DUNE HD CENTER και DUNE BHD MINI
DUNE HD CENTER
Applications:
Dune HD Center is to date the most universal and powerful Full HD (1080p) solution with Blu-Ray support which has a power to be a true Center of any most modern home AV system. With its intuitive user-friendly interface player provides literally all HD and SD video and audio playback features applicable for home use.
Available Models:
  • Dune HD Center
  • Dune HD Center + Wi-Fi 802.11n
  • Dune HD Center + Ethernet 1000 Mb/s
  • Dune HD Center + 2 x eSATA
Main Features
  • Blu-Ray (Profile 1.1/2.0), DVD, CD discs
  • PC, NAS resources in local network and internal HDD (downloads, uploads and live playback).
  • IPTV: free and paid (with additional software modules).
  • Video on Demand (VoD) and Home Video (HV).
  • Internet radio support
Proprietary implementation of full VoD and HV system called "Dune HD" is supported. This system is based on SecureMedia solution, certified by all the Hollywood majors.
  • File formats: MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, DVD-ISO, VIDEO_TS.
  • Video codecs: MPEG2, MPEG4, DivX, XVID, WMV9, VC1, H.264.
  • Audio codecs: DD: AC3 (DD), EAC3 (DD+), Dolby True HD [lossless]; DTS: DTS HD High Resolution Audio (HRA), DTS HD Master Audio (MA) [lossless], decoding in PCM/analog, Bitstream on HDMI1.3.
  • Subtitle formats: Plain text, SSA/AAS, SRT, VOB.
Network
  • NFS, SMB and limited HTTP clients supported.
  • The product?s internal HDD behaves as a NAS (Netwrok Attached Storage).
  • FTP and SMB servers are supported.
  • Bit-Torrent can be used for direct digital content download from Internet.
  • Player also features full functionality of Mozilla Firefox for Internet browsing.
Hardware
the most modern design of Dune HD Center includes - Sigma Designs 8634 SoC
  • 512 MB of RAM, 64 MB flash and 1GB of NAND flash memory for fastest Java support on the latest and future Blu-Ray disks (Profile 2.0).
  • HDMI 1.3 for ultimate HD video and HD audio performance.
  • Optical, coaxial digital and 7.1 analogue audio output.
  • Composite, component, S-Video video output.
  • Three USB 2.0 ports for connecting external AV sources.
  • Ethernet 100 Mb/s and Wi-Fi up to 300 Mb/s (optional).
  • Mobile rack with SATA Direct Link for fast and easy HDD exchange to support any audio and video collection on any number of hard discs w/o need to create expensive multi-disc NAS solutions. Any 3.5? SATA HDDs can be used.
Dimensions
  • 429mm (width) x 296mm (depth) x 94mm (height)
Blu-Ray video playback support
DVD-Video playback support:
  • DVD menu navigation is supported.
  • Sources:
    • Commercial DVD-Video disks:
      • Internal DVD drive.
      • USB DVD drives.
    • ISO images, VIDEO_TS folders:
      • Internal HDD.
      • USB mass storage devices (USB HDD, USB flash memory).
      • USB DVD drives.
      • NFS network folders.
      • SMB network folders.
Media files playback support:
  • Sources:
    • Internal HDD.
    • USB DVD drives.
    • HTTP URLs (limited support).
  • Containers:
    • MPEG (MPEG-TS, MPEG-PS, VOB, M2TS) (typical file extensions: .MPG, .TS, .M2TS, .TP, .VOB).
    • AVI (typical file extensions: .AVI).
    • MOV, MP4 (typical file extensions: .MOV, .MP4, .QT).
    • MKV (typical file extensions: .MKV).
    • ASF (typical file extensions: .ASF, .WMV).
    • DVD-ISO, VIDEO_TS (DVD-Video playback, including DVD menu support).
    • Raw video.
    • Raw audio (typical file extensions: .WAV, .MP3).
  • Video codecs:
    • MPEG2.
    • MPEG4.
    • DivX.
    • XVID.
    • WMV9.
    • VC1.
    • H.264.
  • Audio codecs:
    • AC3 (DD).
    • EAC3 (DD+).
    • DTS.
    • MPEG (layers 1/2/3).
    • AAC.
    • LPCM.
    • WMA.
    • WMAPro.
  • Embedded subtitle formats:
    • In MKV: plain text, SSA/ASS.
    • In MP4: VOB.
  • External subtitle formats:
    • SRT.
  • External audio streams:
    • AC3.
    • DTS.
IPTV:
  • Protocols:
    • Multicast UDP (raw).
    • Multicast RTP.
  • Format:
    • MPEG-TS container.
    • MPEG2 video codec (SD and HD resolutions).
Extended set of supported video modes:
  • HDMI:
    • 480i, 480p (60 Hz)
    • 576i, 576p (50 Hz)
    • 720p (50 Hz, 60 Hz)
    • 1080i (50 Hz, 60 Hz)
    • 1080p (24 Hz, 25 Hz, 30 Hz, 50 Hz, 60 Hz)
    • 1024×768, 1280×1024, 1280×768, 1280×960, 1360×768, 1366×768, 1400×1050, 1440×900, 1600×1200, 1680×1050, 1920×1200 (60 Hz)
  • Component:
    • PAL
    • NTSC
    • 480p (60 Hz)
    • 576p (50 Hz)
    • 720p (24 Hz, 25 Hz, 30 Hz, 50 Hz, 60 Hz)
    • 1080i (48 Hz, 50 Hz, 60 Hz)
  • Composite:
    • PAL
    • NTSC
  • Note: some video modes may be not supported ? it depends on the player mode, type of data being played back, and peculiarities of video hardware connected to the player.
