Trends Audio Tube Pre-amp / Buffer
Κώστας Φ.
Έτοιμος ο προενισχυτής της γνωστής, πλέον, Trends.
Photo δεν έχει πάρει το μάτι μου πουθενά, αλλά υπάρχει ως pre-order.
Αντιγράφω από το site τους...
Trends PA-10 Tube Headphone/Pre Amplifier is an innovative audio product and provides all functions of headphone amplifier, pre-amplifier and phono pre-amplifier.
[Features]
- the innovative circuit design of low voltage hybrid (tube/transistor) pre-amp to provide audiophile quality sound, compact size, and easy/safe DIYer accessibility
- pure class-A circuit to provide the best sound performance
- support both 6DJ8/6922 series and 12AU7 series tubes by simply switching the jumpers. DIYers can easily change their both series tubes to enjoy the fun.
- ONE bi-triode 6DJ8/6922 or 12AU7 tube as voltage amplification and TWO MOSFETs as output driver which perform the warm, comfortable tube sound and in addition, guarantee the high fidelity & sufficient driving power to the next power amplifier stage.
- provide all functions of headphone amplifier, pre-amplifier and phono pre-amplifier
- provide TWO sets of switching audio inputs. Besides the normal CD input, the Phono input with higher gain is provided for small output turntable or PC sound card. No separated phono pre-amplifier is required.
- Besides the normal audio output in the back panel, ONE headphone output in the front to drive even high-impedance audiophile-grade headphones
- compact design (mini-size & light weight), suitable for hi-fi room, living room, sleeping room or even right beside your laptop computer.
- TWO precise screw-driving potentiometers for professional audiophiles to adjust the tube’s bias voltage to guarantee the best working point for different tubes.
- require just a single +24V power supply ONLY, besides the bundled AC adaptor, audiophiles can apply all other power supply with the same spec., e.g. lead-acid batteries.
- a specially designed AC power adaptor with extra low ripple & noise for Hi-Fi device is bundled for continuous power supply
- separate pre-amp unit & power adaptor to minimize interference and flexible to apply other power sources, e.g. lead-acid battery.
- all audiophile-graded parts and components
- the stylish aluminium case provides outstanding shielding & grounding capability to keeps the background silent and maximize the S/N ratio.
Πηγή: Trends Audio
200$ στην αμερική ... ε κάπου 200+ε εδώ.
Πάντως πρώτη φορά βλέπω προϊόν σε webshop διαθέσιμο για pre-order χωρίς έστω και μια φωτογραφία. Αυτό θα πει πάρτε το με κλειστά μάτια.
Ελπίζω να παίζει καλύτερα απ' όσο φαίνεται (ψιλοαηδία - μεταξύ μας...)
http://www.buyoyo.com/buyoyo/eng/ProductDisplay.do?prtype=17&prrfnbr=11258371
Προσωπικά πάντως θα το αγοράσω. Έχω και τον ΤΑ και το UD και είμαι πολύ ευχαριστημένος. Μπορώ να πώ οτι με ένα UD και ένα ULTRAMATCH απέφυγα -για την ώρα- το BENCHMARK.
themiloc
Πληροφορώ οτι σε λίγο θα παραράληφθούν οι PA-10 και με τις Ρωσσικές 6H23n.
Η διαφορα του PA-10 SE στην τιμή από την στάνταρ λάμπα θα είναι 25 ευρο. (PA-10 185ευρο/ PA-10 SE 210 ευρο)
Οι πρώτες εντυπώσεις όσων των δοκίμασαν ήταν ανάλογες με εκείνες του ενισχυτακίου TA-10.1 και σαν pre και σαν headhone amp.
Θ.Ζ.
LOCATION SOUND
ΠΡΟΣΟΧΗ παιδιά, τα ψηφιακά καίγονται ΠΑΝΕΥΚΟΛΑ και επισκευή, σημαίνει αγορά νέου, λόγω τιμής. ΠΑΘΩΝ. :(
Κώστας Φ.
Νίκο αν με τα ψηφιακά εννοείς τους Class-D, θα σου έλεγα ότι γενικεύεις. Οι υλοποιήσεις είναι τόσες πολλές και τόσο διαφορετικές που δεν είναι σωστό να τσουβαλιάζουμε έτσι.
Αν αναφέρεσαι αποκλειστικά στον Trends, να σου πω ότι τον έχω δύο (2) χρόνια, έχει περάσει από όλα τα συστήματα φίλων και, ενώ έχει περάσει αρκετά (γιατί μου αρέσει να σκαλίζω...), δεν έχει βγάλει "κιχ".
Νικο και σε εσενα και σε εμενα καηκε επειδη καναμε μακακια και τον βραχυκυκλωσαμε.:137:
Να ειναι καλα ο κυριος Θεμης Ζαφ. που και στους δυο μας τους αλλαξε υπο τις καλυτερες προυποθεσεις.
Απάντηση: Re: Trends Audio Tube Pre-amp / Buffer
Ναι αυτό οφείλω να το ομολογήσω. :107:
η τιμή του ΡΑ-10 τώρα πόσο είναι;
Απάντηση: Trends Audio Tube Pre-amp / Buffer
Από ότι ακούω δεν έχει θετική επίδραση, αν κάποιος ακούει ροκ, δεν μιλάω για μέταλ.
Το χει πάρει κάποιος το μηχάνημα;
Σκέφτομαι να υλοποιήσω τη λύση του David Kan (http://www.6moons.com/audioreviews/trends/ta10_3.html)
με το νέο pro της Trends και δυο Trends ΤΑ-10.1 σαν power amps σε floorstanders υψηλής ευαισθησίας (αν όχι τα Klipsch Synergy F2 (τα βάσης RB-61 δεν ήταν για πολύωρη ακρόαση, κούραζαν) τότε ίσως τα Dali Ikon 6; Κάποιο άλλο που να μπορεί να μπει σε 20 εκ. από πίσω τοίχο και 10 - 15 εκ. δεξιά και αριστερά από χαμηλό έπιπλο και μπαλκονόπορτα; Θέση ακρόασης στα 2 μ. 30 εκ.).
Θα ήθελα να μάθω αν το έχει κάνει κανείς από το forum. Κι αν ναι, με τί ηχεία και πώς ήταν το ηχητικό αποτέλεσμα;
Ευχαριστώ εκ των προτέρων,
Κώστας
Nikos67
