Y
Yiannis_B
...ή πώς θα έπρεπε να είναι τα manual, και ποιοι θα έπρεπε να τα γράφουν....:107:
από το εγχειρίδιο χρήσης του Aleph 5....
".....The amplifier does not require any maintenance. While the design is conservative, this is a hard running amplifier, as single ended Class A operation is the least efficient operating mode.
In fifteen years the electrolytic power supply capacitors will get old.
Depending on usage, you will begin to have semiconductor and other failures between 10 and 50 years after date of manufacture.Later, the sun will cool to a white dwarf, and after that the universe will experience heat death.. " :135:
