Enigma 2 στον Kathrein!
AF_Flashimage_4.47
Now it is finally over and the flash image AAF is ready.
The AAF + TDT team has allowed the necessary time to patch for the problem with LM purely to take.
TDT + AAF MOD for Flash
Our common image in January 2009.
Image Info
Enigma2 Team Ducktales Build rev709 AAF Flash Mod 4:47
Base Team Ducktales Build rev709 from 18.01.2009
Changelog since last public release:
E2 rev644 change since New Year's Image:
Team Ducktales:
+ Advanced diagnostic functions (Loading module Bug)
+ Loading Modules Bug Workaround (1w)
+ Performance improvements
+ CI module improves handling
VFD + memory error fix
MKV H264 + Start / Stop fix
+ DTS MKV playback
+ Better rewind buttons on m2ts/trp/vob in 1 / 3 4 / 6 7 / 9
+ Symbol rates patch 30000000
+ Full Picture Player
+ Network Test should work now
+ Tuxtxt fix (Videotext should now run without SWAP)
AAF:
+ AAF pannels v1.3 (cifs, hddsleep, samba server, powerbotton)
+ SoftCam Panel 0:11
+ Aspect ratio in Media Player / DVD player with changeable OK
+ Mount for movies in the IMG / RAR container
+ New Version 3.3 Amount me CIFS mount support
+ Umount when device is removed
+ HDD Standby (set on AAF panel automount)
+ OSD Screenshot in WebIF
+ Emu Control in WebIF
+ Remote WebIF replaced
+ WAP Fix
+ Keymap adapted
+ AAF Default Skin v.1.1.0
+ Channel number / Satinfo in infobar
+ AAF Modnummer in ImageInfo
+ EcmInfo thx max
+ Samba Server Support (only with the stick extension)
Thanks to team for the super Ducktales base image and all of this image allows and have tested.
TDT + AAF MOD für euer BA Stick
Unser gemeinsames Januar 2009 Image.
Image Info
Enigma2 Team Ducktales Build rev709 AAF BA Mod 4.51
Basis Team Ducktales Build rev709 vom 18.01.2009
Changelog seit letzten oeffentlichen Release:
Aenderungen seit E2 rev644 Neujahrsimage:
Team Ducktales:
+ Fixed Loading Modules Bug
+ fixed mme bug
+ Performanceverbesserungen
+ CI Modul Handling verbessert
+ VFD Speicherfehler fix
+ MKV H264 Start/Stop fix
+ MKV DTS Playback
+ Besseres spulen bei m2ts/trp/vob auf Tasten 1/3 4/6 7/9
+ Symbolraten Patch 30000000
+ PicturePlayer Vollbild
+ Netzwerk-Test sollte nun funktionieren
+ Tuxtxt fix (Videotext sollte nun auch ohne SWAP laufen)
AAF:
+ AAF Pannel v1.3 (cifs, hddsleep, sambaserver, powerbotton)
+ SoftCam Panel 0.11
+ Seitenverhältnis in Mediaplayer/DVD-Player mit OK änderbar
+ Mounter für Filme im IMG / RAR Container
+ Neue Amount Version 3.3 mir CIFS Mount support
+ Unmount wenn Geraet entfernt wird
+ HDD Standby (einzustellen über AAF-Panel automount)
+ OSD Screenshot im WebIF
+ Emu Control im WebIF
+ Fernbedienung im WebIF ersetzt
+ WAP Fix
+ keymap angepasst
+ ChannelNummer/Satinfo in Infobar
+ AAF-Modnummer in Imageinfo
+ EcmInfo thx max10
+ Sambaserver Support
Änderungen
1. Webinterface
2. Skin Wechsel (reboot statt gui restart)
3. AAF-Panel Power Booten (reboot statt gui restart)
Απάντηση: Enigma 2 στον Kathrein!
Παιδια μια βοηθεια μιας κι εχω μεινει πολυ πισω στις εξελιξεις.
Εχω πανω το AAf 1.5 και καπου καπου μου κανει καποια κολληματα.
Ποιο ειναι τωρα το πιο σταθερο image και ποια προεργασια χρειαζεται για να φορτωθεί (θυμαμαι οτι παλια βαζαμε το επισημο firmware πριν περασουμε τα aaf).
Ευχαριστω.
Μαλλον το πιο σταθερο που μπορεις να βαλεις αυτη τη στιγμη ειναι το ΑAF 2.0e. Θα το βαλεις στην flash η σε στικακι?
