Μια συγκριση...
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
HD-DVD and Blu-ray, A Comparison
Disc Capacity
  • HD-DVD, 15 GB per layer, typically 30 GB per disc
  • Blu-ray, 25 GB per layer, typically 50 GB per disc
  • Advantage: Blu-ray
Maximum Bitrate
  • HD-DVD, 36.55 mbps
  • Blu-ray, 54 mbps
Video Codecs
  • HD-DVD, MPEG-2, MPEG-4, VC1
  • Blu-ray, MPEG-2, MPEG-4, VC1
  • Advantage: Neutral
Video Resolution
  • HD-DVD, up to 1080p
  • Blu-ray, up to 1080p
Audio Codecs
  • HD-DVD, Dolby TrueHD, DTS-HD, Dolby Digital Plus, Dolby Digital, DTS-ES (all required in some form)
    • DTS-HD High Res up to 3 Mbps and DTS-HD Master Audio up to 18 Mbps; Dolby Digital Plus up to 3 Mbps and Dolby TrueHD up to 18 Mbps.
  • Blu-ray, Dolby TrueHD, DTS-HD, Dolby Digital Plus, Dolby Digital*, DTS-ES* (*=required, all others optional, meaning they aren't supported on many players)
    • DTS-HD High Res up to 6 Mbps and DTS-HD Master Audio up to 24.5 Mbps; Dolby Digital Plus up to 1.7 Mbps, and Dolby TrueHD up to 18 Mbps
  • Advantage: HD-DVD
Network Enabled
  • HD-DVD, Required, firmware updates, web-enabled features on disc, etc.
  • Blu-ray, Optional
  • Advantage: HD-DVD
Interactivity
  • HD-DVD, uses HDi, built in persistent storage, two video decoders
  • Blu-ray, Uses BDJ, other features are optional
  • Advantage: HD-DVD
Durability
  • HD-DVD, same as CD and DVD
  • Blu-ray, special hard coating developed by TDK
Studio Support
  • HD-DVD, Paramount, DreamWorks, New Line, Universal, Warner, the Weinstein Company, Studio Canal
  • Blu-ray, Sony Pictures/MGM/Columbia TriStar, Buena Vista, Disney/Touchstone/Miramax, Fox, Warner, Lions Gate
Manufacturer Support
  • HD-DVD, Toshiba, Onkyo, LG, Samsung, Thomson/RCA
  • Blu-ray, Sony, Panasonic, Sharp, Philips, Hitachi, Mitsubishi, LG, Samsung, Thomson/RCA
IT Support
  • HD-DVD, Microsoft, Intel, HP, NEC, Toshiba, Sanyo
  • Blu-ray, Apple, Dell, Benq, HP, LG, Panasonic, Philips, Pioneer, Samsung, Sony, TDK
Player pricing
  • HD-DVD, ~$230
  • Blu-ray, ~440
  • Advantage: HD-DVD
Titles available
  • HD-DVD, ~320
  • Blu-ray, ~320
Conclusion
Blu-ray clearly has an advantage in specs, higher storage capacity and higher maximum bitrate. HD-DVD seems to hold the edge in "market readiness" if that's a real term. All the features you want were required in the spec from the beginning, so you know your player supports it. Man it would be nice if the studios would create discs in both formats so we didn't have to buy two players...
http://www.htguys.com/archive/2007/October26.html
Γιατί για να απολαύσουμε μία ταινία πρέπει να κοιτάμε ένα σκασμό specs?
Τι κι αν το Blu-Ray κερδίζει στα specs; η εμπειρία μας, μας έχει δείξει το αντίθετο στον τελικό νικητή.
Video Codecs
* HD-DVD, MPEG-2, MPEG-4, VC1
* Blu-ray, MPEG-2, MPEG-4, VC1
* Advantage: Neutral
Πόσα Blu-Ray με VC1 έχετε δει; Άλλο αν έχει support. Πόσα έχετε δει;
Durability
* HD-DVD, same as CD and DVD
* Blu-ray, special hard coating developed by TDK
* Advantage: Blu-ray
Ναι... Το είδαμε αυτό...
Network Enabled
* HD-DVD, Required, firmware updates, web-enabled features on disc, etc.
* Blu-ray, Optional
* Advantage: HD-DVD
Δεν καταλαβαίνω εδώ γιατί το HD-DVD κερδίζει. Για τα web features; Και τα firmware updates; Πρέπει να έχω το player μου στο internet για να δω μια ταινία; Firmware updates κανει και το PS3 πάντως...
Απάντηση: Re: Μια συγκριση...
Εξαιτίας της Warner αλλα και της επιλογής αλλων στούντιο που υποστηρίζουν το BD αυτή τη στιγμη υπάρχουν 94 τιτλοι BD με κωδικοποίηση VC1
http://www.blu-raystats.com/index.php
Εγώ περιμένω να βγεί το U5000 της Samsung και μετά ας πάνε να κουρεύονται!! HD να είναι και ούτε που θα προσέχω το κουτί αν είναι μπλέ ή κόκκινο..
Σωστός ο Μήτσος!!!!!!!:respect:
intergrale
