Bowers & Wilkins T7
m1ts0s
News poster
With T7, you can stream audio directly from any Bluetooth-enabled PC, tablet or mobile phone, without the need for a Wi-Fi network. T7 uses high quality Bluetooth aptX, which mean you can stream high-resolution audio files for crystal clear sound.
"The speaker’s honeycomb bezel is more than just a funky affectation, but an innovation derived from the company’s 800 Series Diamond loudspeakers, which sit in the famed Abbey Road studios. Claimed to be the first commercial application of its Micro Matrix honeycomb structure, B&W says the design allows for a stiffening solid platform for the T7’s drivers to squash cabinet vibration and distortion.
The drivers on board the T7 include dual patent-pending “high-output” bass radiators for rich, powerful bass, as well as dual two-inch drivers. The drivers are constructed from glass fiber, similar to the company’s premium wireless music systems, mounted in a steel basket, and powered by a pair of filterless class D amplifiers to help promote clear, full midrange and treble extension."
ModelT7
DescriptionWireless Portable Speaker
Technical featuresBluetooth
Digital Signal Processing (DSP)
High Quality Class D amplifiers
Rechargeable lithium ion battery
Drive units2x 50mm (2.0 in) Full range
2 x Auxiliary Bass Radiators (ABR)
Frequency response58Hz - 19kHz +/-3dB
Frequency range-6dB@ 50Hz to 21kHz
Amplifier power output2 x 12W
Power supply voltageInput: 100-240Vac, 50/60Hz, 1.0A, (Power supply)
Output: 15Vdc, 2.0A
Power consumptionStandby: 0.141W
Sleep: 0.317W
Operating temperatureThis product is only designed to work at an ambient temperature of up to 45°C
InputsAuxiliary - analogue (stereo 3.5mm jack)
Service - firmware updates only (micro USB)
Height114mm
Width210mm
Depth54mm
Net weight940g
EnclosurePolycarbonate
$349.99
http://www.bowers-wilkins.com/Wireless-Speakers/Bluetooth-Speakers/T7
  • loggeo
geo kok
