city (I believe in Nepal), and he's stealthily taking out guards and escaping the city.
- Nolan North returns to be Drake and Chloe Frazer is played by Claudia Black (Stargate SG-1, Fargate).
- The Sixaxis mechanics were ditched for such things as throwing grenades.
- One of the weapons revealed is a rocket launcher that Chloe uses (might only be for the cinematic).
- There are no load screens.
- The score is being composed by Greg Edmonson (same guy from the first one).
- Weapons can be used in any stance (running, behind cover, hanging, climbing a wall, etc.).
- You can now move while aiming behind cover.
"In Uncharted 2, every character fully interacts with the dynamic geometry moving around them, and environments in the background are real parts of the game world"
"If Drake's on top of a train, he's going to be shaking with the train as it moves around"
"As he gets inside, his moveset is going to change, and he's going to be a lot more secure because the wind's not blowing."
- The graphics look better than Uncharted 1.
- Button sequence cinematics such as the final boss have changed so now Drake is now fully controllable in these parts...I think (This one's also hard to describe).
- Climbing seems improved upon. You can climb lamp posts now among other new things.
- If there is an enemy patrolling a rooftop you're climbing a wall to, you can pull him off the roof while hanging on the wall.
http://www.eurogamer.net/tv_video.php?playlist_id=18961
Να και το καινούριο trailer που δυστυχώς μας προέκυψε κι αυτό teaserάκι. Μου αρέσει που έχουν αλλάξει εντελώς το σκηνικό από λιακάδα και ζούγκλα πάντως.
Και :622: σ' αυτόν που έγραψε στα comments "Hang on lads. I've got an idea." :143::143::143: (Από την τελευταία σκηνή του original Italian Job για όσους δεν το αναγνώρισαν.)
Και σ' αυτόν που έγραψε στα comments "Hang on lads. I've got an idea." (Από την τελευταία σκηνή του original Italian Job για όσους δεν το αναγνώρισαν.)
Απο γραφικα ειναι αλλου
Σορρυ που γελαω αλλα τα γραφικα ειναι απιστευτα !!!!!
Εχουν πει περιπου ποτε βγαινει ??
Το τέλος του trailer λέει fall 2009 οπότε γύρω στον επόμενο Νοέμβριο.
Εγώ συνήθως γελάω με τα χάλια γραφικά αλλά όπως γουστάρει ο καθένας.
Προσωπικά πάντα με εντυπωσιάζει η σύγκριση των story-boards με το τελικό αποτέλεσμα, είτε σε παιχνίδι είτε σε ταινία animation. Είναι εκπληκτικό να το βλέπεις να ζωντανεύει στο screen-shot, πόσο μάλλον σε κίνηση. Μακάρι να είχαν δείξει και λίγο gameplay στο trailer...
Γελαω για πολλους και διαφορους λογους που πιστευω οτι τους ξερεις κιολας.:615:
Ενας απο αυτους ειναι οτι βλεπω την "μπαγιατικη":136: 6800 τι βγαζει και δεν μπορω να κρατηθω. :142:
Έχω βαρεθεί με αυτά εντελώς... Αυτό που ξέρω είναι ότι το hardware των PC δεν αξιοποιείται ούτε κατά 50% και όλες οι εταιρείες σε βάζουν να αλλάζεις GPU χωρίς λόγο κάθε τρεις και λίγο.
Το hardware του 2005 που έχουν οι δύο κονσόλες κάνει παπάδες και έχει αρκετά να δώσει ακόμα απ' ό,τι φαίνεται - ειδικά το "δυσκοίλιο" PS3.
Το γνωστο αβανταζ οταν προγραμματιζεις σε στανταρτ hardware.
Αντε να βγεί γρήγορα γιατι μάλλον θα ειναι πολυ καλο οπως και το πρώτο..Αν και ήταν εύκολο και το τελείωσα γρήγορα...
s channel
