Δειτε το NEO slim PS 3 !!
[IMGl]http://img2.pict.com/0c/4a/db/1488948/0/slimps33.jpg[/IMGl]
Today at the gamescom conference in Cologne, Germany, SCEI chief Kaz Hirai officially announced the Slim PS3, available in stores from the first week of September. Price will be $299 in the US, 299 € in Europe, £249 in the UK and ₯29,980 in Japan.
The US version can be Pre-ordered Now From Amazon.com.
http://www.amazon.com/dp/B002I0J4VQ/?tag=bluraynews-20
The UK version can be Pre-ordered Now From Amazon.co.uk.
http://www.amazon.co.uk/dp/B002L16JXS/?tag=bluraynews-20
Features and connections are the same as on existing models. It'll include a 120GB hard drive (upgradeable).
According to SCE, the internal design architecture of the new PS3 system, from the main semiconductors and power supply unit to the cooling mechanism, has been completely redesigned.
Size, weight and energy requirements are cut by a third. Dimensions are 290Χ65Χ290 mm (11.4Χ2.6Χ11.4 in). Weight is 3.2 kg (7.0 lbs). Power consumption is approximately 250W. Noise is also reduced, although no specific figure was given.
[IMGr]http://img2.pict.com/34/a6/a4/1488952/0/slimps32.jpg[/IMGr]
As regards the outside look, the form factor of the new PS3 system features a new design with textured surface finish (in charcoal black vs the piano black finish on previous models), giving "an all new impression and a casual look," which the company hopes "will appeal to a wider audience."
With the introduction of the new PS3 system, SCE will also reduce the price of the current PS3 with 80GB HDD to an RRP of US$299.
Also in North America, the price of PS3 with 160GB HDD will be reduced to an RRP of US$399 from August 18.
Απάντηση: Δειτε το NEO slim PS 3 !!
Να το κάνουν επίπεδο, για να μπαίνει μαζί με άλλες συσκευές ούτε που τους πέρασε από το μυαλό!
Εκεί, αυτάρεσκο, μόνο του ή πάνω από τις άλλες συσκευές μόνο...
Και ακόμα πιο άσχημο και πιο φτηνιάρικο μου φαίνεται... Τουλάχιστον δεν θα χρειάζεται Swiffer! :138:
Με λιγότερο χώρο, λιγότερο αέρα και μεγαλύτερες θερμοκρασίες;
Προτιμώ το "χοντρούλικό" μου.
Αλήθεια, την τιμή την είδατε? Για να δούμε πόσο θα κάνει εδώ! Τα 299$ που θα ανέβουν?
Έχει μικρότερες ανάγκες ψύξης λόγω νέου επεξεργαστή. Κ θα είναι κ πιο αθόρυβο
xfader
Όπως και να 'ναι είναι καινούργιο, άρα μου αρέσει! :107:
Οι γνωστες π@π@ριες της Sony οπως με το PS2. Ποτε δεν καταλαβα τι σκεφτονται. Να τους πουλησω τη γκουμουτσα πρωτα και μετα να το κανω πιο μικρο να το ξαναγορασουν (οι Γιαπωνεζοι εχουν μανια με τα μικρα γενικως, απο διαμερισματα και επιπλα μεχρι σκυλακια τα θελουν ολα μικρα)? Παντως αυτος που ειχε σχεδιασει το αρχικο PS3 ηθελα να μαθω απο τι εμπνευστηκε (απο κανενα VCR μαλλον! http://en.wikipedia.org/wiki/File:N1500_v2.jpg :137:)
δεν υποχρεωνει κανεναν η SONY να το αγορασει! εκτιμησε και με βαση της αναγκες της αγορας προχωρησε στον επανασχεδιασμο με σκοπο την μειωση του μεγεθους και του κοστους, η προσωπικη μου γνωμη ειναι οτι το μεγαλο PS3 εχει το ιδανικο μεγεθος για να ανταποκρινεται στην σωστη μεταφορα του ζεστου αερα μενει να δουμε κατα ποσο το καινουργιο διαχειριζεται σωστα τον θερμο αερα και μην την τυχον εχουμε εκει δραματα με αυξηση θορυβου του ανεμιστηρα οπως στο XBOX Arcade.