Product Specifications
Download PDF file: dune_hdcenter.pdf [136.69 Kb] (Count: 424)
Hi-res pictures
Hi-res Dune HD Center pictures
ΤΙΜΗ : 599 ΕΥΡΩ
DUNE HD MINI
Applications:
Dune HD Mini is a compact Full HD player supporting all the features of its "big brother" Dune HD Center, but w/o an optical drive.
Available Models:
  • Dune HD Mini (home use)
  • Dune HD Mini (for Digital Signage)
Hardware
  • Sigma Designs 8635 SoC
  • 256 MB of RAM, 64 MB flash - HDMI 1.3 - coaxial digital and stereo (2.0) analogue audio output
  • composite, component, S-Video video output
  • two USB 2.0 host connectors
  • USB slave to be used as external USB box to a PC (for fastest data transfers)
  • Ethernet 100 Mb/s and WiFi up to 300 Mb/s (USB dongle)
  • Mobile rack for HDD with SATA Direct Link
Dimensions
  • 268mm (width) x 138mm (depth) x 43mm (height)
  • Sources:
      • USB DVD drives.
      • Internal HDD.
      • USB DVD drives.
  • Sources:
    • Internal HDD.
    • USB DVD drives.
  • Containers:
    • Raw video.
  • Video codecs:
    • MPEG2.
    • MPEG4.
    • DivX.
    • XVID.
    • WMV9.
    • VC1.
    • H.264.
  • Audio codecs:
    • AC3 (DD).
    • EAC3 (DD+).
    • DTS.
    • AAC.
    • LPCM.
    • WMA.
    • WMAPro.
    • In MP4: VOB.
    • SRT.
    • AC3.
    • DTS.
IPTV:
  • Protocols:
    • Multicast RTP.
  • Format:
  • HDMI:
  • Component:
    • PAL
    • NTSC
    • 480p (60 Hz)
    • 576p (50 Hz)
  • Composite:
    • PAL
    • NTSC
  • Note: some video modes may be not supported � it depends on the player mode, type of data being played back, and peculiarities of video hardware connected to the player.
Download PDF file: dune_hdmini.pdf [136.69 Kb] (Count: 202)
Hi-res pictures
Hi-res Dune HD Mini pictures
TIMH : 299 EΥΡΩ
Απο την Ισραηλινη HDI αναμενονται μες τον Δεκεμβρη.
Αντρεα οι τιμες θα ειναι ιδιες πανω κατω με αυτες που αναφερω ή "ανταγωνιστικοτερες";:105:
Καλες πωλησεις(..θα εχετε)!
Βαγγέλης Λάμπρου
Επειδή ρωτάω στο εξωτερικό για τους υποτιλους πριν παραλάβουμε τα πρώτα κομμάτια θέλω να μου πείτε οι αρχαιότεροι της κατηγορίας:
Τι προδιαγραφές έχουμε για να παίζουν όλοι οι υπότιτλοι των αρχείων; (Όλων των αρχείων... μη μου πέιτε αυτο το ξεχάσαμε γιατι θα τα ακούσετε)
Εχω εξαιρετική επικοινωνία με τον προγραμματιστη του software και θα μας κάνει τα χατήρια αρκεί να είμαστε γρήγοροι)
Για λέτε γρήγορα να τα μεταβιβάσω γιατι το μηχανημα φαίνεται οτι θα λύσει πολλά χέρια με αυτα που κάνει...
Απάντηση: DUNE HD CENTER και DUNE BHD MINI
Αυτες οι δημοσιες σχεσεις σου Βαγγελη μου δεν εχουν ορια :137:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Δεν ηξερα οτι ειχαμε τετοια...κονε:444:
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Re: DUNE HD CENTER και DUNE BHD MINI
δεν του λες να κάνει κάτι και με τα flac αρχεία;
Βαγγέλης Λάμπρου
Μόλις το έλαβα και σας το αντιγράφω.....
(του έστειλα οτι γνώριζα για τους υπιοτίτλους γιατι δυστυχώς δεν έλαβα μήνυμα σας....)
Hi Evagelos
please note: according to our s/w engineers, Greek subtitles are supported now (CP-1253). Tomorrow we'll be already sending the mass production orders to our distributors with this new firmware.
Best regards
Konstantin
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Hi Evagelos
Best regards
Konstantin
Μετα απο ολα αυτα, οπως καταλαβαινετε, ερχεται...:126:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Λαβαμε και αλλη απαντηση σχετικα με ερωτηση μας εαν μπορουν να
μετακινηθουν οι υποτιτλοι μεσα στο καδρο(ξερετε την καψουρα μας
για το 2.40:120:)
Μας απαντησαν πως σε οποιοδηποτε μορφης αρχειο γινεται.
Πατας το κουμπακι "subtitles" και μετακινεις με τον κερσορα πανω η κατω.
Ομως, σε οτιδηποτε μπαινει στο disc drive δεν γινεται...ακομα.
Εαν γινει, θα ξεκινησει απο το DVD και θα ακολουθησει το Blu ray...
MAD
Σιαρτάκιας
Ξέρουμε εάν βλέπει εξωτερικό USB σκληρό NTFS?
  • loggeo
Christos Kourmouzoglou
