ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
6.4 Lbs.
DLP, Projection System
Native 16:9 WVGA Resolution
1100 ANSI Lumens
2000:1 Contrast Ratio
5-Segment Color Wheel
Model Name PE5120
Display Technology DLP Technology by Texas Instruments
Panel 0.53 12° DMD DMD x 1
Native Resolution WVGA 854 x 480 (16:9)
Resolution Supported 640x350 to 1280 x 1024
Brightness 1100 ANSI Lumens
Contrast Ratio 2000:1
Image Size 26" to 258"
Projection Distance 4.9' to 32.8'
Throw Ratio 52" @ 9.8'
Zoom Ratio 1:1.2
Optical Zoom Manual Zoom, F=2.8 to 2.6
Digital Zoom / Digital Keystone No / Yes
Lamp 200W VIP, 3000 hours lamp life
Compatibility PC, Mac, NTSC, PAL, SECAM
Aspect Ratio 4:3 / 16:9 Screen Selectable
HDTV Compatible Yes
PIP (Picture in Picture) No
Speaker No
Full-function Remote Control No
Presentation Wizard Optional
Carrying Case Yes
Projection Position Front / Rear / Table / Ceiling
Dimensions (WxHxD) 10.3" x 3.9" x 8.5"
Box Dimension (WxHxD) 17.8" x 11.5" x 14.6"
Net Weight 6.4 lbs
Gross Weight 12 lbs.
Warranty 3 years limited warranty with 1st year QXchange
Κυκλοφορει στην χωρα μας σε λιγες ημερες.
Τιμη?Ενα πουλακι μου ειπε...1500 ευρουλακια
