ATC 150 ASLT Limited Edition active speakers system
Ultra Audio
Limited edition system brings exceptional focus to a 45-year heritage of innovation and precision engineering…
ATC loudspeaker Technology is proud to announce the availability of the SCM150ASLT, a luxurious marriage of world-class transducer and electronic design engineering, conceived to deliver extraordinary levels of clarity, neutrality, transient response and effortless power delivery.
The 3-way system comprises flawlessly engineered SCM150ASLT speaker towers incorporating the latest ATC designed and built drive unit technology, combined with an ATC P6 power amplifier. SCM150ASLT drivers including the new 25mm neodymium soft dome SH25-76S super dome tweeter, the 75mm soft dome SM75-150S super dome midrange and the SB75-375SL super linear bass driver are driven directly by the six dedicated channels of the P6 dual-mono, 3-way power amplifier, housed in an elliptical billet aluminium chassis, exquisitely machined and finished to complement the impeccable quality of the cabinets.
Manufactured to the highest standard by ATC’s own cabinet makers, weighing 116kg and 1.40m tall, each speaker enclosure is finished in selected European crown-cut walnut veneer with a high-gloss polyester lacquer, and detailed with a stainless steel badge, input panel and bespoke limited edition plinth, PVD treated to create an exclusive nickel-like appearance.
SCM150ASLT Speaker
Deploying proprietary drivers throughout, the 3-way system uses ATC’s new SH25-76S tweeter, featuring both upper and lower suspension for greater operational precision and lower distortion; the latest evolution of ATC’s signature soft dome midrange design, the SM75-150S, and the company’s low-distortion SB75-375SL Super Linear bass driver. Combined they deliver a response accuracy of ±2dB between 60Hz-17kHz and ±6dB from 25Hz to 22kHz across a wide horizontal dispersion and at a maximum SPL of 117dB. The rear-mounted input panel features a single LEMO aerospace-grade 10-pin connector.
P6 Power Amplifier
The P6 is a high-performance Class AB dual-mono power amplifier designed and built by ATC to provide dedicated amplification and optimally matched active crossovers for the SCM150ASLT. It features a total of 6 channels: 2x (200W LF, 100W MF, 50W HF) for a combined output power of 350W/side. Generating a signal-to-noise ratio of more than 105 decibels its ultra-low noise discrete design, paired with 3-way active crossovers with phase equalisation, offers clear and detailed audio reproduction. On the rear panel, professional L/R XLR inputs (from preamplifier/digital source) are joined by aerospace-grade LEMO multi-pin loudspeaker output connectors. Proprietary speaker cables are included with the system.
As is customary with ATC products the SCM150ASLT and P6 are covered by a six-year warranty.
Αποκλειστική διάθεση : Audio Soul Ultra , Λήμνου 8, Δάφνη.
VLASSIS-S
Sιγμοειδής Νέμεσις
Καμία εβδομηνταριαχιλιαδες.
Για δορυφόρος πολύ ακριβός, αλλά ωραίο φινίρισμα ξύλου
Μου λες που την βρηκες αυτην την τιμη?
Γιατι επισημα εχουν σαν πληρες συστημα 46.000 λιρες.
Δορυφόρο με ύψος 1,,40 μέτρα και 116 κιλά έκαστο.???......😂😂😂
Ναι.
Τυπικός δορυφόρος.
Ξέρεις τι ωραία σαμπ έχει η φίρμα γι'αυτους τους δορυφόρους;
Για ρίξε μια κλεφτή ματιά εδώ:
Και για τα 200-αρια και για τα 300-αρια έχει σαμπ η φίρμα, όλα είναι εξαιρετικοί δορυφόροι και τα σαμπ τους είναι ανάλογων δυνατοτήτων.
Δεν ήταν χαζός ο Χατζησταμος ούτε ο Θέμης ο Ζαφειρόπουλος που έβαλαν σαμπ της φίρμας στα εντοιχισμένα 200-αρια.
Εντοιχισμένα παρακαλώ, που ξέρετε όλοι πως κατεβαίνει η απόκρισή τους πιο κάτω από τα ελεύθερα στο χώρο.
Δο
Ρυ
Φό
Ροι
Επίσης έχω κι από άλλες φίρμες να σας δείξω ανάλογα σαμπ, από Γουίλσον μέχρι γουίζντομ.
