Δυο νεες αναβαθμισεις
panosop
Συστημικός
Την επίσημη αναβάθμιση με ημερομηνία 5-12-2005, (χθές δηλαδή), μπορείτε να την κατεβάσετε απο ΕΔΩ και περιλαμβάνει τα ακόλουθα...
Release Notes for ReelVDR 009preview5
Changes against thes latest Preview (4)
These are the most important improvements & changes against the last Preview:
- major improvements in picture quality
- Color settings are korrect now and represent the standard when sliders are at 50%
- Install-Wizard is being executed at the very first start which lets the user make the
most relevant settings
- almost all software ist available in english and german. More languages will follow.
- reworked and vastly improved Menu strukture
- USB Support for external drives
- automatic media-detection now working for almost all supported formats: DVD, (S)VCD, mp3-CD, Audio-CDs
- Support for burning DVDs
- using the new undelete plugin, one can now delete or undelete recordings marked for deletion
more improvements:
- timezones can now be selected correctly (e.g. CET for Central-European-TZ), this way
also automatic switching of daylight-savings works now
- auto-resume for DVD plugin: DVDs are now continued at the last seen state
- 4:3/16:9 switching available at the shift-funktion of the PiP-key
- updates for DiSeqC-setup: with the "expert" key (red button) waits and number of repeats can be adjusted
- handling of CAMs completely reworked. new plugin "reelcam" now seperates CAMs froms tuners
- also CAMs can now be disabled seperately to avoid conflicts
- brightness (and for Lite also color) of frontpanel-LEDs adjustable
- Box is only reacting on Reel remote control
- added support for Texas Instruments ACX & Prism54 based WLAN cards
- support for ogg-vorbis audio files
- digital out working in stereo mode (ac3 aka DD5.1 not working yet)
- manual channelscan
- recordings can now be sorted by date
- improved network performance
- improved performance in vdr and dvd-plugin
- deleted recordings and temporary files (from the burn plugin) will be finally deleted in standby mode
- loudness control now working fast and satisfactory
- configuration of the box is kept when flashing new firmware 1)
- picture distortions on channel-switching eliminated
- bugfixes at CDDA (CD-audio) plugin. Audio-CDs will be played correctly
- Networkdrives working (when using Windows XP as server please select "simple release"
- support for NFS network connections
- all drives (local and remote) will be mounted on /mnt/XX. 2)
- solved problems with low symbolrates 3)
- tons of other small bugfixes and improvements
Remarks:
1) If the configurations should or must be overwritten completely, press the "blue" button
(the one on the rightmost under the display) when the flashing process starts (within the first three bars)
2) there are now four base directories on the harddisk: "video" for (VDR) recordings, "music" for mp3/wav/ogg audio files and "movies" for films. "opt" can be used for installing optional software
3) some older satellites e.g. Tόrksat are sending wrong frequencies, symbolrates etc. If using such a satellite you must turn of "auto-pid-update" in setup
ΚΑΛΑ ΠΑΕΙ...
Δες τι βρήκα εγώ ψάχνοντας λίγο....
Η dr24 έχει πρόβλημα:όταν χρησιμοποιείς το radio ή παίξεις mp3,μέτα έχεις ασπρόμαυρη εικόνα.... :x Η εικόνα μέσω component είναι πολύ καλύτερη από την dr23a
Για την dr25 που βγήκε χθες τίποτα ακόμα...
Τέλος δες και τι άλλο βρήκα ψάχνοντας...:
...the DVB-S2 tuner will be launched late quater 1/early quater 2 2006. At the moment we have no more details of the exact specification...
Δηλαδή , το DVB-S2 tuner για τον reelbox είναι γεγονός και αναμένεται τέλος του πρώτου τετραμήνου του 2006 με αρχές του δεύτερου δηλαδή Απρίλιο με Μάιο.....!!!!
panosop
Συστημικός
το HDTV στο Reelbox με Mpeg4 είναι γεγονός.......!!!!!!!!
"The ReelBox series is equipped with complex special hardware to the decoding and rendition of audio and video material.
