EMU 1212m V2 ΚΑΡΤΑ ΗΧΟΥ
Όποιος θέλει ας κάνει και μια σύγκριση με τα specs των BENCHMARK DAC 1 και CAMBRIDGE AUDIO DACMAGIC, γιατί εγώ την έκανα, (όσο μου κόβει), και έπαθα... σοκ!
:107:
Για πάρτε και μερικά specs, (1212m), να μην σας βάζω να ψάχνετε και σας ταλαιπωρώ...
Technical Specifications
General
Sample Rates: 44.1, 48, 96, 192kHz from internal crystal or externally supplied clock (no sample rate conversion)
Bit Depths: 24-bit I/O, 32-bit processing
PCI Specification:
- PCI 2.2 Compliant
- Form Factor: Universal Keyed, Short PCI Card
- 3.3V I/O, 5V Tolerant
- PCI Bus-Mastering DMA subsystem reduces CPU usage
E-MU E-DSP™ 32-bit DSP with 67-bit accumulator (double precision w/ 3 headroom bits)
Hardware-accelerated, 32-channel mixing, and multi-effects processing
Zero-latency direct hardware monitoring w/effects
ASIO 2.0, WDM/MME/DirectSound Drivers
EDI (E-MU Digital Interface) proprietary 64-channel audio link over CAT-5 cable
Anti-Pop speaker protection minimizes noise during power on/off
Ultra-low jitter, clock subsystem: < 1 ns in PLL mode (44.1kHz, Opt. S/PDIF Sync)
Analog Line Inputs (2)
Type: servo-balanced, DC-coupled, low-noise input circuitry
A/D converter: AK5394A
Level (software selectable):
- Professional: +4dBu nominal, 20dBu max (balanced)
- Consumer: -10dBV nominal, 6dBV max (unbalanced)
Frequency Response (20Hz - 20kHz): +/- .05dB
Dynamic Range (1kHz, A-weighted): 120dB
Signal-to-Noise Ratio (A-weighted): 120dB
THD+N (1kHz at -1dBFS): -110dB (.0003%)
Stereo Crosstalk (1kHz at -1dBFS): < -115dB
Analog Line Outputs (2)
Type: Balanced, low-noise, 3-pole low-pass differential filter
D/A converter: CS4398
Frequency Response (20Hz - 20kHz): + 0.0/-.35dB,
THD+N (1kHz at -1dBFS): -105dB (.0006%)
Digital I/O
S/PDIF:
- 2 in/2 out coaxial (transformer coupled)
- 2 in/2 out optical (software switched at ADAT)
- AES/EBU or S/PDIF format (software selectable)
ADAT:
- 8 channels, 24-bit @ 44.1/48kHz
- 4 channels, 24-bit @ 96kHz (S-MUX compatible)
- 2 channels, 24-bit @ 192kHz
MIDI:
- 1 in, 1 out
Synchronization
Internal crystal sync at 44.1, 48, 96, 192kHz
External sample rate sync via
- ADAT (44.1 - 192kHz)
- S/PDIF (opt. or coax 44.1 - 96kHz)
:107:
Απάντηση: EMU 1212m V2 ΚΑΡΤΑ ΗΧΟΥ
Για δείτε τι ανακάλυψα:
"Later on (when we finally laid our hands on 1212M soundcard, one of those featuring CS4398 DAC) the straight-forward censorious audio quality comparison in the balanced mode demonstrated that 1212M was not outscored by our reference card LynxTwo ($1000). Both cards performed identically great (at least with our $1500 studio monitors) and offered excellent quality, which was noticeably higher than that of other professional soundcards on the good speakers."
Aυτό θα το βρείτε εδώ:
http://ixbtlabs.com/articles2/digests/sound2k4.html
:107:
Διόρθωση jitter, (αν έχει κάποια σημασία): αλλού αναφέρεται ότι είναι 576 ps και όχι 596 ps όπως ανέφερα στο post # 8.
:203:
Kαι χωρίς υποχρεωτικό upsampling/oversampling! Kάνει ακριβώς αυτό που θέλεις!
:107:
Βλέπω ότι υποστηρίζει όλα τα κοινά sampling rates, αλλά δεν βλέπω πουθενά να υποστηρίζει τα 88.2 KHz.
Γιατί ;
... με ηχεία αξίας $1.500 :112:
2)E-MU 1212m: 576 ps
Kαλά τι τρομερό πράγμα είναι αυτό; Δεν μπορώ να συμφωνήσω μετά του εαυτού μου! :140:
Ε-MU 1212m JITTER=596 ps
και ζητώ συγνώμη!
:120:
Δείτε και το αδερφάκι της 1820m με το ίδιο dac αλλά εκτός PC:
NOISE: -144,7 db !!!
DYNAMIC RANGE: - 133 db !!!
THD: 0,0000 % !!!
IMD + N: 0,0002 % !!!
CROSSTALK: - 146,3 db !!!
IMD @ 10.OOO HZ: 0,0000 % !!!
Αν δεν είναι αλήθεια δεν πταίω και μην βαράτε όλοι μαζί! Αλλοιώς να τρέμουν τα DAC;
:107:
Βρε caravelle με έχεις καταστρέψει με την 1212m μου έχει γίνει εμμονή !!
αν δεν το παρατηρησατε οι εξαιρετικες επιδοσεις στις emu ισχυουν μονο στα 24/48.
Ναι το παρατήρησα απλά είναι η μόνη κάρτα που μου κάνει βάση των εισόδων που παρέχει και φυσικά των εξόδων της.Η Asus δυστυχώς δεν έχει balanced outs οπότε δεν έχω και πολλές επιλογές.Αν έχεις κάποια άλλη πρόταση εδώ είμαι.
Θέλω balanced outs και ins coax , optical , rca και χαμηλό jitter :( δύσκολη επιλογή ρε γαμώτο μου....
Nickk
