Θωρακισμένο καλώδιο ρεύματος; Γιατί;
Απο τον Thomas E. Beardon, Nuclear Engineer ,
EM FIELDS, ACTION, CREATION, and TIME
Every physical change of a charged particle (from proton to neutron to electron) constitutes a modulation imposed upon its virtual photonic activity creating its electromagnetic field. These modulations collect, become coherent, and breach the threshold of the virtual dimension. It, in turn, amplifies the signal or information, passing to the frame of the electromagnetic field. The EM field plays an integral role in coupling the virtual state reality to observable state reality.
Action, according to physics, is the fundamental constituent of physical reality. In metaphysics, action is the agent of karma, producing natural consequences. Action is non-observable; only changes in action are observed, and then only partially. The photon is the basic quantum of action, uniting energy and time.
All physical things are composed of rates of changes in action. These action changes are totally internal to the mass itself. Therefore, literally, the physical universe exists inside each and every part of itself, and is a giant hologram.
An ordinary photon has a certain size that is quite fixed, and it is made of the substance "action" which is totally nonperceivable and nonobservable. Only changes in action are perceivable, observable, or detectable, never fundamental action itself.
So physics already prescribes a universe made out of action, and that universe has no length, no time, no energy, no space, no concrete existence. Yet from it can be taken--by differentiation (which is simply separation)--any length, any time, any energy. However, only a single quantum at a time changes or is separated. Quanta do not superpose.
At its most fundamental level, the entire universe is continually being created and then destroyed in sequence. The continual creation of a tiny piece of time and then the destruction of the piece of time makes us experience reality or change as if we were a pointer moving along a time line.
We cannot see time because it is continually being destroyed by the change process, the very process of physical detection or observation itself. This is similar to the annihilation of a photon when it hits the retina and becomes absorbed.
Now, if we invoke another kind of change, a virtual change, such that its size is always smaller than the actual quantum's size, then this kind of change cannot be detected, even theoretically. The concept of a virtual change is one such that the quantity of action that was changed was deliberately made smaller than the size required to throw the switch of detectable or observable change. It is an infinitesimally small perturbation.
Individually, virtual photons cannot breach the threshold of quantum change, and so cannot be observed or detected. But in concert, they do breach the threshold. The totally unobservable, undetectable virtual photons being emitted and absorbed are conceived as creating the electric field at the same time as observable physical change (ordinary quantum change) occurs.
The electric field, of course, can cause or induce change of sufficient magnitude to breach the quantum threshold and result in observable change. The bottom line is this: the virtual state can be collated and collected to sufficient magnitude to breach the quantum threshold and induce ordinary observable physical change. The electromagnetic field already does precisely this!
We can coherently collect the virtual state to produce matter or its anti-matter, which after all are nothing but macroscopic assemblages of quantum changes, and we can thus get free energy, materialization and dematerialization, teleportation, and antigravity by means of special modifications and development of electromagnetic circuits.
Each photon carries a small piece of time. And the entire virtual state reality is hanging onto that small piece of time as a modulation. That is where the probabilities are riding, in terms of the ordinary monocular interpretation of quantum mechanics. All the probabilities and possibilities are concretely real and occupy orthogonal universes. Since they all share the same single time dimension, there is a TIME BRIDGE OR TIME CHANNEL [QM wormholes] connecting the universes.
Each move or change in one of them crosstalks a tiny bit into each of the others. Since it is the photon which carries them, then each photon contains all possibilities and virtual states modulated upon itself. Photon interaction thus involves the communication of these possibilities and virtual states to the object with which the interaction occurs.
The virtual state psychotronic modulations of the mass's electric field are now riding on the virtual photons that generate that field.
Every possibility concretely exists in that manner, in the virtual state, timewise hanging into the time dimension of the detected physical world's four-space frame, but spacewise hanging out of the ordinary three-space physical universe of objects. So indeed all possible realities, even the wildest and the most farfetched exist in the virtual state.
THE TIME CHANNEL IS QUITE LITERALLY THE PARANORMAL CHANNEL THAT CONNECTS THE NORMAL SPATIAL WORLD TO AN INFINITY OF NON-NORMAL SPATIAL WORLDFRAMES. Only by the continual destruction of each piece of created time (by fusing it back together with the piece of energy involved, and forming a quantum which is unperceivable) are we able to experience physical reality at all, uncluttered and relatively free from the vast hordes of infinite realities through which the ship of quantum-change physical reality sails.
Since the electromagnetic field represents a collection of this vast array of realities, then by proper selection (i.e., by coherent tuning) of multiple stages we should be able to select a particular virtual reality channel. And indeed so we can. Any scheme for drastically increasing signal-to-noise ratios should be adaptable to such a collection mechanism for the detection of bioenergy.
Απάντηση: Re: Απάντηση: Θωρακισμένο καλώδιο ρεύματος; Γιατί;
Εκτός αν πέσεις σε κλειστοφοβικούς αγωγοί που δεν αποδίδουν καλά όταν τους στριμώξεις με θωράκιση.. :143:
Εχει παραθυρακια, μπρος - πισω.
Απάντηση: Re: Θωρακισμένο καλώδιο ρεύματος; Γιατί;
χάθηκε η μπαλα , STOP.
To γήινο μαγνητικό πεδίο είναι ακόμη ισχυρότερο.
Σε ποιες συχνότητες αναφέρεσαι?
Χάθηκε η μπάλα, STOP !
Σας χρειάζεται επειγόντως μια ξεχωριστή κατηγορία που θα ονομάζεται "high-end" να τα λέτε μόνοι σας και να μην σας ακούμε !
Ισως να χαθηκε η μπαλα,
Και κατι που ειναι Ελληνικο και off topic, αλλα μου αρεσε!
In ancient Greece (469 - 399 BC), Socrates was widely
lauded for his wisdom. One day the great philosopher
came upon an acquaintance, who ran up to him excitedly
and said, "Socrates, do you know what I just heard about
one of your students...?"
"Wait a moment," Socrates replied. "Before you tell
me, I'd like you to pass a little test. It's called
the Test of Three."
"Test of Three?"
"That's correct," Socrates continued.
"Before you talk to me about my student let's take a
moment to test what you're going to say. The first
test is Truth. Have you made absolutely sure that what
you are about to tell me is true?"
"No," the man replied, "actually I just heard about it."
"All right," said Socrates. "So you don't really know
if it's true or not. Now let's try the second test,
the test of Goodness. Is what you are about to tell me
about my student something good?"
"No, on the contrary..."
"So," Socrates continued, "you want to tell me
something bad about him even though you're not certain
it's true?"
The man shrugged, a little embarrassed.
Socrates continued, "You may still pass though because
there is a third test - the filter of Usefulness. Is what you
want to tell me about my student going to be useful to me?"
"No, not really..."
"Well," concluded Socrates, "if what you want to tell
me is neither True nor Good nor even Useful, why tell
it to me at all?"
The man was defeated and ashamed and said no more.
This is the reason Socrates was a great philosopher
and held in such high esteem.
Θα συμμορφωθουμε... αφου κρινετε οτι μας..χρειαζεται επειγόντως...και θα... μιλαμε με pm για να μην ενοχλουμε...
the Test of Three."
"Test of Three?"
it's true?"
"No, not really..."
it to me at all?"
Είσαι πολύ ωραίος ΝΙΚΝΜ
jabe