With the Equator BSP-15 an efficient DSP (digital signal Processor) is available, to which sufficiently arithmetic performance puts at the disposal, in order to be able to decode HDTV material.
A special chip (FPGA) of focus takes over the image output. If the rendition in the dissolutions of standard 720p (1280 x 720, progressive image output) is supported the at present unclear situation regarding the codecs and specifications, which could be used for the European HDTV by the offerers, makes difficult concrete statements the HDTV ability of playback units for all manufacturers.
With the ReelBox platform accomplished tests resulted in that the representation of highly soluble WM9-Material is easily realizable, also on processing of copy-protected material (DRM).
The H.264-Codec, whose employment appears with several TV offerers, can be played of the ReelBox up to a dissolution of 1080i."
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Πολυ καλα νεα!
Πανο , αυτο που δεν καταλαβα ειναι εαν μπορεις να δεις MPEG4 και τωρα?
Εχεις κανει τις τελευταιες αναβαθμισεις για να δοκιμασεις?
Κάνω απλά "αντιγραφή και επικόλληση" απο τη σελιδα του http://www.zotos.biz/
τα συμπεράσματα δικά σας για τα περίπου 900 ευρώ ..........
15.12.05
Reelbox Light - Μας δουλεύουνε;
Μετά από πάνω από ένα χρόνο αναμονής, παραλάβαμε το ReelBox Light. Φυσικά δεν το περιμέναμε και είχαμε πεισθεί ότι είχαν χαθεί τα όποια χρήματα είχαν προ-πληρωθεί για την εισαγωγή του.
Κάλιο αργά παρά ποτέ, λέμε τώρα.
Το μηχάνημα δεν περνάει απαρατήρητο. Είναι κυριολεκτικά τέρας, μεγαλύτερο και από το Tripple Dragon και αρκετά πιο μεγάλο από το elnan vision. Θα έλεγα μάλιστα ότι το elan χωράει άνετα μέσα στο Reelbox!
Έχουμε και λέμε, 8 κιλά και 800 γραμμάρια χωρίς το σκληρό δίσκο. Μετά τον πρώτο εντυπωσιασμό η απογοήτευση άρχισε να κερδίζει έδαφος. Πριν ακόμα το βάλουμε στην πρίζα, η όλη κατασκευή μας φαινότανε ψεύτικη και ειδικά το front panel (η πρόσοψη) μάλλον για φτηνό παιχνίδι έμοιαζε παρά για μηχάνημα κοντά στα 900 ευρώ ... Ειδικά όταν το βάλαμε στην πρίζα, μάλλον λατέρνα θύμιζε ή καλύτερα κάτι νταλίκες που τη νύχτα μοιάζουν με χριστουγεννιάτικο πανηγύρι. Τώρα δεν κάνω πλάκα, τα φωτάκια μάλιστα αλλάζουν και απόχρωση! Ωραία! Και η LCD οθόνη έδειχνε τα δικά της, "booting" και μπάρες να ανεβαίνουν.
Η επόμενη έκπληξη ήταν η πρώτη εικόνα στην TV, ένα εντυπωσιακό λογότυπο της Reel Multimedia. Μείναμε με το στόμα ανοιχτό. Φυσικά όχι για το λογότυπο, αλλά για το γεγονός ότι τίποτε άλλο δεν γινότανε. Για να εξηγούμαστε, εκτός απο τα φωτάκια που άλλαζαν χρώμα, το LCD που έδειχνε ότι ξεκινάει διαστημόπλοιο και το λογότυπο στην TV, nada! τίποτε, α! ψέματα άνοιγε και το πορτάκι του DVD player.
Ok, το μυαλό γυρίζει και μας λέει, μάλλον δεν έχει λογισμικό, ας μπούμε στο site να κατεβάσουμε. Great! Το βρήκαμε και το version; 0.009 preview 5 ΔΗΛΑΔΗ ΟΥΤΕ ΚΑΝ ΕΚΔΟΣΗ ΒΗΤΑ (beta). Άλλη έκπληξη, η αναβάθμιση γίνεται με το να γράψεις το λογισμικό σε CD και να το βάλεις στον δέκτη την ώρα που μπουτάρει.
