Ήμαρτον Αυτοί Οι Αμερικάνοι....Vol II......
Spinner Exhaust Tip - Pimp your exhaust pipe
The Spinner Exhaust tip is a spinner for your exhaust pipe, though not as high tech and expensive like the Pimpstars LED spinners it will surely turn heads. As you step on the gas the spring-loaded spinner is also pushed out of the exhaust tip, giving a visual indication of the revving engine. For a variety of cars with electronic fuel injection engine control, the Spinner Exhaust Tip has the beneficial effect to eliminate the initial hesitation of the engine under rapid acceleration. Made from stainless steel it does not corrode due to the exhaust gases.
The Spinner Exhaust Tip is available in different shapes and sizes to be used with all standard exhaust pipes of cars. Spinners shaped as turbine, flare and other designs meet your preference for an eye-catching accessory. Prices start at $ 44.95
Θέλετε να δείτε τι Αμερικανιά βρήκα πάλι??? Χε,χε,χε......
Μα να μην υπάρχει ένας αντιπρόσωπος στην Ελλάδα να πάω να πάρω κι εγώ σαν παιδί??
Ακόμα και στην ZΖR θα έβαζα......
Και αν καίγεστε τόσο πολύ να το αγοράσετε κάντε τις πληρωμές σας εδώ
Όσοι το αγοράσετε κατεβάστε τις φωτό εδώ....
Εγώ θα αναλάβω να σας...
  • n_olympios
    Μαντιναδόρος!
geo kok