Μη με τσιγκλατε με τους δορυφόρους.
Μη.
Προστατευτείτε.
Κατά τη γνώμη μου, λόγω του ότι το twitter και το mid δεν είναι στον ίδιο κάθετο άξονα με το woofer, φαίνονται πολύ πολύ "άδεια" ψηλά και γενικά είναι πολύ άσχημα ηχεία (πάντα κατά την ταπεινή μου γνώμη).
Πάντως για να τα 'χουν βάλει έτσι, θα το 'χουν ψάξει το πράμα.
Ναι.
Τυπικός δορυφόρος.
Δο
Ρυ
Φό
Ροι
Μη.
Προστατευτείτε.
Πάντως Γιατρέ οπτικά είναι κάπως, πως να το πω, σαν μονάδες για λαιβ, φαίνονται πιο δεύτερα άσχετα τι παίζουν.
Αυτή είναι όλη η γλύκα αρχηγέ μου.
Παίζουν κάθε δίσκο μουσικής, σα να είναι λάιβ, μπροστά σου η μπάντα.
Τι "δεύτερα", δεν υπάρχουν περισσότερο "πρώτα" από τέτοιο σεταπ, τόσο σε ανάλυση, όσο και σε δυναμικά και αληθοφάνεια.
Τα υπόλοιπα, είναι ραδιοφωνάκια μπροστά σε τέτοια σεταπ.
Ο χαβαλες πάει ακόμα πιο μακριά από όσο φαντάζεσαι, διότι μιλάμε για πολυκάναλο τέτοιο σεταπ.
Πάρε μάτι την μπροστινή τριάδα, κι έχει κι άλλα ο μπαχτσές:
Προφανώς 2 σαμπ τους φτάνουν για όλους τους δορυφόρους. ;)
Ο χαβαλες πάει ακόμα πιο μακριά, όταν μιλάμε για πολυκάναλο τέτοιο σεταπ.
Έτερον εκάτερον
.. ειναι μαυρα μου αρεσουν !!
Τα μαύρα είναι πιο φτηνά από τα ωραία ξύλινα με τη γυαλιστερή τη λάκα, και ταυτόχρονα είναι ταμάμ για εντοιχισμό, κι αν τα φυτέψεις μέσα σε ντουβαρι με μια ωραία ηχοπερατή σίτα από μπροστά με ζωγραφιά τίποτα σε Μπομπ Ρος, θα ζωντανεύουν τα δέντρα μπροστά σου.
Ααααα, μυρίζουν γουεστλεικ, αγαπημένες κόρνες, εύγε, αλλά θέλουν σαμπ κι αυτά.
Έτσι όπως τα έχει, δουλεύουν ως μιντγουφερ.
60-80 σίγουρα θα γκρεμίζουν σπλήνες, αλλά για πιο κάτω θα θέλουν κι αυτά βοήθεια.
C
chrispo
Βάλε και ένα ζευγαράκι σάμπ...και άκουσε μία τα μπροστά και μία τα πίσω...
τι λές ...ποιό θα ¨παίξει ¨?...:rolleyes:
Κοίτα, τα 200-αρια τα atc τα έχω ακούσει καλά και με ποικιλία σε μουσικό πρόγραμμα, και φυσικά με τα σαμπ τους.
Το μπάσο τους, εκείνο που κατάφεραν να βγάλουν στον πολύ περιποιημένο χώρο του Άθενς μαστερινγκ, το έχω ξεπεράσει στο δικό μου σεταπ.
Και με μαρτυρία τρίτου, που επίσης τα είχε φάει με το κουτάλι τα μεγάλα atc.
Κατά 99% έχω ξεπεράσει και τα μεσαιοπριμα τους. Χονδρικά σε αυτό το επίπεδο παίζω.
Εκτιμώ πως τα γουεστλεικ θα τα προτιμούσα.
Ωστόσο, για να έχεις μέτρο σύγκρισης, απέχω γερά στο δικό μου σεταπ από τα μεγάλα Γκέρχαρντ που άκουσα σε πολυκάναλο. Πολύ ατάκα αδερφέ. Πολλά δυναμικά, χαοτικό.
Manosmathiou
