Dirac Live Room Correction Suite
m1ts0s
News poster
The Dirac Live Room Correction Suite™ is tailored for computer audiophiles. Dirac Live® technology optimizes the audio performance for your system, delivering the best possible sonic reproduction regardless of environment. With the Dirac Live Calibration Tool™ for PC and Mac you can easily measure the acoustic characteristics of your loudspeakers and your room, and then calibrate them accordingly - eliminating unwanted coloration. The suite also includes Dirac Audio Processor™ which allows you to apply correction to all sound that is played from your computer, regardless your media player.
Ordinary Price: 650 €
Early adopter special: 487.50 €
Υπάρχει και free trial στο site.
EDIT: The Limited Trial version will allow you to assure compatibility with your computer and sound card before you make a purchase. It will enable you to measure and display the frequency response and the impulse response of your room, but it will not allow you to make a Dirac optimization.
http://www.dirac.se/en/consumer-products.aspx
vlasis
Φωτογράφος!
Απάντηση: Dirac Live Room Correction Suite
Μπραβο Μητσαρα μου...........αλλα γαμωτο δεν ειναι και λιγα τα φραγκα στην εποχη μας ειδικα αν εχεις φτασει στο επιπεδο που θες τον ηχο σου με το αναλογο συστημα και θες να το χρησιμοποιησεις για...μια φορα!!!
leftos
