Ayre Acoustics QB-9 USB DAC
Features
Asynchronous transfer mode for USB input. (white paper)
Minimum phase digital filter. (white paper)
Single-pass 16x oversampling.
Zero feedback, fully balanced discrete circuitry.
Equilock circuitry for active gain devices.
Ayre Conditioner (patent pending) power-line RFI filter.
AyreLink communication system.
Specifications
Maximum Output Level
2.05 V rms – unbalanced outputs
4.10 V rms – balanced outputs
Frequency Response
DC - 20 kHz (44.1 kHz sample rate)
DC - 22 kHz (48 kHz sample rate)
DC - 40 kHz (88.2 kHz sample rate)
DC - 44 kHz (96 kHz sample rate)
Signal/Noise
110 dB (unweighted)
Input
1 USB, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz (up to 24 bits)
Dimensions
8.5" W x 11.5" D x 3" H 21.6 cm x 29 cm x 7.6 cm
Weight
5 pounds 2.25 kg
Πηγές:
Ayre
Tέστ στο Stereophile
Τιμή 2500$:108:
Πάντως λειτουργεί σε asynchronous mode και έχει μόνο μια usb ως είσοδο
Eπισης και στο computeraudiophile
The QB-9 asynchronous USB DAC is Ayre's first entry into the USB DAC market. Based on performance Ayre has hit a home run on its first plate appearance. Asynchronous USB is currently the technology to beat in the USB DAC arena. Ayre made a very wise decision to release a product when the time and technology was right. Ayre did not go down the adaptive USB path just to release a product and sell units in a down economy. Again you're not going to get Ayre's all-out assault for $2500, but you will get a DAC that is incredibly pleasing and accurate. A sense of ease emanates from the QB-9. This translates into wonderfully relaxing listening sessions where one can forget about the components and get lost in the music without even trying. I hope listeners have a couple hours to spare each time they sit down to listen via the QB-9. Time flies when Sonny Rollins is whaling on his tenor sax or Beck is weaving a unique story with his lyrics and great sounding instruments. Thanks to Ayre for contributing to my musical enjoyment over the last few months and congratulations for making the Computer Audiophile Suggest Hardware (CASH) list with the QB-9 asynchronous USB DAC.
Aλλά 2500 ρε γαμωτο....!!!
Μια χαρά όμορφο κουτί έχει...
αλλά δεν μπαίνω στο πειρασμό να κρίνω το περιεχόμενο του με βάση τα 2500 ντόλαρς:126:
Μπές,μπές:116:
Κάποιο σχετικό κόστος βέβαια έχει και το κάτοθι:
For the QB-9, Ayre has licensed the asynchronous technology developed by Wavelength's Gordon Rankin for the TAS1020B chip.
Το κόστος των συγκεκριμένων <<δικαιωμάτων>> δεν μπορώ να το γνωρίζω.
Σίγουρα όμως το αναλογούν, σε μία συσκευή, πόσο θα είναι μικρό.
Σκέψου πως οι πολυκάναλοι ραδιοενισχυτές των 350 ευρώ έχουν επάνω τους ένα σωρό τέτοια.:138:
Απάντηση: Re: Ayre Acoustics QB-9 USB DAC
Έλα ρε, άμα έκανε 1000 ευρά, θα ήταν όμοιος αυτουνού του Benchmark με τους τελειωμένους τελεστικούς, και θα έπαιζε χάλια. Ενώ τώρα, άμα μπήξεις δυόμισυ χιλιάρικα, θα παίζει υποχρεωτικά καλά. Dig it?
VLASSIS-S
Sιγμοειδής Νέμεσις
Απάντηση: Ayre Acoustics QB-9 USB DAC
Το ακουσε καποιος στην εκθεση να μας πει εντυπωσεις?
DAMBO
