Νέα από την Opera Audio
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Θυμάστε την Κινέζικη Opera Audio???
Λοιπόν παρουσίασε τα νέα της μοντέλα...
Έχουμε και λέμε
Eric-Grand 3-ways floor stand speaker system, bass reflex σχεδίαση, με 3 woofer 6,5" και silk dome tweeter 1", και κατασκευή υψηλής ποιότητας (MDF με ειδικά αποσβεστικα εσωτερικά και crossover με πηνία αέρος κλπ κλπ).
Specifications:
Frequency Response:42Hz-30kHz
Sensitivity: 91dB
Recommended Power: 20-150W
Impedance: 4 ohm
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
CD-120 Linear CD Player
FEATURES:
Non-Oversampling, No digital filter
J-FET/Transisters made of analog filter without any op-amp
Very short signal pass length
Very less number of parts in Analog section
Sampling frequency: 44.1kH/88.2kH (selected manually using remote control unit)
Output voltage: 2.35V
Digital output: 1 group, Unbalanced
To Experience the True Possibility of 16bit/44.1kHz Format
SPECIFICATION:
DAC resolution : 16bit TDA1543
0dBFS signal output : 2.35V RMS
Output Terminals : Gold plated Tube RCA unbalanced
Frequency response : Less than +/- 0.5 dB deviation 20Hz-20kHz
Phase response : Less than 5 degrees deviation 20Hz-20kHz
Signal-to-noise ratio : More than 100dB
Crosstalk : Less than -100dB
Distortion (RCA) : Less than 0.12 %
Remote Control : Philips RC-5 compatible IR system 36kHz modulation frequency
Dimensions / Weight : 8.5cm x 43cm x 32cm (HxWxD) / 10kg
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
A100 Linear Solid-state Integrated Amplifier
Specifications:
Power output : 80W + 80W at 8 Ohms
Minimum load : 4 ohms speakers can be connected.
Input Sources : 5 selectable inputs switched by gold plated relays
Input Terminals : Gold plated Phono/RCA unbalanced
Output Terminals : One set of gold plated speaker terminals each channel
Line level Outputs : Gold plated Phono/RCA unbalanced pre out
Frequency response : - 0.5 dB deviation 2Hz-100kHz
Phase response : Less than 2 degrees deviation 2Hz-100kHz
Signal-to-noise ratio : More than 95dB
Input Sensitivity : 500mV
Distortion : Less than 0.02% ( 20W 8 0hms)
Inter-modulation : Less than 0.01% (19kHz + 20kHz)
Remote Control : RC-5 compatible IR system 36kHz modulation
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Eric-Linear Bookshelf Speaker System
Eric Linear Feature
Woofer
NRSG (None Resonance Surround Geometry)
CBCS(Controled Breakup Cone Structure)
CR(Cooper Ring)
VS(Ventilating Structure)
AMS(Asymmetric Motor System)
FS(Flat Spider)
ADPC(Air Dried Paper Cone)
Tweeter
DB(Dynamic Balance)
FF(Ferro Fluid)
TD(Textile Dome)
Cabinet
18mm MDF/Wood Veneer 18mm
Specifications:
Frequency Response:60Hz-30Khz
Sensitivity:86dB Recommended
Recommended Power:2-60W
Impedance: 8ohm
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
το καλύτερο όμως είναι η νέα σειρά με την ονομασία "Forbidden City" για την οποία δεν έχει ανακοινωθεί τίποτα παράμόνο μία φωτογραφία...
Απ' ότι φαίνετε οι Κινέζοι αρχίζουν να μαθαινουν και design!!!
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
λοιπόν κάποια νέα για την σειρά Forbidden City...
Παρουσιάστηκε στο 6moons τον Ιανουάριο
http://www.6moons.com/industryfeatures/forbiddencity/forbiddencity.html
Αποτελείτε από τα εξής μηχανήματα
Turandot CD player
Burr-Brown PCM1792 DACs
less than 14ps of distributed jitter
S/N ratio better than 120dB
Τιμή στις ΗΠΑ $2400
Calaf 200wpc hybrid integrated
6922-based driver section
40-watt Class A
five remote-switchable inputs (one of them balanced)
damping factor in excess of 1000 and a S/N ratio of 100dB
Τιμή στις ΗΠΑ $3200
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Η Opera δεν σταματά να παράγει νέα μοντέλα, αποδεικνύοντας ότι στην Κίνα ο οργασμός του hi-end καλά κρατεί.
Αυτή τη φορά παρουσίασε τους μονομπλόκ τελικούς ενισχυτές Droplet οι οποίοι φιλοξενούνται σε σασί από ξύλο και μέταλλο σε σχήμα σταγόνας.
Οι ενισχυτές είναι λαμπάτοι push-pull, με ένα ζευγάρι μεγάλες τριόδους 211 να αποδίδει 100Wrms, και πρώτα στάδια με τις 5687 και ECC88.
H απόκρισή του δίνεται στα 100KHz για τη μισή ισχύ του ενώ η τιμή του ζεύγους φθάνει τα $10.000. (Music Lover. 210.2018.941)
http://www.hxos.gr/show_page.php?page_id=1287&cat_id=14
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Οι ασταμάτητοι οι Κινέζοι της Opera Audio παρουσίασαν ηχεία κόρνας (!!!!)
Τα ηχεία ονομάζονται Consonance M-12 και M15 (τιμές $5900 και $8500 αντίστοιχα). Το μικρότερο M-12 χρησιμοποιεί ένα woofer 300mm χάρτινου κώνου με υφασμάτινη ανάρτηση για την αναπαραγωγή των χαμηλών. Για τις ψηλές συχνότητες έιναι εφοδιασμένο με ένα tweeter 510mm θόλου τιτανίου και με μαγνήτες από νεοδύμιο και μαγνήσιο, το οποίο βίσκεται μέσα σε μία κόρνα με άνοιγμα 90°. Η απόκριση του ηχείου είναι 38Hz - 20kHz και η ευαισθησία 97dB/W/m. Οι διαστάσεις του είναι 930x420x450.
Το M-15 χρησιμοποιεί ένα woofer 380mm χάρτινου κώνου με υφασμάτινη ανάρτηση για την αναπαραγωγή των χαμηλών. Για τις ψηλές συχνότητες έιναι εφοδιασμένο με ένα tweeter 720mm θόλου τιτανίου και με μαγνήτες από νεοδύμιο και μαγνήσιο, το οποίο βίσκεται μέσα σε μία κόρνα με άνοιγμα 110°. Η απόκριση του ηχείου είναι 30Hz - 20kHz και η ευαισθησία 98dB/W/m. Οι διαστάσεις του είναι 1085x580x458.
Για να δούμε αν θα έρθει και τίποτε προς τα εδώ...
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
και επιτέλους η δοκιμή των Forbiden City από το 6moons
http://www.6moons.com/audioreviews/fcity/fcity.html
και προσοχή στις τιμές
Turandot CD $2,400; Calaf integrated amp $3,200
Άρα σύμφωνα με την διαφημιστική καταχώρηση του εισαγωγέα σε περιοδικό του χώρου τα συγκεκριμένα δεν έιναι High End. :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
επειδη ετυχε να τα ακουσω αξιζουν λεφτα τους ευκολα........για τα forbidden city μιλαω.....
ωραια κατασκευη και σωστος ηχος....για τα λεφτα τους εχουν λιγο ανταγωνισμο.......
intergrale
