Boston G5 Subwoofers
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Designed to dominate small enclosures like no other subwoofer can, Boston G5 pounds out plenty of devastatingly accurate, remarkably deep bass. Add in stunning design, steadfast reliability, and remarkably easy installation and you've got a subwoofer that demands a new level of respect—even from the most seasoned enthusiast.
Boston's premier G5 12-inch competition subwoofer
# 3-inches of peak-to-peak excursion
# 2¾" 4-layer voice-coil
# Radialvent® cooling technology
# SureSet™ impedance selection and overdrive protection
# SPS™ (Soft Part System) removable assembly enables SVC/DVC swaps and field repairs
# Can be field-stripped and custom painted, powder-coated, or plated
# Optimized for small sealed enclosures–only 1.0 cu. ft. is required
# Integral sealing gaskets simplify both standard and inverted mounting
# Compatible with GTR TunableRadiators™, for increased bass output without added enclosure volume
# Available in dual 4-ohm and single 4-ohm versions
Boston's premier G5 10" competition subwoofer
# Optimized for small sealed enclosures–only 0.5 cu. ft. is required
    Chauncey Gardiner * tl;dr *
geo kok
