BENQ W30000 LED Home Cinema 1080p Projector
Να και το μπαμ από την Benq, με το διάδοχο του 20000 να ενσωματώνει στα χαρακτηριστικά του, φωτεινή πηγή led, dynamic black, τσιπάκι hqv (μάλλον reon;), 20.000 ώρες λειτουργίας, 600 ansi lumens και ονομαστικό λόγο αντίθεσης 100.000:1. Δεν υπάρχουν ακόμα λεπτομέρειες για την τιμή, αλλά το μόνο σίγουρο είναι ότι μιλάμε για σκοτεινό και ακριβό μηχάνημα, ειδικά για τα μέχρι τώρα δεδομένα της εταιρείας.
http://www.dcviews.com/press/benq-w30000.htm
Targeting high-end home cinema, the W30000 combines Full HD 1080p sophisticated cinema performance with the unparalleled advantages of progressive LED technology. Among the world's first to launch an LED projector lineup that includes luxury home cinema, BenQ raises theater ‘wow' to a new level of immersion: an unrivaled 128% NTSC color gamut (compared to the average 55%-80% NTSC of most projectors) complemented by an extreme 100,000:1 contrast ratio underlies exquisite picture quality and razor-sharp definition. LED-produced images are bolder and more deeply saturated across a broader color gamut, which means the W30000 is able to generate vastly more distinct colors, with each color being extraordinarily richer and more vibrant than conventional projectors. LED also affords 20,000 hours of projection lighting; coupled with BenQ's filter-free DLP design for flawless, never-fade color accuracy, the W30000 provides a near lifetime of enjoyment. Cinematic quality is further supported by BrilliantColor®, DynamicBlack®, 600AL, and Hollywood Quality Video (HQV®). Using Imaging Science Foundation™ calibration standards (ISFccc), each W30000 can be fine-tuned to its unique environment to ensure optimal video performance of various preset applications. Panamorph Lens compatibility further lets users fully duplicate the theater experience with a true widescreen 2.35:1 aspect ratio.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Απάντηση: BENQ W30000 LED Home Cinema 1080p Projector
Αυτα ειναι πολυ καλα νεα!
Ελπιζω με την γνωστη τιμολογιακη πολιτικη της BENQ να δουμε τον
πρωτο "οικονομικο" LED:444:
Αυτα τα 600 ansi σε ολους τους LED ομολογω πως με τρομαζουν
λιγο.
Δηλαδη σε τι οθονες θα πρεπει να βλεπουμε?
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Σε 60" θα είναι μια χαρά.
Και παλι θα υπενθυμισω πως η μαρτυρια που εχουμε για την ποιοτητα
της εικονας αυτων των βιντεοπροβολεων προερχεται απο τον Βαγγελη
ο οποιος ειχε δει τον Vivitek προσφατως.
Εαν θυμαμαι καλα λοιπον μου ειχε πει πως του αρεσε η εικονα συνολικα
αλλα επαιζαν σε σχετικα μικρη οθονη(92'' ? Μην ξεχνατε πως στις
εκθεσεις συνηθως παιζουν σε τεραστιες οθονες)
Re: Απάντηση: BENQ W30000 LED Home Cinema 1080p Projector
λιγο.
Αν είναι 500-600 πραγματικά ansi μετά το calibration, τότε θα είναι υπέραρκετα για μέχρι 120-130 ιντσες σε σκοτεινούς χώρους (dedicated με σκουρόχρωμους τοίχους).
Τα LED έχουν ομοιόμορφο φασματικά φως που σημαίνει ότι δεν έχει και πολύ νόημα η σύγκριση με τις κοινές λάμπες.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Απάντηση: Re: Απάντηση: BENQ W30000 LED Home Cinema 1080p Projector
Ανδρεα μου, ωραιες οι υποθεσεις και μακαρι να ειναι ετσι οπως τα λες.
Ομως να θυμισω ενα screenshot απο τον Vivitek απο την περασμενη
CES σε 70''
Γιατι σε 70'' αραγε?:121:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Θυμιζω πως και ο Vivitek εχει 600 ansi φωτεινοτητα και ιδια
αντιθεση με τον w30000...
