[h=1]Πωλείται το Pro-Ject 2Xperience Acryl: [/h]
Εδώ το λινκ από τον Ορφέα:
http://orpheusaudio.gr/content/2-xperience-acryl
Εδώ το λινκ από τις Ωδές:
http://www.odes.gr/index.php?page=s...roduct_id=1875&option=com_virtuemart&Itemid=5
http://www.project-audio.com/main.php?prod=speedbox&cat=accessories
Το πικάπ έχει παίξει με Ortofon Rondo Red MC, Ortofon Kontrapunkt a και Dynavector Karat 17 d3 χωρίς κανένα πρόβλημα.
Κατάσταση:
Δίνεται χωρίς κεφαλή όλο το πακέτο
Τιμή πακέτου: 700 ευρώ
Επικοινωνία με πμ ή τηλ 6945859667
Στοιχεία του πλατώ από το site της Project
Turntable
• A quiet running AC motor with a two-step pulley drives the platter's outside edge via a belt.
• The transparent acrylic plinth stands on three height-adjustable Sorbothane®-damped aluminium cones.
• The motor is decoupled from the plinth to reduce vibration transmission.
• The resonance-optimised platter is a sandwich construction utilising the hub, a fine-balanced medium density fibre platter weighing 2Kg, a 4mm thick flat-ground layer of vinyl and a screw-down metal record clamp.
• The platter's low-tolerance chrome-plated stainless-steel axle runs on a Teflon bearing plate in a sintered bronze bearing housing.
• Connection to the phono input of the amplifier can be made with connecting cables of your taste through the gold plated phono sockets and earth screw. A standard cable is provided.
• External power supply avoids potential electro-mechanical interference.
Tonearm 9cc
• The headshell and armtube are fashioned from a single piece of carbon-fibre.
• Conical armtube avoids standing wave reflections.
• Inverted tonearm bearing comprises four hardened stainless tips in ABEC7 spec ballraces.
• Rings provide very solid arm bearing housings. The outside ring is open to avoid resonances.
• Design of counterweight effectively counteracts unwanted resonances.
• The counterweight supplied is suitable for cartridges weighing between 6 - 10g. Alternative counterweights for cartridges weighing between 11 - 15g, 8 - 11g or 5 - 8g are available as an accessory part.
• Counterweight shaft lowered to record level reduces cantilever forces and dynamic wow when playing warped records.
• Solid armbase permits accurate height adjustment of armtube and VTA (vertical tracing angle).
• Single-screw fixing of armtube allows rotation for easy adjustment of needle azimuth despite fixed headshell.
• Silicone-damped armlift can be adjusted to suit working height of the arm.
• The internal wiring consists of flexible high-purity copper from the headshell right through to the gold-plated phono sockets.
- Το πικάπ είχε αγοραστεί από τον Ορφέα στο κέντρο της Αθήνας πριν 3 χρόνια καινούριο, περιλαμβάνει μαύρο μεταλικό κλαμπ και προστατευτικό καπάκι από plexiglass.
- Επίσης είχα αγοράσει και το project speed box που προσφέρεται μεταξύ άλλων και για αλλαγή στροφών του πλατώ χωρίς να χρειάζεται να αλλάξει θέση ο ιμάντας (120 ευρώ).
- Τέλος, πριν από 4 μήνες είχε γίνει ανακαλωδίωση (sixtream της clearaudio) του βραχίονα από το Χρήστο Κοψιά στο studio hi-fi στη Δάφνη που είχε στοιχίσει 150 ευρώ. Αυτή είναι μια αναβάθμιση που προτείνεται στους βραχίονες της Project που προσφέρει ατάκα και περισσότερη διαφάνεια.
Κατάσταση:
- Λειτουργική: 10/10
- Κοσμητική: 9.5/10
Turntable
Tonearm 9cc
