Benq 3750 lcd tv 1920X1080! Με 1600 Ευρώ;;;;;
Χρήστος Ακρατόπουλος
The BenQ DV3750 offers the highest brightness rating at 550 nits, for brilliant screen images in your home. The ultra-wide 170-degree view angle of the BenQ DV3750 means friends and family can gather to enjoy watching television together, with everyone getting the "best seat in the house."
The BenQ DV3750 provides a superior contrast ratio of 800:1 that, coupled with gamma correction and BenQ's exclusive Senseye imaging technology, enables them to deliver a full spectrum of colors for digitally rendered screen images that appear just like their counterparts in real life.
The exclusive Senseye is a fully digital image processing system integrating high-definition digital imaging and image calibration technology. Senseye imaging technology purges noise from image signals, restoring true colors, accurately displaying image details, and enhancing picture contrast and depth. The result is screen images that achieve a full three-dimensional sense and convincing realism.
BenQ's exclusive Senseye imaging technology screens out noise from video input signals to eliminate fuzzy signals. Combined with professional color-separation technology, signal loss due to format conversion is minimized to accurately depict brilliant, saturated and natural hues.
Integrating a super-adaptive 3D comb filter, the BenQ DV3750 eliminates input signal distortion and delivers screen images that are cleanly rendered, clear and artefact-free. BenQ's exclusive Senseye imaging technology also ensures each pixel on the screen is accurately tuned, to bring super-sharp and clear images to the viewer.
Combining the super-fast response time with de-interlacing technology, the BenQ DV3750 provides screen images that are stable and uniform, with no motion artefacts. For the best DVD viewing, 3:2 pull-down recovery transparently reformats 24-frames-per-second DVD video into the 50-frames-per-second video used by the PAL/SECAM TV system.
Product Description BenQ DV3750 - LCD TV - 37"
Product Type LCD TV - colour
Dimensions (WxDxH) 102 cm x 12.2 cm x 59.1 cm
Weight 20.3 kg
Diagonal Size 37" - widescreen
TV Type High Definition monitor
PC Interface DVI, VGA (HD-15)
Technology TFT active matrix
Image Aspect Ratio 16:9
Tuner Qty 1
Multi-channel Preview Picture-in-picture (PIP), picture-on-picture (POP)
Sound Output Mode Stereo
Surround Sound Effects SRS TruSurround XT
Power AC 110/240 V ( 50/60 Hz )
Specification
General
Width 102 cm
Depth 12.2 cm
Height 59.1 cm
Weight 20.3 kg
Television
Resolution 1920 x 1080
Widescreen Modes Zoom, Wide
Image Contrast Ratio 800:1
Viewing Angle 176 degrees
Viewing Angle (Vertical) 176 degrees
Pixel Response Time 8 ms
Brightness 500 cd/m2
Comb Filter 3D-Y/C digital
Features Gamma correction, 3:2 pulldown compensation, 3D Edge Correction
TV Tuner
Tuner Qty 1 tuner(s)
Reception System NTSC
Video Features
EDTV Ready Yes
HD Ready Yes
Supported DTV Resolutions 480p, 720p, 1080i, 480i
Audio System
Connections
Connector Type 3 x composite video/audio input ( RCA phono x 3 )
1 x component video input ( RCA phono x 3 )
3 x S-Video input ( 4 PIN mini-DIN )
1 x VGA input ( 15 PIN HD D-Sub (HD-15) )
1 x DVI-HDCP
1 x audio line-in ( RCA phono x 2 )
1 x serial
Power
Power Device Power supply
Voltage Required AC 110/240 V ( 50/60 Hz )
ΤΙΜΗ 1600 ΕΥΡΩ ΣΕ ΑΓΓΛΙΚΟ ΚΑΤΑΣΤΗΜΑ!!!
http://www.komplett.co.uk/k/ki.asp?sku=313532&view=detailed
Stock status: 18 pcs expected on stock 2005-11-15
Ή 2000 δολάρια στην Αμερική!!!
http://www.computers4sure.com/product.asp?productID=3443746&info=Over#tabs
Έχει ακριβώς τα ίδια χαρακτηριστικά με την Philips 9830 δηλ. δεν δέχεται σήμα 1080p παρά μόνο 1080i...
