Συγκριτικο στο cine4home
Ο νικητης ποιος ειναι?Γιατι στα γερμανικα δεν καταλαβα τιποτα:103:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Απάντηση: Re: Συγκριτικο στο cine4home
Ακριβως με την σειρα που εμφανιζονται.
Ομως υπαρχει πολυ μεγαλη περιπτωση αρκετοι να προτιμησουν
την DLP εικονα.
Και εδω ειναι η ομορφια των βιντεοπροβολεων σημερα.
Δεν υπαρχει κακος και δεν υπαρχει τελειος.
Οταν ξεπερασουμε τα τεστ και τις αναφορες τελικα υπερισχυει
η εικονα που προτιμαμε...
Δηλαδη ο infocus νικησε?
Λενε οτι αυτος δεν εχει καλο μαυρο....
Ποια ειναι η γνωμη σου?Ειναι το μαυρο του ετσι οπως το παρουσιαζουν?Γιατι ειχα βρει κατι screenshot αυτου και του benq w5000 και το μαυρο του infocus ηταν γκρι:104:
InFocus X10 Projector: Black Level Performance
Black levels are the InFocus X10's weakness. Keep in mind, this is InFocus's entry level 1080p projector, and it is using TI's Darkchip 1, which, today, is their entry level performance 1080 resolution DLP processor. Black levels are strictly entry level, and no match for example, to the Epson Home Cinema 1080 UB, which has the best overall black level performance of any of the under $3000 home theater projectors. It doesn't stop there, however. Others with a black level advantage include the entry level Optoma's (mostly by virtue of having a dynamic iris). The HD803, also for example, starts with the Darkchip1. Most of the 3LCD projectors near its price (on either side), can do better than the X10, especially on very dark scenes.
Fortunately, that seems to be about the only real weakness of the X10, when it comes to image quality! Shadow detail, is a completely different story.
InFocus X10: Shadow Detail Performance
Wow! Truly excellent! Like its biggest broth
er, it's just fantastic on shadow details. Actually it is even easier to spot the darkest of details than with the IN83, let alone anything else we've tested. Seems that, these days, projectors with so-so black levels tend to have especially great shadow detail resolving ability. This may be due to everything being a little brighter. Still, the details are there - in spades!
http://www.projectorreviews.com/infocus/X10/imagequality.php
Για να δείς ένα σοβαρό και υπεύθυνο τέστ και παρουσίαση.
MaxHeadroom
Απάντηση: Συγκριτικο στο cine4home
Να ρωτησω αν ο sanyo z700 ειναι γενικα καλυτερος απο τον panasonic ax200?
Ασχετως που ο 2ος ειναι 720p, σε επιπεδο χρωματων και γενικοτερα εικονας, ποιος ειναι ανωτερος?
Ο ενας θεωρειται ο καλυτερος 720 lcd και ο αλλος ο φθηνοτερος 1080 lcd ...
Re: Απάντηση: Re: Συγκριτικο στο cine4home
Σοβαρό το projectorreviews.com έναντι του cine4home.de; Αυτό πάει και για "ανέκδοτο της ημέρας"! :142:
Μόλις διάβασα το δεύτερο ανέκδοτο... γιαυτό πάω να κάνω μια γαργάρα γιατί μούδιασα απο το πολύ γέλιο.
Απάντηση: Re: Απάντηση: Re: Συγκριτικο στο cine4home
Άντε τώρα να καταλάβουμε και εμείς που δεν ξέρουμε,
πιο είναι το σοβαρό :121:
Re: Απάντηση: Re: Απάντηση: Re: Συγκριτικο στο cine4home
Όποιον και να πάρεις δεν θα μετανιώσεις.
Στον κύριο Κ., το στοχαστή, πήγε ο μαθητής Τιφ και του είπε.
Θέλω να μάθω την αλήθεια.
Ποια αλήθεια; H αλήθεια είναι γνωστή. Θέλεις να μάθεις την αλήθεια για το εμπόριο των ψαριών;
Αν μάθεις την αλήθεια για το εμπόριο των ψαριών θα πάψεις να πληρώνεις ακριβά τα ψάρια τους.
Γι’ αυτό και δεν θα σου πουν ποτέ την αλήθεια.
Απο τις ιστορίες του κυρίου Κόινερ του Μπέρτολτ Μπρέχτ.
MaxHeadroom
"Δεν είναι κακό να είναι κάποιος ημιμαθής, αφού κατ'ουσίαν όλοι ημιμαθείς είμαστε. Κακό είναι νά'ναι ημιμαθής, να εντυπωσιάζεται από το φανταχτερό και να το υιοθετεί χωρίς να κρίνει το περιεχόμενο. Ότι λάμπει, δεν είναι ρύζι."
Max Hed-Rum, Βουδιστής φιλόσοφος του 7ου αιώνα
:137:
Ο ανώτερος ποιητής λέγει ότι πραγματικά αισθάνεται,
ο μέτριος ότι αποφασίζει να αισθανθεί
και ο κατώτερος ότι πιστεύει πως πρέπει να αισθανθεί.
Φ. Πεσόα.
MaxHeadroom
Φ. Πεσόα.
Α, καλά... :142:
Να σε ενημερώσω λοιπόν -μια που δεν τό 'χεις πάρει χαμπάρι- ότι ο... ποιητής Art Freierman, ο reviewer του "σοβαρού" ProjectorReviews, "αισθάνεται" ότι πρέπει να τα έχει καλά με όλους και γράφει ανάλογα. Έχει πράγματι καταντήσει ανέκδοτο, το γεγονός ότι η στάμπα "ProjectorReviews Award" που αποδίδει στα προϊόντα με κορυφαία επίδοση, μοιάζει νά 'ναι μέρος του template στο οποίο βασίζεται για να γράφει τα άρθρα των δοκιμών.
Νομίζω δεν αξίζει να μπω σε λεπτομέρειες επί της μεθοδολογίας δοκιμών του ενός και του άλλου site, γιατί πράγματι όποιος έχει μάτια -και χρησιμοποιεί λίγο το μυαλό του- βλέπει.
Μια αριστοκρατική στάση.
Ο κ. Κ. Είπε. Έτυχε να πάρω και εγώ κάποτε μια αριστοκρατική στάση.
(Ξέρετε, όρθιος, στητός και περήφανος. Με το κεφάλι ριγμένο πίσω).
Βρισκόμουν βλέπετε στο νερό και η στάθμη ΄όλο ανέβαινε. Επειδή έφτασε στο σαγόνι μου αναγκάστηκα να πάρω αυτή τη στάση.
"...δεν υπάρχει καμία σημαντική σκέψη, την οποία η βλακεία δεν θα ήξερε πως να χρησιμοποιήσει: είναι ευκίνητη προς όλες τις κατευθύνσεις και μπορεί να φορέσει όλα τα φορέματα της αλήθειας. Η αλήθεια αντιθέτως έχει μόνο ένα φόρεμα και έναν δρόμο για κάθε περίπτωση και βρίσκεται πάντοτε σε μειονεκτική θέση... Αν η βλακεία δεν έμοιαζε σχεδόν απαράλλαχτα με την πρόοδο, το ταλέντο... κανείς δεν θα ήθελε να είναι βλαξ"
γράφει ο Ρόμπερτ Μούζιλ το 1931.
stavros.vatistas