Μπορει να μην υποχρεωνει κανενα να αγορασει, αλλα το να βγαζει μια πιο εμφανισιμη συσκευη δεν ειναι και πολυ ωραιο για καποιον που ειχε αγορασει το αρχικο PS3 (και το κανει κατα συστημα οπως φανηκε και απο το PS2). Σα να σου λεει κοιτα τι πουλαω τωρα και κατσε εσυ με τη γκουμουτσα...
Το 360 ειναι αλλη περιπτωση καμια σχεση με το PS3 δεν εχει αλλαξει ΚΑΘΟΛΟΥ εξωτερικα η συσκευη, μονο εσωτερικα εβαλαν καλυτερα υλικα για να μην εχει τα προβληματα των πρωτων εκδοσεων...
Παντως ειναι και θεμα γουστου.
Προσωπικα μου αρεσει πολυ καλυτερα το παλιο απο το slim.
+1
Το παλιό είναι πολυ classy! και πάει και με το piano black της Kuro (αν είχα...)
πάντως δεν μπορώ να καταλάβω την λογική το παλιό να έχει ακριβότερα απο το νέο. Θα μειώσουν λέει την τιμή στα επίπεδα του νέου. Δηλαδή θα υπάρχει η νέα μούρη με 120άρη σκληρό και θα πάρει κάποιος το παλιό με την ίδια τιμή και με μικρότερο δίσκο?
Πάντως το καινούριο είναι καινούριο. Και στην τεχνολογία αυτό πάντα παίζει το ρόλο του (ακόμα και για τη μεταπώληση)
Όμοια και εγώ, αν και από φωτογραφίες δεν μπορώ να έχω άποψη.
Slim PS3 Bitstreams Dolby TrueHD and DTS-HD
PlayStation 3 Without any fanfare or even a passing mention in its official announcement, the upcoming slim PS3 is getting an additional feature, one long requested by those who use the console as a Blu-ray player: it will be capable of bitstreaming DTS-HD and Dolby TrueHD to a compatible receiver for it to decode those advanced audio signals.
This has been revealed by Engadget, quoting a story posted on Japanese electronics site Impress Watch.
The regular PS3 can't bitstream advanced audio codecs because its HDMI transmitter chip doesn't support it. Therefore, unlike the addition of DTS-HD decoding or BD-Live support, a new firmware cannot add advanced audio bitstreaming to existing consoles.
It has been long argued that there is no difference between decoding an advanced audio signal on the player or on the receiver, provided they both follow the specification. However, many users insisted they wanted to decode in their receivers and were unhappy that the PS3 didn't offer them that option. Now, with the slim PS3, they can choose whether to decode in the console or in the receiver.
http://www.engadget.com/2009/08/21/ps3-slim-bitsreams-dolby-truehd-and-dts-hd-ma-audio-at-last/
http://av.watch.impress.co.jp/docs/news/20090821_309899.html
Review
http://www.engadget.com/2009/08/27/playstation-3-slim-review/
Παντως με την προσθηκη του HD audio οφειλουμε να ομολογησουμε οτι το PS3 slim ειναι ενα εξαιρετικο blu-ray player (σε αντιθεση με το PS2 που ηταν μετριοτατο dvd-player), αν εξαιρεσουμε την ελλιπη υποστηριξη ορισμενων τυπων αρχειων (.mkv :118:)
xfader
Re: Απάντηση: Δειτε το NEO slim PS 3 !!
Ξεκίνησε στο plaisio! Για πείτε, αφού έχουν την ίδια τιμή, γιατί κάποιος να πάρει το παλιό?
Κάποιοι "αντιρρησίες", λένε ότι προτιμούν το παλιό.
Βρίσκει λοιπόν ευκαιρία η Sony και τους το πουλάει στην ίδια τιμή, από το να κάνει προσφορές για ξεστοκάρισμα. :109:
Katerinanota