Πάντως μίλησα με την bsi την αντιπροσωπεία της Benq στην Ελλάδα και δεν γνωρίζουν πότε και αν θα φέρουν την τηλεόραση αυτή...
minas
Πισιά
Και μετά μου λένε ότι γκρινιάζω για τις τιμές της Philips!
Με τα λεφτά μιας Philips μπορείς να πάρεις 2 Benq και να τις έχεις stacked :twisted:
Από το link του Δημήτρη:
"Benq DV-3750 LCD-Τηλεόραση με Ηχεία"
Και ΑΜΕΣΩΣ πιο κάτω:
" Περιγραφή:
Η Benq DV3750 είναι τηλεόραση τεχνολογίας πλάσματος..."
Πείτε μου τώρα εσείς τι από τα δύο είναι και αν θα εμπιστευόσασταν την αγορά της από αυτό το site...
http://www.technixx.gr/gruppe.jsp?gruppe=10044
με 1838 Ε
Η τιμή της είναι 1800 Ευρώ + 55 Ευρώ τα έξοδα αποστολής στην Αθήνα...
http://www.technixx.gr/suchergebnis.jsp;jsessionid=F8DCFF36C5B9CD3FFDD9E203C3DA6CA4
Μπορεί να μπει και σε έντοκες δόσεις με πιστωτική κάρτα...
Για την εγγύηση ισχύει το εξής:
Αν έχει οποιοδήποτε πρόβλημα η τηλεόραση εντός εγγύησης το μόνο που επιβαρύνεται ο καταναλωτής είναι τα μεταφορικά έξοδα για Θεσ/νικη. Δηλ. τα 55 Ευρώ. Από εκεί και πέρα όλες οι υπόλοιπες ενέργειες γίνονται από αυτούς... ουσιαστικά δηλ. δεν μας ενδιαφέρει που θα πάει η τηλεόραση και ποιός θα την φτιάξει (προφανώς θα ξαναπάει Γερμανία...).
Ειδικά για τον Βαγγέλη Λάμπρου η ερώτηση:
Οι ρυθμίσεις της τηλεόρασης εκτός από τις κλασσικές (contrast κλπ) είναι:
Αdjust red blue green yellow,
Color Temp.
ACE (Auto Contrast Enhancement)
Noise Reduction
Picture Mode (• Vivid • Standard • Movie • Sports • Personal 1 • Personal 2)
Σου δίνει όπως βλέπετε και 2 προσωπικές επιλογές...
Είναι αρκετές οι ρυθμίσεις αυτές Βαγγέλη;
spylab
Για φαντασου να εχεις αγορασει το ιδιο pannel τα διπλα λεφτα.........
Μετά από την επικοινωνία μου με την Benq - Europe τα νέα έχουν ως εξής:
Μέχρι σήμερα καμία τηλεόραση Benq δεν είχε έρθει στην Ελλάδα γιατί δεν υπήρχε service της εταιρίας για τις τηλεοράσεις της. Για τον λόγο αυτό ο υπεύθυνος μου είπε ότι δεν μπορώ να την αποκτήσω από την Βenq ούτε και power - buy μπορεί να γίνει από το avsite...
ΟΜΩΣ
Από τις αρχές του επόμενου Μαρτίου η Benq αποκτά service στην Ελλάδα και για τις τηλεοράσεις της! Αυτό σημαίνει ότι όλη η σειρά τηλεοράσεων της Benq θα έρθει και στην χώρα μας! Μάλιστα λίγο πριν γίνει αυτό, πήρα την υπόσχεση, ότι θα ενημερωθώ και κατά συνέπεια θα ενημερωθεί και το avsite!!!
Και φυσικά με τιμές παρόμοιες με αυτές του εξωτερικού!!!
:D :D :D
Το μόνο που δεν ρώτησα -αλλά θα ρωτήσω σίγουρα τις επόμενες ημέρες- είναι αν αγοραστεί η τηλεόραση από την Γερμανία, αν θα ισχύει η εγγύησή της στην Ελλάδα...
Τώρα ποιός θα αναλάβει την διανομή και το service των τηλεοράσεων Benq στην Ελλάδα δεν γνωρίζω...
Και το e-mail που έλαβα από την Benq:
"Hi Mr. Christos,
Thank you for your interest in BenQ and we are happy to hear good feedback on our TV!
Due to the service network is not ready in Greece, we don't have the
plan to expand now to Greece.
However, we will inform you of the business status once we establish
the service network.
Best regards,
Riley"
bmavroeidis
