Audiolab 8200cd κελεπουρι...
deleted user 10898
Audiolab introduces the New 8200CD
The Audiolab 8200CD is a fully-featured integrated DAC and CD transport of advanced specification, and impeccable performance. Exhibiting a number of digital inputs including USB, coax, and optical, the 8200CD is the most flexible integrated DAC / CD on the market.
The designers at Audiolab have focused on compatibility with the USB capable of interfacing with a number of media players including WMP, iTunes, and iRiver. Additionally it is capable of playing full HD audio sources up to 24Bit 96kHz through the asynchronous USB design.
Designed around the advanced ESS Sabre32 9018 DAC, the 8200CD delivers optimal sonic performance from digital sources. The ESS DAC in conjunction with Audiolab’s proprietary discrete master clock circuit manages to achieve 100% jitter attenuation within the digital domain. This is expressed through music playback with unrivaled detail and timing.
Comprised of over 1700 components using precision SMT manufacturing on a 4 layer PCB, the Audiolab 8200CD is the most advanced electronic design in Audiolab’s long history.
deleted user 10898
sabre 32 (9018) και ασυγχρονη usb και εισοδους καθε ειδους....
και εχει συνεχεια!!!
προσεγμενο ρολογακι και διακριτο αναλογικο σταδιο εξοδου με fetακια
The 8200CD and 8200CDQ enjoy extremely low levels of jitter thanks to the DACʼs unique coupling with
Audiolabʼs proprietary, discrete master clock, to the benefit of all forms of digital audio. Once converted to
analogue, music signals are passed through a balanced, discrete, Class A FET output stage and on to the
userʼs amplifier via either single-ended RCA or fully balanced XLR outputs. Four-layer PCB (Printed Circuit
Board) construction and 34 regulated power supplies help to maintain optimal signal quality throughout.
deleted user 10898
και προενισχυτης..
In addition to the above, the 8200CDQ adds full preamp functionality whilst maintaining the same chassis
size as the 8200CD. The existing digital inputs are joined by three line-level analogue inputs, providing
source selection and volume control in the analogue domain. The preamplifier section is fully balanced and
all analogue input signals are converted to balanced form, helping to reduce distortion and noise. Class A
gain structures are present throughout, and users may choose between preamplification in the analogue or
digital domain in respect of the digital inputs. In addition, the 8200CDQ adds a direct-coupled, discrete,
Class A headphone amplifier, accessible via a socket on the front panel.
deleted user 10898
και η ολοκληρωση...
The Audiolab 8200CD is available from late August at £699.95, with the 8200CDQ arriving in September at
£899.95. Both models are solidly built with all-aluminium casework and are available in a choice of ʻsilverʼ
(natural aluminium) or classic Audiolab black.
The 8200CD and 8200CDQ are the first of a new generation of Audiolab products. A range of amplifiers is
set to follow, forming the backbone of the all-new Audiolab 8200 Series.
Απάντηση: Audiolab 8200cd κελεπουρι...
Και το θεμα προ, βεβαιως βεβαιως! Με 200 ευρω παραπανω να εχεις και προ και να τα χειριζεσαι ολα απο το τηλεχειριστηριο του σιντι δεν ειναι και λιγο!
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Re: Audiolab 8200cd κελεπουρι...
νομιζω το θεμα πηγη για πολλους ελαβε τελος...
Θα είχε κλείσει αν είχε ενσωματωθεί ένας πλήρως ψηφιακός προενισχυτής.
Ας μην ξεχνάμε ότι σε λίγα χρόνια τα ηχεία θα είναι ενεργά και ψηφιακά αλά Meridian.
deleted user 10898
Re: Απάντηση: Re: Audiolab 8200cd κελεπουρι...
καλα, μεχρι τοτε, εμεις οι απλοι χαζοι θνητοι εμποροπαραπλανημενοι που δεν πιστευουμε οτι οι Pwm κλπ παιζουν καλυτερα ας εχουμε καποιες επιλογες σαν αυτη...
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Re: Απάντηση: Re: Audiolab 8200cd κελεπουρι...
shape of things to come...
http://www.meridian-audio.com/produ...stems/dsp5200-digital-active-loudspeaker.aspx
Re: Απάντηση: Re: Απάντηση: Re: Audiolab 8200cd κελεπουρι...
Αν δεν κάνω λάθος αυτό το ηχείο υπάρχει αρκετά χρόνια και όμως έχουμε δει ελάχιστες αντίστοιχες προσπάθειες.
Προσωπικά αμφιβάλω ότι προς τα εκεί πάνε τα πράγματα. Αν υπεραπλουστεύεται άλλωστε το hobby μας θα σταματήσει να είναι hobby. :126:
ενδιαφερον μηχανημα απο καθε αποψη,το θεμα ομως ειναι η τιμουλα στη χωρα μας
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Re: Απάντηση: Re: Απάντηση: Re: Audiolab 8200cd κελεπουρι...
Δεν υπάρχουν ανάλογες προσπάθειες για διάφορους λόγους:
α) Λόγοι τεχνογνωσίας. Ξέρουμε όλοι τι τεχνογνωσία έχουν οι περισσότερες "high-end" βιοτεχνίες. Λίγοι μπορούν να πάνε προς τα εκεί αυτή την στιγμή.
