[10ήμερο προσφορών σε Chario 1/4 - 10/4] Chario Academy Sonnet & βάσεις δώρο
Chario Academy Sonnet & βάσεις δώρο - > € 2550,00
Low Frequency Load Back-Firing Vented
Vent Geometry Half-Exponential Hourglass Type
Configuration 2-way Reversed Array
Drivers
1 Tweeter 2 mm SILVERSOFT™ dome NeFeB motor
1 Woofer 1 0 mm ROHACELL® Full-Apex™ Poly-Ring NeFeB motor
Sensitivity 90 dB SPL normalized to 1 m / 2.83 Vrms / de-correlated L/R pink noise within IEC 2 8-1 compliant listening room
Low Frequency Cut Off 55 Hz @ -3 dB referred to C4 WETS
Xover Frequency 1180 Hz
Alignment LKR4 Derived (Df=45°)
Rated Impedance Modulus 4 W (min .2) Argument ± 36°
Size 445 x 2 5 x 40 mm (H x W x D)
Weight 14 kg
Finish Solid Walnut / Solid Cherry /Solid Oak & HDF
Dedicated Stand Weight 13 kg Size 750 x 540 x 460 mm (H x W x D) iron black anodized fi nish (Top Plate & Legs) Varnished HDF (central Section)
Το μοντέλο είναι σε demo , άριστη κατάσταση.
Ionianpower
