Πωλείται ο δορυφορικός δέκτης Head SD 8500 Challenger High Definition.
Τιμή 120 ευρώ, στην πλήρη συσκευασία του.
2CI + 1 Card Reader
UCAS
DiSEqC 1.0 1.1 1.2 1.3(USALS)
6000 Κανάλια
Blind Scan
1 Sat Tuner MPEG4 AVC 264
Firware Version 29/12/2009
Υποστηρίζει Ελληνικά, Αγγλικά, Γερμανικά...
h**p://www.satellite-heaven.de/testberichte/head-sd-8500-challenger-hd-sat-receiver.htm
Αναλυτικά Χαρακτηριστικά...
# - 2 Common Interface
# - 1 Card reader (multicam)
# - MPEG4 AVC/264 [email protected]
# - Blue display
# - Blind Scan
# - 100 Satellites programmable
# - Max. 6000 Channels. (TV & RADIO Programmable)
# - DiSEqC Support Level 1.0, 1.1, 1.2 and 1.3(USALS)
# - Multi-Picture Function of (4, 9, 13 or 16) Picture
# - SDRAM 128MB
# - SHARP Tuner build-in
# - Excellent Performance
# - MPEG-2 Digital & Fully DVB Compliant.
# - SCPC & MCPC Receivable from C/Ku-Band
# - Program search in automatic, advanced and N.I.T (Network Information Table) Search
# - Extrem quick channel searching
# - Switching time less than 1 sec.
# - Sleeping timer programmable
# - Automatic NTSC/PAL Detection
# - Build-in Measuring instrument of Oscilloscope / Spectrum analyzer function
# - Zoom in/out
# - Multi-Search : more Satellite could be marked and searched
# - Quick button solution for edit channels
# - 8 Favourites Channel group Selection (Move, Music, Sports, Drama, Kids, News, TV1, TV2)
# - Parental Lock of Menu and Channels
# - More comfortable channel sort function as delete, rename or displace
# - Backup & Recovery programmable of Channel List (Backup/Recovery)
# - Support of Teletext and Subtitling
# - Supports user friendly OSD and easy Main Menu.
# - Smart Design with 256 colours
# - 24 Languages OSD Menu
# - Aspect Ratio for 4:3, 16:9 and Letterbox
# - Games
# - Supports Calendar and Biorhythm.
# - Pause programmable
# - Recall programmable: Save the last 10 chose Channels
# - Advanced Channel List Sorting Function (Favorites, Lock, Move, Skip, Transponder,
# - Network, Satellite, A to Z, Z to A and etc.)
# - Supports automatic Turn-On and Off in Timer Settings
# - Find programmable: find your Channels alphabetically
# - Manual PID input (Audio, Video und PCR)
# - Volume difference for every each channel programmable
# - 4-digit LED Blue display
# - 5 Quick colors Button on the RCU for comfortable and quick navigation
# - Quick Button on the Front Panel
# - Software - Upgradeable via RS-232 (PC-to-STB / STB-to-STB)
# - Software Loader and Channel PC Editor supported
# - SatcoDX data transferable from PC
# - Data transfer (Channel List) STB-to-STB
# - Power On/Off Switch
# - Digital Audio 5.1
# - S/PDIF Digital Audio output(Coaxial)
# - 2 x Scart (TV/VCR)
# - 2 x Cinch Audio output (R/L)
# - 1 x Cinch Video output
2CI + 1 Card Reader
UCAS
6000 Κανάλια
Blind Scan
# - Blue display
# - Blind Scan
# - SDRAM 128MB
# - Zoom in/out
# - Games