MAD
Σιαρτάκιας
Άντε μπάς και δείτε λίγο πραγματικό μαύρο, και σας φύγει λίγο άγχος, από το να κοιτάτε το ρολόι σε κάθε ταινία!!! :142::142::142:
MaxHeadroom
Πολύ σωστά! Εάν χρησιμοποιήσετε τον υπολογιστή που βρίσκεται στην κατηγορία Software, θα δείτε ότι τα 600 lumens αρκούν για να αποδώσουν την -έστω και οριακά- αποδεκτή τιμή των 14 fL σε μια οθόνη 120", ακόμα κι αν αυτή έχει κέρδος ίσο με τη μονάδα.
Το κρίσιμο ερώτημα είναι πράγματι πόσα από αυτά τα 600 lumens μένουν διαθέσιμα μετά τις ρυθμίσεις. Εάν οι LED αποδίδουν φασματικά αυτά που υπόσχονται, τότε το μέλλον τους είναι πολύ ελπιδοφόρο και πολύ κοντά πλέον...
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Καλα, πες λοιπον οτι εμεις θα δουμε μαυρο και θα μας φυγει το
αγχος.
Εσεις τους δικους σας που θα τους πεταξετε, που ειναι και μεγαλοι?:142:
βρε ας βγαλουν ψηφιακο με ΠΡΑΓΜΑΤΙΚΟ μαυρο,σταθερη φωτεινοτητα,πολλες ωρες και λογικη τιμη και και ο δικος μου εχει φυγει ηδη μην ανησυχεις:142:
οπως θα θυμαστε απο την αναφορα στον Projectiondesign υπαρχει καποιο θεμα παντως με αυτη τη τεχνολογια που δεν ειχε υπολογισει κανεις.Οχι rainbow αλλα κατι περιεργα εκανε οπως εγραφε αυτος που τον ειχε δει.
But back to the Kroma. Yes the rainbows are gone, but I could see other color seperation artifacts, which only showed on white objects on a very dark background during pans. They look different from rainbows, but very annoying as well. Some people have been reported before about color seperation artifacts on 3-chip DLPs, created by the PWM of the DMD. I've never seen those under normal viewing conditions, but what I've seen on the Kroma looks just like that. There's no color wheel in the Kroma, so maybe this was created by turning on/off the LEDs. Personally, this would be a deal killer for me. But again, I'm very sensitive to these kind of artifacts, so anyone who can live with a 1-chip DLP won't have any issue with this one.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Δημητρη, με ολη την καλη διαθεση, εαν δεν δω δεν πιστευω.
Καποτε στις δεκαετιες 70 και 80 ηταν πολυ "της μοδος" η
αγορα Ντομπερμαν.
Οι εκτροφεις αλλων ρατσων, για να σταματησουν το φαινομενο
διεδωσαν πως η ρατσα, μετα απο ορισμενα χρονια, "τρελλαινεται"
Εχεις δει ποτε κανενα Ντομπερμαν να τρελλαινεται?
Εχουν περασει 6 απο τα χερακια μου και γνωριζω αλλους 50 κατοχους
και ποτε δεν υπηρξε ουτε...καταθλιψη:142:
Με αυτο θελω να πω πως ειναι μια νεα-παλια τεχνολογια που
καταργει τα μειονεκτηματα της παλιας(RBE)
Ας δουμε λοιπον και ας κρινουμε μετα...
Αυτή η τιμολογιακή πολιτική ήταν της BENQ, ή της Ελληνικής αντιπροσωπίας;:121:
Γιατί άμα είναι το δεύτερο, δεν μου αρέσει τώρα που άλλαξε!
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Για πες, εχεις δειγματα της νεας πολιτικης?
Προσωπικά δεν έχω, αλλά διαβάζω για αυξήσεις τιμών, και παραγγελίες
που καθυστερούν ενώ τους έχουν δώσει ημερομηνία.
Μιλάω για τον W5000.
αγορα Ντομπερμαν.
δεν διαφωνω καθολου.Ειμαι ο πρωτος που θελω να πετυχει αυτη η τεχνολογια.Εξ΄αλλου αυτα που γραφει ο τυπος αυτος δεν σημαινει οτι αφορουν την τεχνολογια μπορει να αφορουν μονο το μηχανακι της projectiondesign.
MAD
Σιαρτάκιας
αγχος.