15 λεπτά αργότερα κρατάγαμε το cd στα χέρια και το πηγαίναμε για το Reel box. Το βάλαμε στο DVD drive και δώσαμε ρεύμα. Έκανε, δεν έκανε ένα λεπτό να μας το πετάξει έξω. Τα 60 περίπου αυτά δευτερόλεπτα είχαμε σβήσει τοχριστουγιεννιάτκο δένδρο και χαζεύαμε την "φαντασία" όχι του Dinsey, αλλά του Reel box! Τι φώτα, τι ήχοι ! και το LCD ξεκίναγε τον πυρηνικό αντιδραστήρα!
Τελικά μετά την απογείωση του λογότυπου, κάτι έδειξε η TV. Κάτι, μάλιστα πολύ γνώριμο για τους fun της σειράς Star Trek: The Next Gerenation. Είδαμε λοιπόν ένα πολύ γνώριμο σε εμάς περιβάλλον το LCARS ! Για όσους δεν ξέρουν ή δεν θυμούνται το LCARS είναι το 'λογισμικό΄ που τρέχουν οι υπολογιστές πάνω στα διαστημόπλοια την γνωστής αυτής σειράς (κάτι ανάλογο με τα windows θα μπορούσαμε να πούμε, χωρίς όμως τα παράθυρα).
Η επιλογές των μενού είχαν και ελληνικά -τρομάρα τους- και φυσικά επιλέξαμε τα αγγλικά γιατί δεν καταλαβαίναμε τίποτα - μα τίποτα - από αυτά που έγγραφε στα ελληνικά. Μετά από 9 βήματα (γλώσσα και επιλογές ρυθμίσεων) είδαμε κάποιο κανάλι. Για να ακριβολογούμε τα κανάλια ήταν προ-φορτωμένα.
Ωραία, τουλάχιστον κάνει κάτι τώρα αλλά μέχρι εκεί. Κάθε πρόσβαση στο μενού και κάθε επιλογή = reboot! Δηλαδή το μηχάνημα είναι για κλάματα. Έχει πολύ δρόμο ακόμα το λογισμικό να φτάσει το κόστος που ζητάει το μηχάνημα. Μην ρωτήσετε καν για τις λειτουργίες εγγραφής, αναπαραγωγής DVD κλπ γιατί απλά θα απογοητευτείτε. Ένα γερμανικό τανκ που δεν έχει καύσιμα ...
Δεν προτείνεται ούτε για μαζοχιστές! Το διαθέτουμε όμως, για όσους θέλουν να λένε ότι συμμετέχουν στην εξέλιξη ενός προϊόντος ... (γέλια)
Συμπέρασμα; Αν και εφόσον το λογισμικό εξελιχτεί σε εμπορικά επίπεδα και αρχίσει να κάνει τα μισά από αυτά που γράφει το κουτί τότε ναι, αλλά τώρα δεν αξίζει τον κόπο. Θέλει ΠΟΛΥ δουλειά ακόμα να γίνει αυτό που υπόσχεται και αν μετά από ένα χρόνο (γιατί κατασκευή είναι του 2004) το λογισμικό είναι ακόμα στο 0.009 πόσο καιρό θέλει να φτάσει στο v1;
Και για να μην αναρωτιέστε, τα πληρώσαμε τα μηχανήματα αυτά για να τα εισάγουμε (δεν μας έστειλαν δείγματα δωρεάν) έτσι θα είχαμε κάθε λόγο να γράψουμε καλά λόγια για να τα πουλήσουμε, αλλά δεν μας βγαίνει ... από όπου και να το δούμε. [Ένας πελάτης να μας το φέρει στο κεφάλι μας άφησε στον τόπο, άστο καλύτερα].
Μετά από αυτά νικητής είναι ο elanvision. - (τελεία και παύλα)
jabe