β) Λόγοι marketing. Αυτό το ηχείο έχει ενσωματωμένα ψηφιακό φίλτρο, ενισχυτές και room correction. Ο μέσος "high-end" βιοτέχνης προτιμά να στα πουλά αυτά χωριστά για να αποκομίσει περισσότερο κέρδος. Επίσης δεν χρειάζεσαι καλώδια ic και ηχείων.
Φυσικά τα πράγματα αλλάζουν. Αν δει κάποιος τις πρόσφατες ανακοινώσεις στα συνέδρια της AES όλο και περισσότερες εργασίες εμφανίζονται με θέμα το ψηφιακό ηχείο (με ελληνικό ενδιαφέρον από τον Ι. Μουρτζόπουλο του Πανεπιστημίου Πατρών).
Θα συνεχίσει να υπάρχει το hobby και μάλιστα σε πιο υγιή πλαίσια. Θα ξεκαθαρίσει το ποιοι έχουν τεχνογνωσία και το ποιοι πουλάνε παπατζιλίκι.
Re: Απάντηση: Re: Απάντηση: Re: Απάντηση: Re: Audiolab 8200cd κελεπουρι...
Ακόμα και αν είναι κάποιος μηχανάκιας νομίζω ότι είσαι λίγο αυστηρός αποκαλώντας τον "παπάτζα". :116:
Στα άλλα δεν διαφωνώ, αλλά αυτή είναι η κατάσταση. Άρα στο άμεσο μέλλον δεν βλέπω κάτι διαφορετικό. :126:
deleted user 10898
ναι βρε Σπυρο, ετσι ελεγαν για τους D, μετα ειδαν οτι οι pwm ειναι καλυτεροι, τωρα χρησιμοποιουν pwm σε συνδυασμο με class A για καλυτερα αποτελεσματα, ασε.... θα δουμε.....
με τον αντιπροσωπο που μιλαγα την παρασκευη το απογευμα περιμενει να πανε καλα-πολυ καλα οι πωλησεις.Σιγουρα δεν ειναι το σουπερ ντουπερ μηχανακι, αλλα σιγουρα ειναι μια ενδιαφερουσα προταση στην κατηγορια που κινηται
deleted user 10898
Re: Απάντηση: Audiolab 8200cd κελεπουρι...
γιατι δεν ειναι το σουπερ ντουπερ? τι θα ηθελες (εκτος απο την ψηφιακη προενισχυση και adc με ψηφιακη riaa για phono πχ?)?
Όντως το μηχανάκι φαίνεται super από τα specs, από κει και πέρα αν κάποιος θέλει μόνο computer audio και δεν τον ενδιαφέρει το high definition εγώ θα πήγαινω (θα πάω δηλαδή) εδώ:
http://www.stylos-sys.com/usb_en.htm
Nίκο εσύ που ξέρεις που να ρωτήσεις, δες το λίγο...;)
Απάντηση: Re: Απάντηση: Audiolab 8200cd κελεπουρι...
για μενα ειναι πριτι γκουντ, απλα σιγουρα καποιοι θα κολλησουν στο ονομα , και εκει θα μεινουν.
Δεν υπάρχουν ανάλογες προσπάθειες για διάφορους λόγους: .......................
Φυσικά τα πράγματα αλλάζουν. Αν δει κάποιος τις πρόσφατες ανακοινώσεις στα συνέδρια της AES όλο και περισσότερες εργασίες .........
Σπύρο, όπως ξέρεις, το άθλημα δεν συμφέρει σε πολλούς να πάρει συγκεκριμένη κατεύθυνση.
Και γιατί άλλωστε?
Υπάρχει λόγος να συμφωνήσουν όλοι γιά σχεδιάσεις, λαμπιόνια, καλώδια κλπ?
Ούτως ή άλλως εκεί έξω υπάρχουν τα πάντα όλα. Ανάλογα με το μυαλό, τη γνώση, το χρόνο, το βαθμό μύησης, την τσέπη, τους 1002 προσωπικούς-υποκειμενικούς λόγους προχωράς.
Θάχε ενδιαφέρον νάχαμε τη δυνατότητα ακρόασης κορυφαίων συστημάτων διαφορετικών τεχνολογιών γιά να εκτιμήσουμε κατά πόσον το αποτέλεσμα -εκεί ψηλά- συγκλίνει ή η κάθε φιλοσοφία στησίματος δίνει κάτι που την ξεχωρίζει απ' τις άλλες.
Ο Κώστας αναφέρει συχνά-πυκνά τα ηλεκτρονικά ματζούνια του που φέρνουν τον ήχο (από οποιοδήποτε αξιόλογο μηχανάκι) κοντά στον όρο υψηλή πιστότητα. Μου λείπει η συγκεκριμένη εμπειρία:126:
Τώρα γιά το παπατζιλίκι..δεν νομίζω ότι θα σταματήσει. Είναι τόσοι πολλοί αυτοι (κατασκευαστές) τόσοι περισσότεροι εμείς (καταναλωτές) που υπάρχει ψωμάκι να μασηθεί, ακόμη.
Eleni Sousani
