DREAMBOX 8000 HD PVR... Ξεκίνησε η διάθεση στην αγορά....
panosop
Συστημικός
Απάντηση: DREAMBOX 8000 HD PVR... Ξεκίνησε η διάθεση στην αγορά....
- 400 MHz MIPS Processor
- Linux Operating System
- brilliant big-size OLED - Display
- MPEG-2 / MPEG 4 H.264 Hardware decoding
- TWIN DVB-S2 tuner
- 2 x Plug&Play tuner sockets
optional for DVB-S, DVB-C or DVB-T
- 4 x DVB Common-Interface Slot
- 2 x Smartcard-Reader
- V.24/RS232 Interface
- Integrated Compact Flash and SD Card Slot
- 10/100 MBit compatible Ethernet Interface
- 3 x USB 2.0 (1 x front, 2 x back)
- S/PDIF Interface for digital bit stream out (AC-3)
- 2 x Scart-interfaces
- S-Video
- YPrPb (Component)
- DVI
- Audio/Video cinch out
- 128 MByte Flash, 256 MByte RAM
- 2 x integrated SATA
- support for internal IDE HDD 3,5” in any capacity
- support for SATA SlimLine DVD
- WiFi (Mini-PCI device inl. antenna)
- unlimited channel lists for TV/Radio
- channel-change time < 1 second
- automatic service scan
- directly bouquet-lists
- EPG (electronic program guide)
- Videotext Decoder
- multiple LNB-Switching control (DiSEqC)
- OSD in many languages and skin-support
DreamBox DM8000 technical data
DBS-Tuner:
Frequency Range 950 ... 2150 MHz
QPSK Demodulation EN 302 307
Signal Level - 65 dBm ... - 25 dBm
Signal-to-Noise Level 12 dB max.
DBS-Tuner Input Connector F-Type female
Input Impedance 75 Ohm
AFC +/- 3 MHz
Demodulation Shaped QPSK and 8PSK
FEC Viterbi and Reed-Solomon
Viterbirate 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9
Roll-off Factor 35 %
Common-Interface:
Common-Interface Power Consumption max. 0,3A/5V
Video decoder:
Video Compression MPEG-2 / MPEG-4 H.264 and MPEG-1 compatible
Video Standard PAL G/ 25 Hz, NTSC
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical (AC3)
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video
VCR-Scart:
FBAS
Serielle Interface RS 232:
Typ RS232 bidirectional
Bitrate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
USB:
USB 2.0 connector (3x)
SATA Interface:
for internal HDD
Compact Flash - Reader
SD Card - Reader
LNB power and polarisation per tuner:
LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
Count of active satellite position:
DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power consumption:
< 30W (in operation, horizontal polarization / 400mA LNB current)
< 25W (in operation, no LNB)
< 2W (Deep-Standby-Mode)
Input voltage:
230V / 50 Hz alternating current +/- 15%
110V / 60 Hz alternating current +/- 15%
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 430 mm x 280 mm x 90 mm
Weight: 3,0 kg without HDD a. DVD
panosop
Συστημικός
τιμη ε???
για δείτε εδώ στη Γερμανία...
http://www.hm-sat-shop.de/11311-200.ahtml
ΜΟΝΟ 999 ευρώ, ΟΥΤΕ 1000... :109::114: :617:
Βεβαια δεν μου άρεσε ότι τελικά δεν βάλανε HDMI αλλά όπως και στον 800αρη, μόνο DVI-D...
Επίσης ότι η CPU του είναι μόνο στα 400 Mhz και όχι στα 733 Mhz που λέγανε απο την αρχή.
Αλλά "μπρός στα κάλη τί είναι ο πόνος...".΄
Για να δούμε πώς θα παίξει στην αγορά.
Εδώ στην Ελλάδα θα τον πουλάνε ή θα τον νοικιάζουνε ; :114: :142:
....Αλλά "μπρός στα κάλη τί είναι ο πόνος..."
1000,00 ευρώπουλα δεν είναι πόνος ......θάνατος είναι !!! :144:
:125:
πολλά... πάρα πολλά είναι... και ευχομαι να επριλαμβάνουν κάνα τέρα δίσκο μεσα στην τιμή... αν και πόσο εχει ενας τέτοιος δίσκος 100 ευρώ
Ποιες ειναι οι διαφορες απο τον DREAMBOX 800 HD ?
Οι βασικές διαφορές στο hardware ειναι ότι ο 800 έχει 1 card reader και κανένα C.I. ενώ ο 8000 2 card reader + 4 C.I.
Eπίσης έχει 3 θυρες usb εναντι 1 του 800
Εχει CF reader, MM/SD reader (που δεν έχει ο 800)
Εχει 2 tuner δορυφορικά (dvb-s2) και μπορεί να δεχτεί αλλα 2 (και dvb-t) ενω ο 800 παιρνει μόνο 1
Μπορείς να βαλεις και dvd-rw
...αυτά σε γενικές γραμμές, τις λοιπές διαφορες θα τις δούμε στην πράξη...
Στην παρουσα κατασταση με τα δορυφορικα δρωμενα (Γερμανια,Ισπανια) και με τα ρολλα κατεβασμενα δυστηχως το ποσο αποκτησης του ειναι υπερβολικο, ποιος ο λογος να δωσεις 1000 ευρω οταν με τα μισα και κατι λιγοτερο θα παρεις τον μικρο αδελφο του?
Αλωστε αυτα που παρεχει στην παρουσα φαση ειτε ειναι υπερβολικα ειτε υπαρχουν και σε αλλες ηλεκτρονικες συσκευες.
Οι δέκτες είναι μέχρι 2 (μέγιστο) νομίζω. Μόνο ο qbox HD θα δέχεται 3...
Τα τιούνερ του 8000 ειναι δύο + 2 κενές υποδοχές για προσθήκες αλλων 2 της επιλογής σου (plug and play) , σύνολο μέχρι 4
Αν εξαιρέσουμε τον αριθμό των tuners και το HD έχει ότι και ο 7020, θα έλεγα δυσανάλογα ακριβότερος!
Evasound
