Πόσο μας ΚΟΡΟΙΔΕΥΟΥΝ.....??
Well it turns out that when a game box says that it runs in 720p or 1080p it’s not entirely true. Sure you can set it to that resolution but the actual game output resolution is rarely exactly that.
Check out two of the biggest releases of the season for example:
COD4 (360) 1024×600p 2xAA
COD4 (PS3) 1024×600p 2xAA
Uncharted (PS3) 960×1080 in 1080p
Neither Call of Duty 4 or Uncharted run in the actual resolutions.
The reason most games do this is to allow for more visual effects to be rendered to the screen without slowing the game down. Most won’t ever notice or care but it’s kind of interesting to find out the actual resolutions that games render in. Here are some more recent ones along with a huge list of older releases from the pixel counter at Beyond3D.
Def Jam: Icon (PS3) 1152×648
Marvel: Ultimate Alliance (PS3) 1920×1080 FullHD
Transformers (PS3) 960×1080
Pirates of the Caribbean (PS3 720p): 960×720
Pirates of the Caribbean (PS3 1080p): 780×1080
Oblivion (360): 1024×600 (PS3 version is full 720p)
ICO (PS2): 512×224p (less than Tekken on PS1 at 512×240)
VF5 (PS3 720p): 1024×1024 (same as 360)
VF5 (PS3 1080p): 1024×768
Here are some older discoveries from the same thread:
Full Auto 2: 1920×1080 AA 4x, bad framerate - PS3
NBA Street: 1920×1080 AA 4x (30-60fps) - 360
LocoRoco Cocoreccho 1920×1080 MSAA 2x -PS3
Tony Hawk Project 8: 1040×584 AA - 360
Tony Hawk Project 8: 1280×720 - PS3
Virtua Tennis 3: 1920×1080 AA 2x - PS3, 360
XMB: 1920×1080p - PS3
Dashboard: 1280×720p - 360
Perfect Dark Zero: 1138×640p - 360
Halo 3: 1152×640p - 360
Call of Duty 3: 1120×630p 360
Ninja Gaiden Sigma: 1280×720p PS3
Project Gotham Racing 3: 1024×600 360
Tomb Raider: 1024×600 360
Ridge Racer 7:
NBA 07: 1920×1080 - PS3
NBA 08: 1920×1080 - PS3
Tony Hawk Proving Ground: 600p - PS3
Tony Hawk Proving Ground: 720p - 360
GRAW2: 720p - PS3
GRAW2: 720p AA 2x - 360
Super Rub a Dub: 1600×1080 - PS3
GTHD: 1440×1080 - PS3
Super Stardust HD: 1280×1080 - PS3
Skate: 1536×864 - PS3
Skate: 1280×720 AA - 360
Bioshock: 1280×720 - 360
Harry Potter: 1280×720 MSAA 2x PS3 ?
Pixel Junk Racers: 1920×1080 PS3
Heavenly Sword: 1280×720 AA 4x PS3
Blast Factor Demo: 1920×1080 PS3
The Darkness Demo: 1024×576 PS3
Απάντηση: Πόσο μας ΚΟΡΟΙΔΕΥΟΥΝ.....??
Αυτά να τα λέμε και να τα καρφώνουμε πολύ ψιλά να τα βλέπουν όλοι.:prof:
Τελικά μόνο PC για υψηλή ανάλυση;
οσο τα γραφικα ειναι καθαρα και εντυπωσιακα δε με νοιαζει η ακριβης αναλυση που θα χει το παιχνιδι. νομιζω οτι εκει που πιστευουμε πως καλυτερα γραφικα δε γινονται στις κονσολες συνεχεια μας διαψευδουν και βγαζουν κατι ανωτερο.
Έτσι είναι.
Αφορμή γι' αυτή την "έρευνα" φαντάζομαι πως ήταν το Halo 3 που κάποιοι βρήκαν ότι τρέχει natively στα 600p και κάνει εσωτερικό upscaling.
Πάντως αν το παιχνίδι δείχνει γ@μάτο δεν με ενδιαφέρει πόσο ακριβώς είναι η ανάλυση όταν υπάρχουν άλλα στοιχεία που παίζουν πολύ μεγαλύτερο ρόλο (φωτισμός, ΑΑ, frame rate κλπ.). Χτυπάει λίγο άσχημα να μην είναι ούτε 720p τα παιχνίδια στις "HD κονσόλες" αλλά τελικά μικρή σημασία έχει.
Δείτε τί λέει ένας developer της Insomniac:
"The amount of action we're able to put on the screen at 60 frames per second really dwarfs what we were able to do a year ago at 30 frames per second," said Hastings. "What's most exciting is the way things are headed right now I think we'll see just as big a leap from our second generation engine to our third as we did from the first to second."
Looking ahead, he was equally as optimistic: "We're already seeing a big leap in what people are able to do with the PS3 now compared to a year ago, and we're going to see just as big a leap between now and the end of 2008," said the Insomniac Games Chief Creative Officer. "I think we're going to continue seeing major leaps each year in what people are able to do with the machine for at least three or four more years."
Έτσι είναι.
Πιστευω οτι δεν εννοεις για τα γραφικα του Halo 3 οτι ειναι γ@μάτα.
Πιστευω οτι μιλας γενικα.
Γιατι τα γραφικα του Halo μετα την πρωτη πιστα και αλλη μια φορα λιγο πριν το τελος σε μια αλλη πιστα που ειναι αρκετα καλα , ολα τα αλλα ειναι απλα χάλια και επιπεδου του απλου xbox. wall_1
Θεωρητικά μιλούσα, δεν έχω παίξει το Halo 3. Απλά είχε προξενήσει αρκετό θόρυβο αυτή η ιστορία και απάντησε μάλιστα και η Bungie για το θέμα. Φαντάζομαι όμως ότι θα ήταν καλά τα γραφικά και ας μην ήταν top.
Κυρίως είχα στο μυαλό μου το COD4 που επίσης είναι 600p (παρά τις υποσχέσεις της Infinity Ward για 1080p@60fps) αλλά κατά γενική ομολογία έχει απίστευτα γραφικά - το περιμένω από Amazon αυτή τη βδομάδα!
Την καλυτερη επιλογη κανεις. :bravo:
Θα το καταευχαριστηθεις. Αν και λιγο μικρο το solo αλλα η αποσβεση σου θα γινει απο το multiplayer ετσι και αλλιως. :cool_4:
(οταν το παρεις σφυρα να μπουμε μαζι για κανα δικτυακο)
Τωρα πως γινεται να ειναι και τα δυο παιχνιδια στα 600ρ και το ενα να δειχνει χαλια και το αλλο να σκιζει στα γραφικα, πραγματικα δεν μπορω να το εξηγησω. :crazy_11:
mgm
