Νέα μοντέλα (;) Monitor Audio: Silver RX
Από το http://community.whathifi.com/blogs...ker-range-more-information-more-pictures.aspx
Και αντιγράφω:
All the speakers use new versions of Monitor Audio's ceramic-over-metal C-CAM driver technology, the developments being brought about by improvements to the Finite Element Analysis the company uses to model the way drivers behave.
The tweeter now has higher sensitivity and wider bandwidth, while the speakers use fine-tuned versions of the Rigid Surface Technology C-CAM mid/bass drivers originally developed for the Gold Signature range. The dimpled profiles are now even more resistant to break-up effects when driven hard.
Also derived from the GS models is the HiVe II reflex port, designed with gun-barrel-style rifling to accelerate the airflow and reduce turbulence.
Ως κάτοχος των silver μου κίνησε το ενδιαφέρον.
intergrale
