Πωλειτε το παραπάνω Panasonic DVD-RV32K σε ΥΠΕΡΑΡΙΣΤΗ κατασταση (καινουριο) με ελάχιστες ώρες λειτουργίας.
>Product Type DVD player
>Enclosure Color Black
>Media Type CD , DVD , CD-R , CD-RW , DVD-R , Video CD
>Converter 10bit / 27MHz
>Audio D/A Converter 24bit / 192kHz
>Media Load Type Tray
>Search Speed Up to 200x
>Picture Modes Normal , Letterbox , Widescreen , Pan and scan
>DVD Repeat Modes Title , Chapter , A-B repeat
>CD Playback Modes Program play , Program repeat , One track repeat , All tracks repeat , Random play / shuffle
>Supported Digital Audio Standards MP3 , WMA
>Picture Zoom Yes
>Video Signal-to-Noise Ratio 65 dB
>Parental Lock Yes
>Resume Function Yes
>Multi-Camera Angle Select Yes
>Multi-Language Select Yes
>Multi-Subtitle Select Yes
>Additional Features Shuttle , Cinema mode , Quick start , Color control , Auto power off , Chapter preview , Contrast control , Subwoofer output , Dialogue enhancer , On-screen display , Brightness control , Video black level expansion , Dual laser optical pickup system.
>Sound Output Mode Stereo
>Surround Sound Effects Advanced Virtual Surround Sound (V.S.S.) >Response Bandwidth 4 - 44000 Hz
>Dynamic Range 102 dB
>Digital Audio Format DTS digital output , Dolby Digital output
>Digital Output Sample Rate 48KHz , 96KHz
>Signal-To-Noise Ratio 115 dB
>Total Harmonic Distortion 0.0025 %
>Compression Function Yes
>Type Remote control
>Technology Infrared
Connector Type 1 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1 x Component video output ( RCA phono x 3 ) - Rear , 1 x S-Video output ( 4 pin mini-DIN ) - Rear , 1 x SPDIF output ( TOSLINK ) - Rear , 1 x Subwoofer output ( RCA phono ) - Rear
Τιμή 80 ευρω...
Διαφορες Πληρ. με πμ.
Ευχαριστώ!!