Για την flash σκεφτομαι γιατι δεν ξερω πως μπαινει σε στικακι.
Ειναι δυσκολη διαδικασια να μπιε σε στικακι?
Βάλτο στην flash με την διαδικασια emergency boot . Αν δεν την ξέρεις κατέβασε το image και έχει how to .
Που το βρισκουμε το aaf 2.0e? Βρισκω ενα που λεει AΑF All In One Package 2.0. Αυτο ειναι?
Λεγοντας emergency boot εννοεις την διαδικαισα με το στικακι που κλεινουμε τον δεκτη απο τοο διακοπτη και παταμε menu και ανοιγουμε τον διακοπτη?
To βαζω πανω απο το aaf 1.5 που εχω τωρα ή θελει να βαλω το επισιμο image και μετα αυτο?
-Enigma2 Team DucktalesBuild rev709 AAF BA Mod 4.51 http://rapidshare.com/files/188388912/AAF_BA_Image_4.51_P1.1.rar
-AAF_Flashimage_4.47/9 http://ufs910.hdtvinfo.eu/component/option,com_remository/func,fileinfo/id,140/
για το δεύτερο link μπορει να χρειαστεί register .
Παραθέτω τα στοιχεία παρακάτω σε 2 τμήματα για να μην γίνει τεράστιο το post.
οκ μπήκε . Τώρα πως γίνεται μέσω δικτύου να δει τον σκληρό;;
Μπορείς να γράψεις ως παράδειγμα το δικό σου configuration?
1. Φίλιππε εδώ θα βρεις ότι χρειάζεσαι αν και αυτό που βρήκες πρέπει να είναι το σωστό.Το em boot είναι με το stick και περιγράφεται στο how to.
http://www.ump2002.net/index.php?PH...n=0&order=mod&directory=Images-Tools-Kathrein
2.Nexiand για να δει τον σκληρό μέσω δικτύου πρέπει να έχεις εγκαταστήσει κάποιο πρόγραμμα nfs server στο pc (π.χ. windows sfu 3.5 ) και να κάνεις share τον σκληρό . Στον δέκτη το μόνο που έχεις να κάνεις είναι να πας AAF PANEL-SETUP-AUTOMOUNT και να βάλεις τα στοιχεία του δικτυομένου υπολογιστή (ip, share folder name , mount point) π.χ. 192.168.0.5...
/movies/ ... /mnt/nfs/server ,στα αντίστοιχα πεδία. Το firewall πρέπει να το ρυθμίσεις ώστε να επιτρέπει την πρόσβαση.
how to : http://www.pixelmagicforum.com/forum/showthread.php?t=1784
windows sfu : http://www.microsoft.com/downloads/...88-601B-44F1-81A4-02878FF11778&displaylang=en
Απάντηση: Re: Enigma 2 στον Kathrein!
ΟΚ. Ευχαριστω πολυ.
Το κατεβαζω κι ελπιζω να μην κολλησω πουθενα.
ευχαριστώ...........
ο server μου τρέχει linux οπότε ήταν εύκολο για εμένα δεν χρειάζομαι τα παραπάνω προγράμματα.
Το πρόβλημα ήταν ότι δεν έκανα τον υποφάκελο movie και για αυτό δεν έβλεπε τις ταινίες που δοκίμαζα. Τώρα όλα καλά.
Δόκιμασα *mkv τα παίζει κανονικά. όσα όμως έχουν DTS ήχο δεν ακούγεται τίποτα. υπάρχει λύση;;
Για dts δεν μου έχει τύχει αλλά υπάρχει ένα πρόγραμμα που μετατρέπει τις ταινίες με dts σε DD γιατι προφανώς είναι και άλλες συσκευές που έχουν πρόβλημα. Δεν θυμάμαι όμως που το είχα δει.
Το εκανα και γω, αλλα σε καμια δεν μου κανει spdi/f passthrough, και ας ειναι σωστα οι ρυθμισεις στο a/v settings. Καμια ιδεα?
Εγώ περνάω τον ήχο με hdmi στην τηλεόραση και από εκεί coaxial στον ενισχυτή.
eεπαναφορα σε kathrein ufs 910 χωρις να μπορω να συνδεθω μεσω eternet λογω οτι οταν επαθε προβλημα προσπαθησα να του φορτωσω απο λαθος version firmware 1.3
intergrale
