http://en.wikipedia.org/wiki/SPDIF
Αυτό με το Max. Res. ισχύει ?
Από αυτό και απο το επόμενο πινακάκι κατάλαβα ότι χρειάζεται 75 Ω A/V cable, σωστά ?Note that there are no differences in the signals transmitted over optical or coaxial S/PDIF connectors—both carry exactly the same information.
Selection of one over the other rests mainly on the availability of appropriate connectors on the chosen equipment and the preference and convenience of the user.
Connections longer than 6 meters or so, or those requiring tight bends, should use coaxial cable, since the high light signal attenuation of TOSLINK cables limits its effective range.
On the other hand, TOSLINK cables are not susceptible to ground loops and RF interference like coaxial cables.[1] One deciding factor for many is cost—any standard 75 Ω A/V cable can be used for coaxial connectivity, while TOSLINK requires a specific cable which until recently was not very affordable.
