O νεος Optoma HD8200
ΛΕΥΤΕΡΗΣ ΚΟΥΚΟΥΡΑΚΗΣ
απο-Συντονιστής
Μπα... Ποτε δεν ενδιαφερθηκα για το πως δειχνει ενας προβολεας, αλλα μονο για το πως "δειχνει"... Παντως ειναι πιο ομορφος απο τους υπολοιπους οπτομα... Για να δουμε και τι πουλια πιανει στην εικονα...
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
I saw the optima at CES. The booth they had it in was fully light controlled and they had it running through an anamorphic lens. They were running Indiana Jones IV while I was there. The movie looked pretty impressive. Optima always seems to run these demo's with an anamorphic lens at the trade shows. They always display well. Most of us don't own a lens set up yet so I don't think its fair to compare it to other 1080P projectors without them. The images I saw were great. With the lens in place you could not see any screen door and the image was bright enough that the wedding seen at the end of Indy was nearly uncomfortably bright. I also got demo's from Epson, Panasonic and a ton of micro projector companies. If the Optima ends up retailing for under $2.6k it will be a great value compared to the other new projectors just released. The panasonic with its anamorphic stretch mode was great looking too. Just not razor sharp. The colors looked very natural on it. The Epson 6500UB looked sharper than the Panny, and had awsome blacks on the Harry Potter scenes they were using for the Demo. Neither projector had the POP of a DLP display. I can only describe them as "muted" somehow in the way they compare.
Aπο το αμερικανικο φορουμ...
Βαγγέλης Λάμπρου
Διαβάζοντας τον Αμερικάνο παρατηρώ οτι δεν θέλει να κάνει σύγκριση του νέου Optoma διότι τον χρησιμοποιεί η μητρική εταιρία στο περίπτερο της με αναμορφικό, κάτι που του δίνει πλεονέκτημα έναντι προβολέων άλλων εταιρειών. Δεν είναι "Fair".....
Δεν γνωρίζει ο καψερός ποια είναι η αναποδη θέση...του "Greek Style"
MaxHeadroom
Απάντηση: O νεος Optoma HD8200
Απορία: αφού ο αναμορφικός θεραπεύει πάσα νόσο, γιατί δε βάζουν κι οι καψεροί οι κατασκευαστές των LCD και μένουν πίσω σε... ποπ; :612:
Άχαχά κρίμα που δεν είναι εδώ τα παιδιά... Βασικά εννοεί πως κερδίζει σε φωτεινότητα και ανάλυση έστω και χωρίς 1:1 pixel mapping το οποίο ειλικρινά δεν φαίνεται καθόλου.
Απάντηση: Re: O νεος Optoma HD8200
Νατος παλι...!!!!!!.:116:
Βρε δεν τους αρεσει ο φακος....δεν το καταλαβαινεις..!!!!!
Μου κάνει εντύπωση που δεν χρησιμοποιούν darkchip 4. Μήπως για λόγους κόστους ;
atsa
