Laptop Acer (4 κομματια)
ACER Aspire 8930G
Processor Intel Core 2 Duo T5800 clocked at 2.0 GHz
RAM 4096 MB (2 x 2048 MB) DDR2 clocked at 667 MHz
Graphics card NVIDIA GeForce 9600M GS 512 MB dedicated, up to 2303 MB total memory
Screen type 18.4" WXGA HD+ screen
Acer CineCrystal
Hard drive 320 GB ATA
Optical disk drive Blu-ray player / SuperMulti dual-layer DVD writer
Memory card reader 6-in-1 card reader: (SD, MMC, MMCplus, MS, MS PRO, xD)
USB Four USB 2.0 ports
Modem/Ethernet 56k ITU V.92 with PTT approval, Wake-on-Ring ready
Wi-Fi Intel Wireless WiFi Link 5100 (dual-band quad-mode 802.11a/b/g/Draft-N) Wi-Fi CERTIFIED network connection, includes 1x2 MIMO technology to support Acer SignalUp technology with Nplify wireless
Bluetooth Yes
TV output HDMi socket with HDCP compatibility
VGA port
Extension card slot ExpressCard/54 slot
Additional features Slot for Kensington keystone
Acer FingerPrint Bio-Protection
High definition 0.3-megapixel Crystal Eye webcam
Dolby Surround Sound system with 5 speakers
5 built-in stereo speakers and 1 subwoofer to support bass effects
Compatible with 2nd generation Dolby Home Theatre systems, including technologies such as Dolby Digital, Dolby Digital Live, Dolby Pro Logic II, Dolby Headphone and Dolby Virtual Speaker
Acer CineSurround for 5 built-in speakers and 1 Acer Tuba CineBass booster to support bass effects
True 5.1-channel Surround sound input
Compatible with MS Sound
Acer PureZone technology with two built-in microphones to remove effects such as background noise and echo
Accessories included Connector for power unit, 8-cell battery
Software included Microsoft Works 8.5 + Office Home & Student 2007 (60-day trial pack)
Acer drivers and utilities
Adobe Reader
CyberLink PowerDirector (demo version)
McAfee Internet Security Suite (60-day trial version)
NTI Media Maker
Size 441.4 x 300 x 40.2-44.2 mm
Weight 4.1 kg
ΤΙΜΗ = 795 ΕΥΡΩ
Εξοδα αποστολης δικα μου (με καταθεση) --- Οπως παντα
Η διαδικασια ειναι απλη αλλα την γραφω να να ειμαι ΚΑΘΑΡΟΣ:
Βαζετε τα χρηματα σε λογαριασμο και το λαπτοπ ερχετε (μεσα σε 2-3 ημερες) στην διευθυνση που θελετε με courier πληρωμενο.
Υπαρχουν 2 κομματια
Φυσικα υπαρχει αποδειξη.
Φυσικα υπαρχει εγγυηση.
Ολα εχουν 1 χρονο ΔΙΕΘΝΗ εγγυηση.
Μπορει να κοπει και τιμολογιο
ACER Aspire 7730
Processor Intel Core 2 Duo T5800 processor clocked at 2 GHz
Cache memory 2 MB
RAM 4,096 MB
Graphics card UMA graphics card
Screen type 17" CrystalBrite WXGA+ screen
Hard drive 160 GB
Optical disk drive SuperMulti dual-layer DVD writer
USB 4 USB 2.0 ports
Modem/Ethernet 56K Ethernet 10/100 modem
Wi-Fi WiFi 802.11a/b/g/Draft-N
TV output HDMi port
Accessories included Mains adapter, battery and user guide
Size 402 x 297 x 41-43.9 mm
Weight 3.8 kg
ΤΙΜΗ = 520 ΕΥΡΩ
Υπαρχουν 2 κομματια
.....Ολα εχουν 1 χρονο ΔΙΕΘΝΗ εγγυηση......
θα ειχε ενδιαφερον αν η εγγυηση ηταν 2 ΧΡΟΝΙΑ, που δινουν οι περισσοτερες
εταιρειες.
εταιρειες.
Δικο μου το λαθος....
Εχουν 2 χρονια εγγυηση.
Εμεινε μονο ενα ACER Aspire 8930G
Νεα τιμη για να φευγει....
700 ευρω
Electr