Εμάς κύριε, αν θέλετε να ξέρετε, θα μας πληρώσουν οι γύφτοι για να τους πάρουν (λόγω βάρους βεβαίως)!!! άσε που τα Αμερικανά αγοράζουν ακόμα!!!! :143::143::143:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
... άσε που τα Αμερικανά αγοράζουν ακόμα!!!! :143::143::143:
Σαφως!
Τα...Αμερικανα ειναι πολυπολιτισμικη κοινωνια.
Εχει και...αφρο-αμερικανους:121:
Μερικές επιπλέον παρατηρήσεις:
1) Ο προβολέας, κατά τα φαινόμενα και τις μέχρι τώρα προδιαγραφές του, φαίνεται να αποτελεί λίγο-πολύ έναν άτυπο κλώνο του Vivitek, εξ' ου και οι ομοιότητες στα χαρακτηριστικά.
2) Η φωτεινότητα είναι ένα ζήτημα που πρέπει σύντομα να αντιμετωπισθεί. 600 ansi lumens, είτε πραγματικά, είτε όχι, απλώς δεν επαρκούν. Ο απαιτητικός βιντεόφιλος δε θα κάθεται με το φωτόμετρο στο χέρι, να υπολογίζει το αν το φως είναι αρκετό για να γεμίσει η οθόνη του, πόσο μάλλον όταν δε μιλάμε για φθηνό μηχάνημα. Απλώς, θα προσπεράσει, μέχρι να δωθεί λύση. Για τον ίδιο λόγο, δε βλέπω σύντομα τα led να υιοθετούνται από πραγματικά hi-end μηχανήματα, τύπου lumis.
3) Τα led, όσο βελτιωμένη φωτεινή πηγή και να είναι σε σχέση με τη λάμπα, εξακολουθούν να μην είναι μια απόλυτα καθαρή και ελεγχόμενη πηγή φωτός (όπως π.χ. τα laser) και έχουν με τη σειρά τους τα δικά τους μειονεκτήματα. Πέρα απ' το ότι δεν είναι αρκετά φωτεινά (προς το παρόν, τουλάχιστον), υπάρχουν και εδώ αναφορές για πτώση (έστω και ελάχιστη) της απόδοσης σε βάθος χρόνου, όπως και αξιοπιστίας (ιδίως για αυτά του μπλε χρώματος). Επίσης, από όσα έχω διαβάσει και η φασματική τους απόδοση, υπολείπεται του laser. Δεδομένου βέβαια ότι τα τελευταία παρουσιάζουν τις δικές τους τεχνικές δυσκολίες προς επίλυση και δύσκολα θα τα δούμε σε οικιακές εφαρμογές πριν από μια δεκαετία, τα led αποτελούν μια καλή μεταβατική πρόταση.
4) Ο Kroma της PD κοστίζει περίπου 23.000 ευρώ και ο Vivitek, αν θυμάμαι καλά, γύρω στα 20.000$. Με αυτά τα δεδομένα, θα εκπλαγώ αν δούμε την Benq να δικαιώνει τη φήμη της ως φθηνού απωανατολίτη κατασκευαστή, καταφέρνοντας να προσφέρει το μηχάνημα σε τιμή πολύ κάτω από τις προαναφερόμενες.
5) Ως προς τα τεχνικά χαρακτηριστικά αυτών των μηχανημάτων, βρίσκω ενδιαφέρον το γεγονός ότι καταργούν τον χρωματικό τροχό, δε βρήκα, όμως, πουθενά αναφορές για το αν χρησιμοποιούν μονοχρωματικό ή τριχρωματικό led. Αν γνωρίζει κάποιος κάτι παραπάνω, ας μας διαφωτίσει. Αν ισχύει το δεύτερο, τότε το πράγμα έχει όντως ενδιαφέρον.
Συμπερασματικά, πέρα από τη όποια γκρίνια, επιφυλακτικότητα και παιδικές ασθένειες, δεν αμφιβάλλω ότι σε 5-6 χρόνια, η αγορά θα έχει βρωμίσει από τέτοια μηχανήματα, σε τιμές προσιτές για τους περισσότερους από εμάς. Υγεία και υπομονή, να υπάρχουν!
Spiromag
